What do I need to convert my MFi RS Turbo to run EFi? Updated 05/04/14
Old Apr 11, 2009 | 01:08 PM
mentalasanything's Avatar
mentalasanything
Default What do I need to convert my MFi RS Turbo to run EFi? Updated 05/04/14
It has struck me that other than the Cossie brake upgrade, there is a question that keeps on getting asked day after day!
"What do I need to convert my MFi RS Turbo to run EFi?"
I propose a Sticky thread on a "Basic" conversion using OFAB or OFAC.
I've done a lot of research into this as I plan to do this conversion myself. Before I start here's a quick list of my references:
www.rsbible.co.uk - Very descriptive, good pictures and diagrams.
www.extraefi.co.uk - A good EDIS diagrams
www.passionford.com Our friendly Forum
www.dainst.com lots of EDIS info
www.megamanual.com - Lots more on EDIS
Other sites I may have to add!
Here's my 2p's worth feel free to add, remove or CONSTRUCTIVELY criticise:
You will need:
1) CVH EFi Head (XR2i or Fiesta RS Turbo) or MFI>EFI sandwich plate.
2) Complete EFi inlet (Inlet manifold, throttle body, injectors, fuel rail, pressure regulator, Throttle position sensor, Idle speed control valve and injector wiring loom)
3) ECU and engine Loom (OFAB or OFAC, loom to suit) An XR3i EFi loom can be used with OFAC.
4) Electronic Distributorless Ignition System (EDIS-4 unit, Crank Position Sensor and Coilpack).
5) Suitable HT Leads.
6) Some form of Crank Position Sensor pickup, either:
.....a) A drilled block and EFi flywheel.
.....b) Sierra CVH crank and alternator pulleys with sierra CVH lower timing belt cover and ribbed aux belt.
.....c) A N Other 36-1 tooth trigger wheel on the crank with Crank Position Sensor bracket (Oddkid creations have been mentioned).
7) MAP sensor (ECU Specific).
8) CO2 Potentiometer.
9) Vehicle Speed sensor.
10) Fuel hose from fuel filter to fuel rail.
11) Engine sensors for the ECU type chosen.
12) XR2i or XR3i EFI throttle pedal and throttle cable.
13) Fiesta RS Turbo rocker cover and charge carrier (ERST ones may be used but a bit fiddly).
14) OFAB will need a MAP sensor suppressor
You won't need:
1) XR3i EFi Dash pod and rev counter. Contrary to popular belief you don't need an XR3i EFi Rev counter. If you intend to keep the wiring as it is, the standard output is from pin 10 of the EDIS which is one of the 2 coil drive outputs. This will obviously only give you half the reading of the current revs which the XR3i EFi rev counter can interperate correctly but the S2 one can't as it would need an input from both coil drive outputs. To overcome this you have two options:
A) Add an output to pin 11 of the EDIS which is its CTO (Clean Tacho Output). There is no pin on the EDIS connector at pin 11 on the XR3i loom and I'm not sure about the FRST loom but one can be easily added. You can just drill a small hole through the back section of the casing, steal a pin from a spare EDIS connector and push it through. This method doesn't often work!
B) Build a tacho adapter by following this diagram:
Credit for this image to www.locostbuilders.co.uk
Either of these methods can then be run as far as the RPM suppressor and plugged directly into the green cable running to the dash bypassing the suppressor and the output from pin 10.
A few things to note:
1) If you want to run anything other than standard settings, the relevant chip and injectors are required (165/195chip, Bosch "beige" 701 injectors).
2) If you want to run more than 1 bar (14.5 psi) of boost, you will have to use an alternative MAP sensor. For OFAB you can use a Cosworth 3 bar MAP sensor which can measure up to 2 bar of boost (1 bar atmospheric pressure and 2 bar positive boost). For OFAC, you can use a Small Turbo Escort Cosworth MAP sensor. This sensor is a 2.5 bar item (1 bar atmospheric pressure and 1.5 bar positive boost).
3) If you want to use an XR3i EFi car & engine loom (1AfA) whith OFAC there are usually no pinout changes. On some installations you will need to check that the CO pot goes to the correct pin for your ECU, some are 8, some are 27. This will need confirmation with a gas analyser.
4) You may get a seemingly low reading from the rev counter. If so you may get away with running a wire from pin 11 of the EDIS module as described above, if not, build your own tacho adapter.
5) If you use the Sierra 1.8 CVH crank pulley you will need the Sierra 1.8 CVH alternator bracket. This bracket needs 5mm machined off the one side to align it with the crank pulley. You will also need a 5mm washer (As sold by Oddkidd creations) to fit between the crank pulley and the retaining bolt.
