Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Fitting Cosworth Engine in MK1 Escort
Old Feb 1, 2009 | 10:32 PM
swoosh500's Avatar
swoosh500
Default Fitting Cosworth Engine in MK1 Escort
Hi All,
I am new to this forum stuff and require some info.
I have bought a sapphire 4x4 and am going to break this so i have the engine and ancils for transplanting into my MK1 escort.
The thing is what is the best way to go about this as there are so many different ways that people have done this.
Any info regarding sumps to use, 2wd cossie std or modifed or RS2000 or cut the crossmember etc.
Also what is the problem with the bulk head lip, does it require cutting back for the engine or will it go in without mods.
Any info on these transplants would be gratefully recieved.
Johnny....
Old Feb 1, 2009 | 11:54 PM
melspec1's Avatar
melspec1
Originally Posted by swoosh500
Hi All,
Johnny....
hello mate, im new to this site as well, but i have done over (4) mk1/2 escort cosworth conversion's? here is a quick crack down! from the start you need a very good shell? the other is how you what to do the conversion! as you can use the floor pan etc from the 4x4 cosworth, but to me thats alot of work.... to me the easy way is useing the shell the way it is, but there a lot of body mods needed? and there is alot of parts to buy to put the cosworth in... unless you a very handy man at the job! ive got to say there is no saving money on a escort conversion! so the shell will need seam welding some people dont, but to me its a must! depends on spec of engine, you can fit 5-link set up for bome prof performance, but again some people you use leaf springs and tramp bar's? the bulk head lip is a yes! you need to shave it back the width of the head and close to the bulk head flat-out, then weld it! gearbox tunnel, best off useing the one off the 4x4 cosworth? or use a grp4! the rad sround needs mods to fit std intercooler or you buy the conversion kit all in one, then its a easy kit to fit? worldcup x-member is needed, useing worldcup pinto mounts but you need a mod sump, dont piss on with a RS2000 sump! then there's your rear alxe, again depends on wot power you got, atlas is top right up to 490HP but that has to be a motorsport set up! you can use a english as my mate duzz with a LSD unit std shaft, that run's 340bhp till now still no problems! for brakes,suspension is all need to be upgrade'd dont use std crap... it dont work.... ive tryed.... if there is any thing else let me know.... hope this helps you!
Old Feb 2, 2009 | 06:51 AM
swoosh500's Avatar
swoosh500
Thanks for that,
The shell i have is real good, just crying out for something mad.
Have been picking up parts for a while now.
4x4 cossie, T5 box, 2wd sump and pickup/pump, 7" X pack rs alloys, bilstein struts, ap calipers etc.
The back axle is my worry as i want to keep the car looking standard, no big wing arches.
So the options as you say are atlas and 5 link or english with lsd and tramp bars.
The thing is will i be gutted after finishing it that i did not go down the arches and 15" wide alloy route with big money atlas instead of the standard look with maybe the narrow atlas or english on leaf springs.
Decisions, what to do.
Old Feb 2, 2009 | 01:44 PM
melspec1's Avatar
melspec1
Thanks for that,
hello mate again... the way you are saying it is the way i like it ? for me keeping the car looking stock, is the best thing! to me putting big arches on is a give away! but its your choice????????? but here is the real thing... i to was thinking of putting big arches on my mk2, but after building a mk1 escort with a stage3 set up and rolling on 7x13 superlites and 175/50/13 tyre's????????????? IT WAS FUN.... power slideing all over realy quick, pin back in your seat! its just a different car with ton's of power! now if you arch it and put on big wheels and tyres then you will get the power down to the wheel with little fun (depends on power).... but thats how i see it... every one has there own choice and how there want to drive the car!!!!! what you realy need to do is drive a mk1/2 escort with a cossie lump in to see wot you want? or ask other's on the site who have arche the cars, and see how there drive ... let me know how you get on...
Old Feb 2, 2009 | 05:44 PM
ricky's Avatar
ricky
Hi All,
Johnny....
hi
you dont need to fork out for world cup xmember just use your escort xmember just trim it a bit to clear the sump
then add strengthing plate to it then you can used 2wd sump and rs2000 engine mounts my mate has got the temp plate to do the xmember we have done 2mk2 and 2mk1 with cosworth in them
Old Feb 2, 2009 | 07:50 PM
graham c's Avatar
graham c
i used the rs2000 sump when i built mine even with bubble arches mine span in forth! so now am just getting my parts for a 4x4 mk1 got the saff ! just need mk1 any prob,s pm me thats wot most people do he he
Old Feb 2, 2009 | 09:27 PM
swoosh500's Avatar
swoosh500
Thanks guys for the info.
Think i am going to keep the standard arches but maybe go for the short 5 link boxes and see if i can pick up a baby atlas, depends if i can get 1 cheap enough.
Good luck with the 4x4 conversion, lots of welding for that 1.
My mate back home has done this and is running the granada cossie V6 with twin turbos through the 4x4, is always crackin the shell and is always welding her up as it is just to much for the shell, he uses this for autocross and it is something else to see and hear when out in the grass.
Old Feb 2, 2009 | 09:32 PM
swoosh500's Avatar
swoosh500
Hi Ricky,
Don't suppose you have any pic's of the crossmember cut and strengthend before you fitted it.
