puma problems help needed
Old Jan 14, 2009 | 04:07 PM
rs tingle's Avatar
rs tingle
Default puma problems help needed
hi there im haveing problems with a 1.7 puma when i go 2 pull away the car seems really slugisan not want to pull away then after bout 10 secs i get a load off power and then it goes but it doesnt do it all the time i have changed the clutch and slave cylinder i thought it might be the clutch but its still doing it any advice welcome thanks
Old Jan 14, 2009 | 04:42 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
erm no i wont be clutch!!! clutch slip and the revs would rise but youd accelerate slowly (or not at all depending how bad it is )
Sounds like youve got a sensor fault. could be HEGO, MAF, Throttle position etc etc.
Try disconnecting battery for 15 minutes to clear any codes as sometimes that can resolve it for a one off intermittant fault thats playing fun with the ECU.
If youve got a 99 onwards puma with digital dash then put your dash into diagnostic mode and read the fault codes to find out which sensor is playing up.
Old Jan 14, 2009 | 04:43 PM
Psycho Warren
Carbon Crazy
Old Jan 14, 2009 | 04:44 PM
Psycho Warren
Carbon Crazy
AGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH the double post scourge has returned
Old Jan 14, 2009 | 06:14 PM
Dal_'s Avatar
Dal_
Throttle position sensor would be my guess.
On the bottom of the air intake / throttle body to the inlet manifold:
Old Jan 14, 2009 | 06:28 PM
rs tingle's Avatar
rs tingle
thanks peeps
Old Jan 15, 2009 | 01:43 PM
rs tingle's Avatar
rs tingle
Default heeeeeeeeeeeeelp
now the car has stated to decide an surge. an now for me to pull off i have to floor it just to get anywhere would this still be the throttle position sensor
Old Jan 22, 2009 | 08:12 PM
rs tingle's Avatar
rs tingle
anyone got a lighter an a petrol can coz thats what i feel like doin right now wid this puma now its decideing to make a big bang when ya put ya foot on the throttle into the airbox heeeeeeeeeeeeeeeeeeeeeeeeeeeeeeelp meeeeeeeeeeeeee
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Ben26
Aug 11, 2015 04:19 PM
col93saphcos
Aug 7, 2015 03:21 PM