How to with FRST loom:
I wont make this a full step by step, that would be dificult as there are a few diferent scenarios and would take forever. If you have chosen the correct loom for the ECU then no pinout changes need to be made (Obviously). Thus making neither OFAB nor OFAC harder than eachother.
1) Disconnect the battery!
2) Fit all of your mechanical parts.
3) Fit all of your sensors.
4) Tape back the parts of the original loom not required. Once finished and tested you can cut out and remove any parts of the loom not required if you like.
5) Install the EFi engine loom.
6) Connect the engine loom to the car loom. You will need to do a bit of chopping and changing. This bit can be tricky, but I will re-post this diagram by passionford member Rab as I think it shows it quite well:
7) Run a wire from the rev counter input to pin 11 of the EDIS-4 unit or by using the tacho adapter above.
8) Connect up the engine loom to the sensors, cooling Fan, ECU, coilpack, Idle speed control valve and EDIS (Some wires may need to be extended eg. Fan and ISCV).
9) Double check everything!
10) Cross your fingers and fire up the car!
If you use the loom from an EFi XR3i it's even easier, just fit the loom to the car, plug in an OFAC ECU and MAP sensor and you're away. That's my plan:
One almost complete loom, just needs a trial fit and taping up.
For the fuel system, i have left the MFi accumulator and fuel filter in place. From the fuel filter I have a braided hose going over to the fuel rail. To acomodate a fuel pressure gauge I have utilised one of these banjo bolts from Burton Power: Click Here, I then drilled it out right through the midle and have attached my gauge to the M10 end like so:
And with a bit of luck, you'll end up with a bay like this:
I'm not claiming this is complete, but it should answer most of the repetitive questions! and a big thanks to everyone for the info I've gathered.
Edit 05/05/2013:
Setting up
• The CPS needs to be very close to the trigger wheel, we're taking 1mm
• The fuel pressure needs to be set to suit the spec. The original FPR is adjustable, you just need to remove the silver circular tab covering the adjustment screw (This is on the top of the FPR), then the pressure can be adjusted acordingly
• A stage 2 (195 spec) engine needs around 3.5 Bar of fuel pressue with the engine running and the vacuum line removed from the FPR
• Don't forget to use a pressure gauge when setting the fuel pressure.
Troubleshooting tips
• The EDIS module should have 12v ignition live to pin 8 and should have earth to pin 9, the XR3i EFi loom has the earth ring termination down by the horn.
• All 3 pins on the coil harness should have positive 12v with the ignition on and the engine off, the edis switches the outer 2 pins to earth to fire the coil
• To test the coil, you should get about 3-6Ω resistance across the middle pin and one outer pin of the coil's loom connector and 13-16KΩ across 2 common lead posts (I.e. 1&4 or 2&3)
• To test the CO Pot, look at the connector holding it with the adjustment screw pointing upwards, put your multimeter across pins 1 and 2. You should get readings of between 0.5-5.5Ω. My CO Pot doesn't go from point to point, it just keeps tuning but doesn't go beyond those readings.
• Lumpy idle when warm could be due to a faulty ISCV. The issue I had was I removed the breather system in favour for a mini K&N on the rocker cover; bad move. There are two vacuum ports on the lower inlet manifold, these take in fresh air and vapours from the breather system for idle!
• Chipped ECU's will give you ECU error codes when using a code reader. You will get something similar to:
A) 53 Throttle Position sensor above maximum voltage
B) 72 MAP, MAF or BP sensor out of range during Dynamic Response Test
C) 59 CO potentiometer error
You may also receive checksum errors.
Edit 07/06/2013:
There's been quite a debate recently about rev counters, some saying that pin 11 of the EDIS worked for them, others saying it didn't. Well, for those that it doesnt work, the circuit below shows how to set up a direct feed from the coil drives to your rev counter:
Edit 17/07/2013:
Well, there's been a lot of mention recently about pin changes on the XR3i EFi loom for use with OFAC. There seems to be a few variations of looms out there. Mine is a late spec EFi loom and all the pins were correct. For other looms some pin changes are required, as detailed by Karlos on this thread: 1afa - ofac
Originally Posted by Karlos G
If anyone is interested this is the wire swaping you need to do for XR3i/XR2i (1AFA) to FRST (OFAC)...
