2wd rear diff ....problems...!!!
Old Apr 5, 2009 | 08:51 AM
2wd's Avatar
2wd
Default 2wd rear diff ....problems...!!!
Hi...I have just got my diff back after a major rebuild...they have changed prety much evrything...including the diff housing.
It all looks perfect...BUT..when I tried to put it back on it did not fit...it hits the mounting the left side
It seems that it is to wide....does anyone know if there are different diff housings...I know the 4wd ones..but they are a bit smaller...please advice
Old Apr 5, 2009 | 06:30 PM
2wd's Avatar
2wd
these numbers are on the diff house 94GG-4025-AA and cover 85GG-4033-BA ... can anyone "translate" these numbers...??
Old Apr 6, 2009 | 02:20 PM
2wd's Avatar
2wd
come on...nobody knows...???
Old Apr 6, 2009 | 02:59 PM
rog's Avatar
rog
http://ford-xpert.com/search.jsp
Just type in the part number
Old Apr 6, 2009 | 05:04 PM
2wd's Avatar
2wd
thanks ... seems that the housing is from a Scorpio.....
Shouldnt at well known gearbox company know that it does not fit a 2wd Sapp. Cosworth...
Old Apr 7, 2009 | 02:14 PM
2wd's Avatar
2wd
And would I be able to modify the diff housing to fit... or ?
Old Apr 7, 2009 | 05:12 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
It should all fit straight in, scorpio housings are identical. How far out is it? Are you sure your car has the 2wd 7.5" beam and not an xr 4x4 or 4x4 cossie 7" beam in it? Measure across the rear mounting points to find out, as a LOT of cars have the wrong beams in due to people putting them over kerbs sideways etc.
Old Apr 7, 2009 | 06:07 PM
HOL's Avatar
HOL
I was going to say it looks about a half inch out!
Old Apr 7, 2009 | 07:03 PM
2wd's Avatar
2wd
well the diff I took out and send to them was a 7½"....and I have a 7" diff ánd this wont fit the beam unless I fit some spacers on the top holes...so I'm quite sure it is a 2wd beam...anyway there is about 19.4 cm between the top holes in the beam
Old Apr 9, 2009 | 02:57 PM
2wd's Avatar
2wd
I have found out that it is a late type Scorpio diff house (frog eyed scorpio ) and it wont fit...
Been told by the company that I should just cut away the ribs to make it fit....anyone have a opinion on that ???
Old Apr 9, 2009 | 03:40 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Personally I'd send it back and have THEM do any modifications, as they've cocked up. Presumably they asked what it came from when you sent it in? If so, they should've repaired/refurbished it accordingly.
Old Apr 9, 2009 | 10:05 PM
2wd's Avatar
2wd
'HE he ..I would but problem is that I live in Denmark and the company is in England
They knew that it is for a 2wd....its a long story...put in short.....I broke it...send it to them to have it build and uprated....got it back and put on the car(fitted perfect)...but it had a problem ..big whine...so they took it back...checked it but found noting and said that it was ok and send it back...but still there was a problem and I got a lokal company to look at it they said "send it back" and so I did and once again they checked it and build a new one...now I got it back and it wont fit...
And now they told me to cut it a bit to make it fit.........I dont know....?
Old Apr 10, 2009 | 04:19 AM
RWD_cossie_wil
Name the Company?
Old Apr 10, 2009 | 04:52 PM
Alvyn's Avatar
Alvyn
I'd ask them to get it collected and sort the problem and re-delivered asap!
Old Apr 10, 2009 | 08:44 PM
2wd's Avatar
2wd
Name the Company?
Well I dont think that it will help to put them up here as they in fact have tried to solve it..so for now I would rather not mention them ...its just that I'm trying to find out if it is a good idea to cut away the ribs to make it fit .... like will it be weaker ?
Old Apr 11, 2009 | 05:56 PM
Alvyn's Avatar
Alvyn
DONT think it would be making it weaker tbh their there more for cooling IMO and I'd rather have a diff cover intact than have it looking like its been bodged looking again IMO!
Old Apr 11, 2009 | 08:37 PM
2wd's Avatar
2wd
hmmm..so you would send it back....well I would normally insist on it, but I dont want to wait weeks ...maybe month to have it back...so I'm kind of locked in this ... or what ever you say in english.. ... I really dont know
Old Apr 11, 2009 | 08:47 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
the scorpios had different ratios to cossies too.....might be worth checking the ratio as it sounds like (being a bit synical here) they've cobbled together a diff from bits lying about.
The frogeyed scorpio came with an open diff (had traction control) so check that it's deffinately an LSD too
I personally would send it back and have it built into a cossie housing, like the one you sent...as the scorpio housing will mean resale value is less if its got cut ribs or if you tell people its not gen cossie.
Dan
Old Apr 13, 2009 | 03:38 AM
2wd's Avatar
2wd
Dan
hmmm,....I see what you mean... I has a LSD....and the resale in no problem..I will never let it go so I think that my only concern is about if its ok to take a bit of the house without weakening it.. (If could just go there there would be no doubt...rebuild to a 2wd house...but... )
Old Apr 13, 2009 | 01:22 PM
SillyFezzaMk1
Rubber Rhino Crew
If you're intent on keeping it then just modify your beam, cut a section out and have a strengthening piece welded in. That's the way i'd do it as most garages can weld steel & you're gambling with grinding the ribs off of the diff housing.
Dan
Old Apr 13, 2009 | 02:18 PM
2wd's Avatar
2wd
Dan
Ok ... I have been thinking about this too, but I have the car on stands in my garage and cant do welding myself :-(
I just find it strange that the company just tell's me this ...
"It looks as though the new case that we used is the later heavy duty reinforced case(from the Granada Scorpio), if the larger ribs on this case is in the way of your mount please cut them back to allow 2-3mm of clearance to the mount and it will be fine"
Old Apr 13, 2009 | 02:39 PM
SillyFezzaMk1
Rubber Rhino Crew
I think you should just do what suits you best, cutting the ribs wont make it break as they're obviously additional/extra ribs that the cossie housing doesnt havein that area.
After all if it breaks would you go back to them? I wouldnt after reading your dealings with them.
Old Apr 13, 2009 | 08:18 PM
2wd's Avatar
2wd
Well ... I will await their answer, and then decide on what to do...and I will proberly not use them again....unless it breakes shortly after I get it on (there is warrany...hopefully )...as I cant afford to buy a new one ... :-(
Old Apr 13, 2009 | 08:24 PM
iansoutham's Avatar
iansoutham
OCD Victim
I'd get it in writing that they will still honour any warranty if you take a grinder to it. Any "modification" could technically void it. I know they have suggested grinding the ribs back, but I would want it specifically worded.
If they are not prepared to do that, I'd send the diff back and tell them to get it right.
Old Apr 13, 2009 | 10:21 PM
2wd's Avatar
2wd
well that is kind of what I've been thinking.....hopefully I'll have their answer shortly after easter...
Old Aug 19, 2011 | 08:02 PM
2wd's Avatar
2wd
Here an little update on an old thread ... Diff came on after modding the house and I got the car going again ... BUT still it is very noicy ???
Anyone has an idea about what could be wrong as I take that al has been cheked by the company (well hopefully) ??
The company, who has tried to make ok twice after the rebuild, said that they could not help me anymore unless I take my car to them ... witch is difficult as I live in DK and do not want to take that long drive with an "problem diff" :-(
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
FlashRS
13
Aug 31, 2015 06:02 PM
xr4x4rs
Aug 6, 2015 09:03 PM
