unlocking deadlocks
Old Dec 5, 2008 | 02:04 PM
xr4x4rs's Avatar
xr4x4rs
Default unlocking deadlocks
rite heres a strange request lol
i have mondeo st24 on a v plate, my central locking packed up just over a month ago now and no ones seems to know whats going on, i have power at all motors etc but nothing else
ive changed control boxes, reprogrammed the key fobs the lot
so i changed my dirvers door motor and ive magaed to get central locking to that door lol, so changed the passenger side now and that works
so i have a wierd feeling that all the door lock motors died at the sme time some how
but one of the rear doors is dead locked, the other is fine for some strange reason, so how do i go about disengaging the deadlock on this door
as electronically locked, but if the motor is fukt, what else can i do, without damaging the door, dont mind the doorcard, but i carnt afford to do any damage to my door
i just want this problem fixed, so ill be buying 2 rear motors next week aswell
Old Dec 5, 2008 | 02:09 PM
Nash_mr2's Avatar
Nash_mr2
Only tool for the job...
Old Dec 5, 2008 | 02:21 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
on my old escort to engage the deadlocks you had to use the key in the drivers door.
with the door unlocked, twist the key as if to unlock it, then turn it the other way to lock it.
so unlock the deadlocks witht he door locked, turn the key to lock it, then turn other way to unlock it.
if you get me lol
Old Dec 5, 2008 | 02:27 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
is there power going to the motor ?? maybe there isn't and its shut waiting for it
Old Dec 5, 2008 | 02:34 PM
xr4x4rs's Avatar
xr4x4rs
there is power going to all motors
but the only way i got the central locking on the 2 front doors was to replace both motors
only the back doors to do, but 1 is deadlocked and isnt picking up a signal from the fronts to tell it to open i think
or its fried the circuit boards inside the motors, which explains why i had to replaece the front 2 for them to work as they were dead, wouldnt even work off the key, but the 2 fronts do now
Old Dec 5, 2008 | 02:37 PM
dojj's Avatar
dojj
Resident Wrestling Legend
look at how the front motors work, then figure out where the motors will be for the rears and put a hole in the door card at the same sort of spot
if you can alreayd open one of the rear doors then use that as a basis for diagnosing what's wrong
Old Dec 5, 2008 | 02:38 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
wouldn't be the first time then i have heard of a door being chopped off or the door car wrecked to get it un done
Old Dec 5, 2008 | 02:40 PM
Smit's Avatar
Smit
The 60ft Launch King
Try unlocking from the passenger side. Mine sometimes only 'deadlocks' from the passenger side not drivers.... Worth a shot.
Old Dec 5, 2008 | 02:44 PM
xr4x4rs's Avatar
xr4x4rs
ive tried smit
now thinking about, i think the door thats deadlocked could be causing all my problems lol
ill take a look into it tomorrow if the weather stays dry, see if i can get the card out and take alook inside the door
but even with the other door thats not deadlocked, the motor still wont work on that
Old Dec 5, 2008 | 02:55 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
one other thing mate, try shoving somthing down between the window and the door and try knocking the motor,i have had my fair share of problems with car locks over the years and somtimes a bit of luck and perserverance helps
Daniel Howard
17
Sep 26, 2015 12:39 AM
Flatlinedan
Sep 18, 2015 12:41 PM
tankybaby66
Aug 9, 2015 07:13 AM
The Virgin Mary
Feb 28, 2005 09:53 PM