1) Pin no. 8 (brown) needs moving to pin 27, which is empty (CO adjuster signal wire)
2) Pin no. 27 (brown/yellow) needs moving to pin no. 45
3) EDIS Module pin 2 (blue/yellow) may now be disregarded as it is not used by the 0FAC ECU (pin 28 on ECU).
There are no MAP sensor pin changes as the OFAC MAP sensor is the same plug as the 2i MAP Sensor, so just plug and play.
But... only on some conversions it seems!
Some work plug and play and others need the above doing, maybe there are some subtle differences in the ECU/loom's of different years I don't know?! But I guess if it doesn't work one way then try it the other! lol
Karlos.
Basically, you will need to check that the CO signal wire goes to the correct pin for your ECU, this will need confirmation with a gas analyser. Also check that the MAP signal wire goes to pin 45.
Edit 17/08/2013:
I can confirm that using pin 11 of the EDIS for my Tacho signal didn't work for me. I've had to use the diode circuit above. The good news is it works well. I've also set the CO% level to 1.5% as per the Haynes manual so now the car is ready for an MOT!
Edit 05/04/2014:
It's been a while! Good news is the cabby now has an MOT! I sorted out my base idle issue which I've added to the troubleshooting section above.
Edit 20/06/2014:
I've finally had the cabby dyno'd and all is well. Made a decent amount of horsepower at 10psi boost with a nice torque curve to match. However, it didn't all go to plan to begin with. It was a figment of my imagination (and partly to do with my Gunson Gastester) that the CO pot was located on the correct ECU pin. Contrary to popular beleif, my CO pot didn't work at all on pin 27, and had to be moved to pin 8. The thread has been updated above.
Lee
Old Apr 11, 2009 | 01:26 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Good work mate thanks!
Sticky would be a good idea too!
Old Apr 11, 2009 | 01:29 PM
mentalasanything
Have requested it!
It struck me that I was going to offer an answer to yet another EFi question this morning so thought why not, I was waiting for the missus to get ready so I had a a spare hour!
Old Apr 11, 2009 | 01:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I cant see why it would'nt be made a sticky, the Cossie brake conversion was and questions related to MFI-EFI conversion are asked probably just as much!
Old Apr 11, 2009 | 01:41 PM
Zetecfiesta's Avatar
Zetecfiesta
deffo mate, good information!!
Old Apr 11, 2009 | 04:01 PM
Chris69's Avatar
Chris69
nice writeup mate its about time somebody wrote one and got it made a sticky
As a side note its worth mentioning in order to get a working standard look rev counter a 90 spec Xr3i item will be needed and conection to the edis module using pin 11 for the feed to it
Old Apr 11, 2009 | 04:28 PM
mentalasanything
Added! I forgot about this, may have a workaround rather than replacement though......
I have read that you can use the coil of a relay to boost the tacho signal (See "Hi Voltage diagram" on page 2 here: http://www.extraefi.co.uk/Drawings/P...cho_Wiring.pdf) I know this is for a megasquirt and I haven't tried it. But it may work for the non EFi rev counters. Anyone have any oppinions to offer on this?
Lee
Old Apr 11, 2009 | 08:10 PM
rstel1's Avatar
rstel1
nice one
sticky all day long
Old Apr 11, 2009 | 10:14 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
So what your saying is i can do the complete mfi to efi swap using a donor xr2i? My mfi head needs a rebuild so would use the efi head and use a sierra pulley system for the cps.Then i can use everything else from the xr2i and will use my mfi charge carrier as its nice and polished and make it fit somehow!!
Am i correct?
Once the efi is installed is it ok to turn up the boost to say 15psi and the fuel will automatically be adjusted?
Old Apr 12, 2009 | 06:47 AM
mentalasanything
Am i correct?
I dont know about the XR2i loom, but you can use the complete head and inlet without any problems, they are the same as the Fiesta RS Turbo items. You can use your charge carrier, the hose connecting it to the throttle body may be tight but use a silicone hose and a very light smearing of fairy liquid and it'll go on.
As for the boost, you should get the car set up by a tuner initially, if only to get the CO levels right. Once that is done, the ECU and EDIS module should work out the ignition and fueling based on how much boost the MAP sensor sees. You will need a 195 chip and Beige 701 injectors to run that much boost though.
Hope that helps
Lee
Old Apr 12, 2009 | 07:18 AM
nigel b's Avatar
nigel b
you can use the escort cossie 2.5bar map sensor on ofac
Old Apr 12, 2009 | 09:42 AM
notroubleclubber
Ive now heard i would need a fiesta turbo ecu and matching map sensor? Is this true or can i use everything from xr2i and just get the 701s and cossie map sensor?
