Laptop pc help needed please
Old Jul 3, 2009 | 08:13 PM
st3v3's Avatar
st3v3
Default Laptop pc help needed please
I have been asked to fix a HP compq 6720s
The problem being,on boot up i get "PXE-E61: Media Test Failure, Check Cable" error msg.
I belive after many hours of trawling the 'net that its a boot up problem where the pc is trying to boot from a network.
I have altered the boot up order to make sure that there is no network before optical drive or HDD but still i get the error msg.
I have also purchased a new HDD today to replace maybe the faulty one, but proved wrong on this aswell,plus the self test on the hdd proved ok.
Any help on this i would be greatfull for
Old Jul 3, 2009 | 08:18 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
From HP Support Website: Unsure if you have done this.
RESOLUTION
For a succesful PXE boot, perform either of the following:
  • Manually change the PXE link speed as follows:
  1. During the Power-On Self Test (POST), press CTRL+S when the LAN On Motherboard (LOM) that is attempting the PXE boot is bannered. The setup menu will be displayed.
  2. Select "Speed."
  3. Select "1000bps."
  4. Press the F4 key to save.
  5. Perform the PXE Boot.
OR
  • Flash the firmware of the HP NC373i Integrated Multifunction Gigabit Server Adapter to an earlier version (boot code Version 1.9.6), using the HP Gigabit Server Adapter Firmware Upgrade Utility for c-Class Blades. Perform the following steps to obtain a version of the HP NC-Series Broadcom Online Firmware Upgrade Utility with a boot code Version 1.9.6:
  1. Click on the following URL:
    http://www.hp.com/support/nc373i
  2. Select the appropriate operating system.
  3. Select the Firmware-Network category.
  4. Select HP NC-Series Broadcom Online Firmware Upgrade Utility .
  5. Click on Revision History .
  6. Click on Release Notes (locate boot code Version 1.9.6).
  7. Select a version of the HP NC-Series Broadcom Online Firmware Upgrade Utility with a boot code Version 1.9.6 and click the "Download" button.
From: http://h20000.www2.hp.com/bizsupport...reg_R1002_USEN
Rick Astley
Or
http://h10025.www1.hp.com/ewfrf/wc/d...reg_R1002_USEN
Old Jul 3, 2009 | 08:48 PM
st3v3's Avatar
st3v3
Originally Posted by doesntbelong
yep done that one matey, gonna read your first post again now,brb
Old Jul 3, 2009 | 08:51 PM
st3v3's Avatar
st3v3
RESOLUTION
  2. Select "Speed."
OR
Nope that dont work either, bugger!!
Im gonna give it them back, im already out of pocket by Ł25 buying them a new HDD that i dont need or cant use
Old Jul 3, 2009 | 09:00 PM
Rick Astley
I'm stumped then I'm afraid matey!
carfixz's Avatar
carfixz
www.hplies.com probably an inherent problem with it from new that HP knew about
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