Old Feb 3, 2009 | 07:14 AM
ricky's Avatar
ricky
Hi Ricky,
no mate no pictures but i see if i can get my mate to take a snap of the xmember from under the car with engine fitted
Old Feb 3, 2009 | 12:29 PM
melspec1's Avatar
melspec1
Im pleased to here that you keeping the stock arche's, its going to look bizz? i hope it works out for mate, just remmber dont skimp on anything, if do you will have your problem,s and more money to pull out for! you ''MAY'' even have to repair the damage's so think about wot you want?
Old Feb 8, 2009 | 08:41 AM
yukspeed's Avatar
yukspeed
Swoosh, pm me I have pic. yuk@yukspeed.com
Old Feb 12, 2009 | 03:54 PM
Rob Virgo's Avatar
Rob Virgo
pics of build would be intresting
rob v
Old Feb 16, 2009 | 03:28 AM
swoosh500's Avatar
swoosh500
I will get pictures up once i get started, but looks as if this will be last on the list to do in my month off as the girlfriend called me over the weekend to say that the cold feed to the water tank at home burst in the loft on Friday night and flooded the house.
So the escort will yet again be talking a back seat now that i will have to sort the house, only finished decorating at christmas and was hoping to get a good hit on the cars when i got home in April.
There always seems to be something else to do when i get home.
Anyway will strip out the engine and box from the MK1 when home and if time strip what i need of the cossie 4x4 and sell the rest of the bits.
Bloody insurance company already coming the bag, she called to tell them the problem on Friday and was told they dont have a record of our policy and to call back on Monday, Scanned all doc's and payment receipt from the bank and emailed them it, as it was out of office hrs, Monday is the first they would do anything, Some 24hr help service that. Tossers.
Will be kickin up shit as soon as the office opens at 9am.
Old Apr 3, 2009 | 01:43 PM
evoguy's Avatar
evoguy
Hi,
I'm going the same route at the moment, MK1 Escort Cosworth Engine etc
maybe we can swap ideas problems & fixes etc. as its a first for me..!
Old Apr 3, 2009 | 02:32 PM
melspec1's Avatar
melspec1
Originally Posted by evoguy
Hi,
good luck...........
Old Apr 3, 2009 | 08:33 PM
graham c's Avatar
graham c
easy peassy mate
Old Apr 23, 2009 | 09:44 PM
ewanm3's Avatar
ewanm3
hi guys since you have done so many conversion you might be able to help me with mine i am trying to fit the cosworth brake set up to my fiesta cosworth any one help with that doing away with the abs just need to know how to wire up the pump and presure switch
Old Apr 24, 2009 | 07:34 PM
graham c's Avatar
graham c
i,ve not got that far on my mk1 4x4 yet but it just live and earth and then you need trigger wire from the ingnition ? i think ? ?
Old Apr 25, 2009 | 08:31 AM
87cos's Avatar
87cos
good luck with the build mate,better have deep pockets aswell.lol.heres a link to our build,
http://www.scottisholdskoolescorts.c...php?f=8&t=7570
Old Jun 1, 2009 | 08:57 AM
swoosh500's Avatar
swoosh500
Hi guys, managed to remove the crossflow engine, box, prop and exhaust system when home, so not much done but a start anyway.
Maybe next trip home i will get to strip the sapphire of the engine and bits needed for the MK 1,
Will post some pic's so far when i get back home from this trip at work.
Old Jun 1, 2009 | 06:06 PM
fostersice's Avatar
fostersice
im getting mine ready for cosworth so lots of pics and parts hope this helps
https://passionford.com/forum/old-sk...0-rebuild.html
Old Jun 1, 2009 | 06:14 PM
fostersice's Avatar
fostersice
bulk head mod
rs500 intercooler
atles with 5 links and large diff tunnel
with axel brace
hope these help
link to all pictures
http://s142.photobucket.com/albums/r...000/?start=all
Old Jun 5, 2009 | 08:07 PM
LEONMEX's Avatar
LEONMEX
sorry to hijack the thread,looking at doing a cossie conversion. Can you use a rs2000 sump or is it just as easy to modify the x-member & use 2wd sump. Also does it matter 2wd or 4wd engine loom?? Will be looking at keeping standard x-member & rs 2000 mounts
Old Jun 5, 2009 | 09:28 PM
katluke's Avatar
katluke
Hi All,
Johnny....
There is plenty of info on the Turbosport forum regarding fitting cossie lumps into mk 1/2 Escorts.Lots of the members on there have converted there cars to cossie power. hth http://www.turbosport.co.uk/index.php
Old Jun 7, 2009 | 01:41 PM
mk1escoz4x4's Avatar
mk1escoz4x4
Hi All,
Johnny....
here are some pics of mine its been converted to 4x4
https://passionford.com/forum/album.php?albumid=156
Old Jun 7, 2009 | 02:44 PM
pig's Avatar
pig
i would be inclinded not to use the standard crossmember and mounts m8.even medium power cossie turbo will rip the mounts to bits imo.if you do wrap the o's mount in heat wrap as that will melt it and it will brake even quicker.you can use the rs2000 sump if you get the oil return put in to the sump for the turbo oil pipe.smithy still uses all standard stuff in his mk1 before he stripped it fo r the rebuild
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
