Gearbox Problems
Old Jul 7, 2009 | 02:43 PM
C0S_TURBO's Avatar
C0S_TURBO
Default Gearbox Problems
Hi, put my 3 Door away at the end of last summer everything working well. It went for its MOT yesterday, passed which was a huge relief, but on the way home I was unable to select 5th gear. Hadn’t been a problem on the way there. Took it out again this morning and I can get fifth but very sticky (not sure if that is the right word). First thoughts are low on gear oil get some new oil and change it and do the diff while I am at it. Does anyone know which gearbox oil I should use and which rear diff oil to use?
Anyone else had a similar problem?
Many Thanks in advance!
Old Jul 7, 2009 | 03:41 PM
It's probably just needing a good run to loosen up the box, most fill with the recommended ATF, personally I use gear oil 75W90.
For the diff use something like 75W90 LSD oil, it must be lsd suitable oil.
Old Jul 7, 2009 | 11:17 PM
C0S_TURBO's Avatar
C0S_TURBO
Default Gearbox
Thanks! I hope it is nothing serious, as I have only used the car about 8-9 times in the last 4 years.
Old Jul 8, 2009 | 07:21 AM
I use mine 8-9 times a day!!
I do at least 350 a week, just got to fit me towbar now!!
TPM961
Jan 15, 2018 10:50 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
gingeRS
Sep 4, 2015 06:29 PM