Old Apr 12, 2009 | 05:18 PM
daveselwood's Avatar
daveselwood
does this work as im converting a series1 to efi using frst parts from my old frst
Old Apr 12, 2009 | 07:50 PM
Bryan_RST's Avatar
Bryan_RST
i thought the xr2i loom was the same as the the turbo loom the only thing the xr2i loom does not have is turbo contral
Old Apr 12, 2009 | 10:00 PM
Chris69's Avatar
Chris69
Lee
I've heard about this but don't know of anybody that has made it work, I was gonna give it a go after reading about it but stumbled upon a Efi item in a scrappy so i know that works with a frst ofab setup for sure.
Old Apr 20, 2009 | 03:12 AM
mentalasanything
Edited to update rev counter info.
Old May 10, 2009 | 07:17 PM
B1G_RST's Avatar
B1G_RST
few bits of info needed for tapping into the exsiting loom/wiring,,
1.which relays which ? haha whats colour of the fuel pump relay and fuel injection relay?
2. pin 6 goes to the oil press sw, this the switch that the turbo braided hose goes into at back of block?
3. anyone no colour of ignition switch cable i need to conect into?
4. pin 3 go to the back of the rev counter aswell as a cable from pin 11 to the back of the cover?
cheers for any advice
Old May 11, 2009 | 01:02 PM
mentalasanything
Right, I'll have a go:
1. Fuel injection relay is a spst one
2. I can't completely remember where it comes out of but I'm sure you're correct.
3. Cant remember the colour off the top of my head, use an inline tester to look for the one that lights up the tester with the ignition lights on.
4. If you have a EFI dash then pin 3 goes to the rev counter. If you have a S2 dash then run a cable from pin 11 of the EDIS to the rev counter (You could cut the cable to pin 3 on the multi plug and replace it with a feed from pin 11 of the EDIS)
Lee
Old May 11, 2009 | 05:17 PM
Rab's Avatar
Rab
Fucking superstar........
This is why I've been getting PM's recently
I did wonder why all of a sudden people were aking questions about EFi again
Old May 11, 2009 | 08:25 PM
mentalasanything
Sorry dude! Good work tho!
Lee
Old May 12, 2009 | 09:41 PM
Rab's Avatar
Rab
Lee
No worrie mate, happy to help! I reckon I'll do another one soon I'm THAT stupid
Old May 24, 2009 | 03:07 PM
MIKE_ERST's Avatar
MIKE_ERST
is the xr2i loom the same as an rs turbo loom? if so is it ofab or ofac?
Old Jun 19, 2009 | 02:51 PM
darrenb16two's Avatar
darrenb16two
If i got an xr2i could i use it as the donor car? Would i need to buy much else?
Old Jun 19, 2009 | 03:19 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Old Jun 22, 2009 | 04:53 PM
steven botes's Avatar
steven botes
i dont agree about the head
the carbed cvh can be modified to accept the efi inlet without an adaptor plate
my xr3i has a standard head modified by myself with a drill and dremel mini grinder - using a efi inlet gasket as a guide , remove material at the top of the port for the injectors - you do not need to remove the material as far up as the gasket , just enough to accept the injectors
Old Jun 22, 2009 | 05:04 PM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
im a bit stuck with this ive just been told by jam sport that i cant run a cossie 3 bar map sensor with my ofab ecu is the case or can i
Old Jun 23, 2009 | 12:39 PM
mentalasanything
Yes you can but only on OFAC. A cossie 3 bar map sensor will read up to 2 bar of boost.
Old Jun 23, 2009 | 12:43 PM
mentalasanything
TBH the only things you need off an XR2i is the top end of the engine so unless it was dirt cheap it's probably uneconomical.
I'm unsure mate, I bet it is the same as one of them! Anyone have any idea?
You have to be very carefull. I found a fantastic article the other day:
http://www.pumaracing.co.uk/CVH.htm
I think it was that one and it defined what heads can be modified for what. And I did read that some heads have water ways running through the parts of the head where you have removed metal.
Just something to note really, you can as you rightly say remove metal, but I personally wouldn't when a CVH EFi head is so easy to come by.
Lee
Old Nov 20, 2009 | 12:54 PM
mentalasanything
Just an update on the loom:
I basically bought an XR3i EFi loom off e-bay and had an extra 1 thrown in for free. 1 of the looms seemed ok and the other one not so good. On closer inspection they were both not so good. One had a good car loom with all the extra's wired in but someone had cut off the ECU plug = No good. The other had been cut about, had a few melted wires in but the engine loom was perfect.
