4x4 camshaft o-ring, where should it go?
Old Jul 7, 2009 | 08:39 PM
Andreas's Avatar
Andreas
Default 4x4 camshaft o-ring, where should it go?
Was going to swap the camshaft o-rings on my 4x4 cossie but the workshop manual only got a pic of the 2wd setup and the 3wd is completly different. Mine didnt have any o-rings fitted either so thats why don't have clue where I should put them, lol.
Does this order seems correct, starting with a bare camshaft?
Bearing
O-ring
"That metal ring with the oil seal"
Woodruff key
Sprocket gear
Bolt
Old Jul 8, 2009 | 07:25 AM
No, the thin o ring seal goes in the groove on the outside of the bearing carrier.
Old Jul 8, 2009 | 08:08 AM
Andreas's Avatar
Andreas
Hmm, do you mean in the same groove as the retainer ring in this pic, ie beneath the ring?
Or on the outside of the retainer ring so that it seals between ring and the grooves in cam shaft caps no1 and no6?
And im sorry for being thick.
Old Jul 8, 2009 | 12:04 PM
Presumably the 4x4 are different to 2wd judging by your piccie, the 2wd have a groove in the centre of the bearing carrier, ie the bearing sits in it's own housing, but your outer race is directly on the head, maybe kit was to do both 2wd and 4wd ?
Old Jul 8, 2009 | 12:08 PM
Andreas's Avatar
Andreas
Yes its quite a bit different compared to 2wd and the workshop manual that contains a very good pic of the 2wd camshaft and how to fit it dont have a pic at all over the 4wd.
I think both 2wd and 4wd use a o-ring but they differ in size.
Old Jul 8, 2009 | 12:32 PM
silky16v's Avatar
silky16v
Get on That!
the place you suggested for the o-ring on 4x4 camshaft is correct
but i've on 2 rebuilds i've left them out and had no issues
Old Jul 8, 2009 | 02:35 PM
Andreas's Avatar
Andreas
Ok, this is the order it should be fitted in.... Thanks to SCS for helping me out.
Old Jul 8, 2009 | 06:43 PM
MannheimAlex's Avatar
MannheimAlex
Strange...never fittet an O-ring on 4x4s
Old Jul 8, 2009 | 07:01 PM
Escos2483's Avatar
Escos2483
From: guernsey,c.i.. a rip off island , full of drunks
It is there to stop oil running along between the bearing inner race and camshaft ... If the o ring was not there oil could leak out towards the cam sproket
Old Jul 8, 2009 | 08:17 PM
MannheimAlex
But they seem to be not that important, cos mine never leaks
Old Jul 9, 2009 | 05:43 PM
2001ode's Avatar
2001ode
Hi,
O'ring is part 3.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
