What do I need to convert my MFi RS Turbo to run EFi? Updated 05/04/14
#41
OFAB and OFAC are the two variants of the Fiesta RST ECU. OFAC is wired exactly the same as the 1AFA ECU that is in yuour XR3i so it's a straight swap!
Lee
#42
Your are a true gent sir thankyou very much
So basically i dont need to change the wireing or anything just plug and play LOL
#43
If you want to use the OFAB variant of the FRST management there are a few pin changes to be made at the ECU end and a supressor is required for the MAP sensor. Nothing major but must be noted!
Glad to be of assistance!
Lee
#44
Hi, I'm thinking in to fit a FRST engine in my ERST S2. I have already a complete FRST engine and I'm wondering in to buy a OFAB engine loom. Well, my question is how to connect this fiesta engine loom to the standard S2 wiring. I have readed a lot of information but always the author speaks about XR3i loom. Do I need really use anything from Xr3i or can I do the conversion only with FRST engine and loom?
#45
Lee
#46
I know that I have to run a wire from the rev counter input to pin 11 of the EDIS-4 unit. Is it the same signal of the pin 3 in the multi plug engine loom? It is probably an stupid question but it is difficult for me to understand everything in english.
Thanks.
#47
ok heres a retard question. can some one explain the advantages of the efi to the mfi? mines is mfi and id be interested in converting but seems alot of work. would like to know the advantages should i decide to do the conversion. if some one could pm me id be greatful
#48
Sorry to dredge this up again... But...?
Ive done exactly as this guide states, converted my EFi Orion to EFi Turbo using OFAC ecu and sensors etc and it doesnt run properly... I don't think it's as simple as plug and play!? The fueling was all over the place and the ECU would not respond to changes made to fuelling via the CO Pot and Fuel Pressure Reg...
Is there some variations in the XR3i/XR2i and Orion EFi looms?
#49
Double check your wiring compared to that.
Lee
#51
Well it should match your current loom. Item 7 on the diagram is the co pot so start there and work through the other connections to the ECU.
Lee
Lee
#52
We have fitted a rebuild frst engine in my escort, but I have some questions :
Which throttle cables and pedals can I fit? Xr3i, xr2i,... Can I take them from any Zetec?
Cheer
#53
Hello,
I have followed the wiring diagraman showed in this post and I have problems with the injectors' signal in the connectors. How is the signal I should mesured in them? I have disconnected the fuel ramp conector and I have measure continuity between 2 pins of injector's connector. Is it normal? Have I got a short circuit?
Thank you for your help.
#58
Whilst building my engine, i have found a few little extra bits. So, I have done a small update to the main post.
I found that if you use the Sierra 1.8 CVH crank pulley you will need the Sierra 1.8 CVH alternator bracket. This bracket needs 5mm machined off the one side to align it with the crank pulley. You will also need a 5mm washer (As sold by Oddkidd creations) to fit between the crank pulley and the retaining bolt.
Also, I've done a lot of reading about MAP sensors. It turns out you can run more than 1 bar of boost using OFAC. You can use a Small Turbo EsCos MAP sensor to run up to 1.5 bar of boost. Not as much as the 2 bar you can run on OFAB, but better than first thought!
Lee
Lee
#59
If you use the loom from an EFi XR3i it's even easier, just fit the loom to the car, plug in an OFAC ECU and MAP sensor and you're away. That's my plan:
One almost complete loom, just needs a trial fit and taping up.
I'm not claiming this is complete, but it should answer most of the repetitive questions! and a big thanks to everyone for the info I've gathered.
Lee
Lee
hi there,
im on my way to convert to efi. have almost all parts installed, but i have wiring issue.
it seems xr3i mk4 loom isn't straight swap. i have to chop and connect more than two cables: reverse light, temp gauge sender, temp sensor, iscv and some others.
is it correct or i have been cheated with loom? is there any wiring diagram for xr3i mk4? i have almost all manuals but i can't find this wirings.
if there isn't one can someone tell me what wires excactly need to be extended?
is it the solution?
Now using OFAC management, there are NO ecu pin changes to be made!! I cannot stress this enough. The car above (my car!!) does not have any pin changes on the ECU, and its fine. Many sources I had found while searching to do this, said I would have to change pins. Looking at the wiring diagrams, I found this hard to believe. When I purchased my engine and ECU, it came with the FRST engine loom. So I sat with my multi-meter, and found out where all the ECU wires went!
Results are as follows!
1, Red -- +ve
3, Brown/Yellow – octane / idle adjust
4, Brown/White – speed sensor
7, Brown/Green – engine temperature sender
16, Brown – current return & 40
17, Brown/Green – diagnostics connector
20, Brown – current return
21, Brown/Yellow – idle speed valve
22, Brown – fuel pump relay
23, Brown/Red – octane / idle adjust
24, Brown/Blue – octane / idle adjust
25, Brown/Yellow – air temp sensor
26, Brown/Black – throttle sensor & co adjust pot & map sensor
27, Brown – CO adjust potentiometer
28, Blue/Yellow – Pin 2 on edis (disconnected)
33, Brown/Green – Boost control valve
36, Blue/Red – Pin 3 on edis
37, Black – idle speed valve & injectors & Speed sensor & Boost control (tbc) & 57
40, Brown – current return & 16
45, Brown/Yellow – map sensor
46, Brown – map sensor & engine temp & air temp & throttle & CO adjust
47, Brown/Green – throttle sensor
48, Blue/Green – diagnostic connector
56, Blue/Yellow – Pin 1 on edis
57, Black – idle speed valve & injectors & Speed sensor & Boost control (tbc) & 37
58, Brown – Injectors
59, Brown – Injectors
60, Brown – current return
from http://www.escortrsturbo.co.uk/forum...pic=10738&st=0
i'm doing ofac.
many thanks!
#60
hi there,
As far as the ECU pinouts are concerned they are the same for 1AFA and OFAC. It's ancillary connections that need changing/extending if you are retro-fitting the loom to an S2.
You are correct to have altered/extended the cables you mentioned, these are all ancillaries. I guess you are converting an 88 spec car since you've changed the temp gauge sender? Have you also done the petrol gauge? I must admit I didnt know about the reverse switch but I'm sure you're right. You'll need to change the fan connector over too.
If you find an XR3i EFi wiring diagram let me know, I havent seen one either!
Cheers,
Lee
#61
i sorted most of the plugs, i used haynes manual diagrams and electric meter. there's no better way.
i have only one issue: is it possible that some plugs will remain unplugged? i have couple that can't be matched.
#62
Lee
#66
May be somebody know what MAP sensor I need if I have OFAC ECU? I know that I need V90FB9F479AA, but may be there is any MAP with the same characteristics it means analog?
#68
Lee
Lee
#69
Lee
#70
Thanks for answer. I think that Motorcraft DY503 may be similar.(Mercury Capri 2.3Turbo)
#73
Lee
#75
Lee
#78
Which colour wire is the rev counter input? I take it its on the blue multiplug on the instrument cluster wiring? Also does pin 85 of the fuel injection relay have to go to battery negative? Or can you earth it instead?
#79
Lee