So basically I took the car loom from one and the engine loom from the other and made 1 good loom, turns out there are only a few common pickup points connecting the 2.
I then added an extra cable out of the EDIS to run my S2 rev counter. For this I ran a short wire from pin 11 as far as the original rev counter suppressor, cut the applicable plug from the other loom and plugged it straight into the rev counter wire, easy. I also moved the CPS plug to the other side of the engine bay to suit my 1.8 CVH crank pickup, again easy just using shielded cable bought from Maplin.
I've added some extra's in there too. I've added a time delayed interior light relay, the fading type like all modern cars have and also a "Lights on" warning.
Other than that I've just tidied any wiring faux pas that had been added, put heatshrink over any exposed wire and that's about it.
All that remains now is to trial fit it, once I'm happy I'll loom in the alarm and tape it all up.
Hope you like!
Lee
Old Nov 23, 2009 | 10:30 PM
MIKE_ERST's Avatar
MIKE_ERST
what relay is the fuel injection relay? (NOT the fuel pump relay) from the diagram in the first post? is it from the escort loom or fiesta loom? what colour, maybe part number ect.. any help will be muchly appriciated
cheers, mike.
Old Nov 24, 2009 | 12:18 PM
mentalasanything
cheers, mike.
Basically they arent part of the engine loom, but they are identical standard 40a SPST relays (fuel pump and injection). FRST ones can be used if you want a factory look, otherwise just get some from your local motor factors, not expensive at all. Just make sure the terminal numbers on the underneath match.
The ones for my '3i loom are part numbers 85BG6911AA (Yellow - Fuel pump) and 81AG14N089CA (Red - Fuel injection). They are identical relays, just a diferent colour for ID purposes. The relay types are standard accross the board where EEC-IV is installed, just diferent colours for ID.
The fuel pump relay from MFi can't be used either, must be a spst item. The reason being that the EEC-IV controls the priming, whereas in MFi the fuel module provides a positive pulse to one pin to make the pump prime iirc.
Lee
Old Nov 24, 2009 | 06:54 PM
MIKE_ERST's Avatar
MIKE_ERST
ok so basically im after 2 40amp, 4 pin relays with the 30 - 85 - 86 - 87 pins?
Edit: ive got 2 81AG14N089CA relays, theyre both yellow, 40amp and have the right pins. Theyll do nicely
cheers, mike.
Old Nov 24, 2009 | 09:22 PM
mentalasanything
cheers, mike.
Nice! Glad to be of assistance!
Lee
Old Dec 2, 2009 | 08:41 PM
MIKE_ERST's Avatar
MIKE_ERST
yet another queery mate. Im using an ofab loom but i dont think i have a map sensor supressor. do you happen to have a picture or could you get one to show me what im looking for?
cheers, mike.
Old Dec 13, 2009 | 10:19 PM
churchy(ilikeitwide)'s Avatar
widearch rs project
Thumbs up
very helpful write up as im planning to build a zetec turbo for my s2 rs and will need to convert to mfi ,, cheers
Old Dec 16, 2009 | 11:31 PM
motormel's Avatar
motormel
Lee
what colour are the plugs that the relays connect to for the fuel pump and injection relay? i have a series 2 and trying to do this converstion, think i've wired into same relay (the big pink one), so i can change the relays to yellow ones (al long as they are correct numbers) but thats only the fuel pump relay, don't know which relay is the fuel injection one. Can someone please help??
many thanks
Mel
Old Dec 17, 2009 | 05:30 PM
mentalasanything
many thanks
Mel
On the original MFi loom the pink plug is for the fuel pump relay, there is no fuel injection relay. So you need to remove the pink plug and rewire the neccessary connections as per the diagram at the top, you then need to add a plug and relay for the fuel injection.
In my loom pic above the yellow holder is the fuel pump relay and the red holder is for the fuel injection.
Lee
Old Dec 17, 2009 | 06:07 PM
motormel's Avatar
motormel
Lee
cheers that helps loads, many many thanks. if i get stuck efi loom here i come lol
regards
mel
Old Feb 25, 2010 | 07:15 PM
rs milesy's Avatar
rs milesy
What does the speed sensor look like ?
What does the co potentiometer look like ? And were do they fit ?
Any chance of some photos please of them fitted
Cheers.
Old Jul 19, 2010 | 10:14 AM
Blunt.RS's Avatar
Blunt.RS
What is OFAB & OFAC
am currently getting bits to turbo my xr3i its running efi
but getting abit confused as to what i need
links are great but not understanding all of it
