Can you run TB's on standard management and the same injectors?
Old Mar 10, 2009 | 04:55 PM
Ryan's Avatar
Ryan
Default Can you run TB's on standard management and the same injectors?
I.e basically just replace then inlet system with individual TB's and use the standard TPS and original injectors, would this cause a massive problem?
i.e if the car ran no MAF, but lambda.
Just talking hypothetically here, on any car, not cossy or ford specific at all.
Old Mar 10, 2009 | 04:57 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yes, but if you told me the specifics of what car and what management setup it currently uses I could be more helpful.
Old Mar 10, 2009 | 05:03 PM
Ryan's Avatar
Ryan
ok ABF golf engine 2.0 16v running standard motronic management i believe.
Old Mar 10, 2009 | 05:07 PM
Chip's Avatar
Chip
Not one im familiar with, which motronic revision is it?
Is it on a resistance based TPS sender (beleive it or not some are just on/off!)
Does it have an airflow meter?
Whats your reason for wanting TB's in the first place
(If its cause you think they sound nice, that gets lost if you have to pipe them back into a single airflow meter)
Old Mar 10, 2009 | 05:09 PM
pani_k's Avatar
pani_k
PassionFORD Member
Sorry to hijack but what about on a blacktop 1.8 zetec then Chip? I've never seen on that still runs the Ford ECU on TBs...
Old Mar 10, 2009 | 05:14 PM
Chip's Avatar
Chip
Stu @ MSD would be the one to talk to about that particular engine I suspect mate, drop him a PM.
I see no reason why not though.
You can normally (on most management) delete the AFM by just unplugging it and then remapping the limp home table for AFM estimate based on TPS and RPM.
Bear in mind though, its likely to cost more than just using aftermarket management, but if you are in a race series that insisted on using the original ECU, it would be a good option.
Ive done it both via the limphome table method and via a shared plenum for the 4 TB's that fed through the standard AFM.
So essentially its doable on pretty much any engine, just dont expect it to work at its optimum without being mapped of course!
Old Mar 10, 2009 | 05:16 PM
Spiky's Avatar
Spiky
tight arse get a dta....lol
Old Mar 10, 2009 | 05:18 PM
Chip's Avatar
Chip
Or a decent ecu
Old Mar 10, 2009 | 05:21 PM
Ryan's Avatar
Ryan
no doesnt run a AFM, reason is mainly for looks, but mainly cursiousity.
reagrds version, not a bloody clue chipper
Old Mar 10, 2009 | 05:22 PM
Ryan's Avatar
Ryan
spiky dont want dta, as no one likes it
Old Mar 10, 2009 | 05:23 PM
Chip's Avatar
Chip
If it has a proper variable resistance TPS, it should be perfectly possible to do it.
Unplug the AFM and see how it drives as a first port of call to investigate it.
Old Mar 10, 2009 | 05:25 PM
Chip's Avatar
Chip
To be fair, its very popular with N/A motorsport applications.
Old Mar 10, 2009 | 05:26 PM
Ryan's Avatar
Ryan
well the engine is going in my mk1 golf, so wont be running until for a while.
just lookin at my options really , dont really want to go the TB's and management route for so little gains, i.e like 20-30 HP, for the cost of over 1k, when a 20VT engine is that, so looking for cheap options to squeeze as much power out of the engine for as little cost as possible, so remove all restriction in inlet and exhaust if possible, i.e inlet, and cat etc etc etc
Old Mar 10, 2009 | 05:28 PM
Chip's Avatar
Chip
Just turbo it, N/A really does SUCK
Old Mar 10, 2009 | 05:31 PM
Spiky's Avatar
Spiky
my mapper likes dta so thats why i'm going there
i cant afford expensice ecu's
well i'll have a play on track chip crappy "N/A" car
Old Mar 10, 2009 | 05:34 PM
Chip's Avatar
Chip
Spikey, N/A is good enough for the welsh.
Old Mar 10, 2009 | 05:37 PM
pani_k's Avatar
pani_k
PassionFORD Member
I'm at a bit of a cross roads with my tuning. 1.8 blacktop zetec running pretty much Stage 2. 145bhp, 127 ft.lbs of torque. 3 options:
1) Carry on N/A tuning
2) Get a blower
3) Get something with bigger bollocks
I love the sound of it now on the high lift cams it really does sound fabulous! N/A though is fuck all torque which is annoying. Turbo is by far the best option for gains but going to be costly for me to implement although I do fancy a DIY installation but haven't the time or resources to do one. Would be a proper NOOB job as well but first time for everything and I like getting my hands dirty. At the moment though, I doubt I'll spend much more on my car. Will keep building no claims touch wood and own an RS of some description in a year or two if Jap hasn't totally gotten under my skin
Spiky's Avatar
Spiky
very true
Old Mar 10, 2009 | 05:52 PM
Ryan's Avatar
Ryan
chip, im not turboing this engine, this is going to be my "ring" engine.
i have another engine a 20VT 286bhp engine for the other stuff.
just want to get the car up and running and finished and the 16v engine is a drop in convertion. so that will do for now, power to weight with puts at about 200 per tonne.
Old Mar 11, 2009 | 09:41 AM
Chip's Avatar
Chip
By turbo it, I meant throw that piece of shite N/A rubbish in the bin. and fit a standard totally reliable 20VT motor for the ring.
Old Mar 11, 2009 | 09:51 AM
ECU Monitor Enthusiast
Originally Posted by Chip
Or a decent ecu
PMSL
Old Mar 11, 2009 | 10:04 AM
Rab's Avatar
Rab
Fucking superstar........
Originally Posted by Flux Capacitor.
PMSL
Simon, I REALLY don't think you're the man to be taking the piss out of other compaines ECU's mate
Old Mar 11, 2009 | 10:25 AM
Maybe not, but I am talking from experience... You are not
But then I have never claimed to be perfect...
Old Mar 11, 2009 | 10:27 AM
Rab's Avatar
Rab
I am talking from experience, the experience of reading MILLIONS of posts on here baying for your blood due to broken ECU's
Old Mar 11, 2009 | 10:31 AM
No, your just being a cunt
Old Mar 11, 2009 | 10:33 AM
Rab's Avatar
Rab
True
Old Mar 11, 2009 | 10:34 AM
Chip's Avatar
Chip
Being perfect is hard, but just treating other people with a little bit of basic respect when doing business with them isnt and would be a good step in the right direction at least Simon
Old Mar 11, 2009 | 10:39 AM
Chip,
Should have guessed you would have something to say...
I havent done business for at least 3 years now so keep recycling if it makes you happy.
And yes, you are quite correct in what you say
Old Mar 11, 2009 | 01:02 PM
Ryan's Avatar
Ryan
simon send me an ECU
picking up the engine from bridgend tomorrow
Old Mar 11, 2009 | 02:40 PM
Only if you learn that it will need mapping
WHen you said it crashed, I didnt know you meant it was your car
** This isnt a for sale post LOL
Old Mar 11, 2009 | 03:12 PM
Ryan's Avatar
Ryan
:Cry:
funny guy.
well obviously it will need mapping
let me know then, TB's would deffo be going on if so.
as those at no CAT is about 180 with a inlet cam change.
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Toe Knee
Aug 23, 2015 08:31 AM
Cameron
14
Aug 9, 2015 06:28 AM
Old ford
Jul 31, 2015 06:50 AM
