Hid headlights?
Old Nov 29, 2008 | 02:44 PM
WongRS's Avatar
WongRS
Default Hid headlights?
Anyone used them on a Saff?
If so, what kits did you use and how where they to fit, do they look good?
i really fancy some for mine, as my lights are pretty shocking and i think they can look good, any opinions?
Old Nov 29, 2008 | 03:36 PM
I think there was a post on pf a few months ago about them. Im sure people were saying that when it came to mot time they had to take the bulbs out for them to pass. Im pretty sure people said they were easy to do,im sure people were cutting holes in the back of the headlight covers to fit the kits.
Old Nov 29, 2008 | 03:38 PM
twoblacklines's Avatar
twoblacklines
i have a focus but fitting is the same, i just threw my headlight covers in a bin lol, not had any problems for 9 months
Old Nov 29, 2008 | 05:32 PM
mechanic28's Avatar
mechanic28
Be warned most of these have no pattern!plod and testers will not be happy lol!
Old Nov 29, 2008 | 06:47 PM
cossie604's Avatar
cossie604
I mot'd a Alfa last month that had one of these cheapo HID kits on....beam image was just shown as a big blob of light on my tester Fail.
Old Nov 29, 2008 | 08:19 PM
My tester has tested various cars with aftermarket hid lights, around 50% pass rate, so long as a correct beam of suitable colour is produced they can't fail it.
Headlight levellers and light washers are not part of the mot, my car has to go to mot soon without it's rear roll bar, but again it's a pass, as not tested, I'm having made some EN16T roll bars that clear the poly diff mounts.
Poly diff mount = AWSOME SPECTACULAR BEST THING EVER.
Old Nov 29, 2008 | 11:42 PM
pacwest's Avatar
pacwest
Puller of the Wrench
You could use the new "mad eyes" from the US that uses the Chevy Silverado lights.
Many different HID options since there are aftermarket lights for the Silverado.
http://forum.merkurclub.com/forum/vi...ight=silverado
Old Nov 30, 2008 | 12:17 AM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Its deffo a fail if the anti roll bar is missing mate
and every car i have had in with after matket hid lights have failed due to not having a pattern as said its just a blob of light
but saying that when i had them in mine they made a big differance ane were well worth the upgrade
just a shame the kit i got the bulbs fucked up within a few dys and the ebay seller fucked off when i put a claim in
hth
Old Nov 30, 2008 | 08:01 AM
STUCOS's Avatar
STUCOS
If hid lights are fitted to a vehicle they must have headlight washers and be self leveling,check the manual tabs
cheeRS stu
Old Nov 30, 2008 | 08:02 AM
iansoutham's Avatar
iansoutham
OCD Victim
hth
But are the ones you get in for MOT test using the cheap kits?
I have 3 cars with them on, and they all pass the MOT, including one yesterday. All have brilliant beam patterns as well.
Mind you, mine are all the 3-figure bi-xenon ones, not the Ł60 off ebay jobs.
Old Nov 30, 2008 | 09:48 AM
STUCOS, the point I was making is although in LAW the car has to have levellers etc, the mot is not testing it to see if it is legal, only to see if it passes a mot which is nothing to do with the law, you can pass a mot, then go an get nicked for something on the car which is illegal, washers and levllers are not even MENTIONED in the manual.
Matt Baxter,
I DID read the manual on friday, the rear arb does not even get a mention, so is not even a testable item, therefore it cannot be failed as it doesn't have to pass anything, the ONLY proviso vosa came out with, al though ecently and VERY confused seems to be where a roll bar is fitted, it must work, and be attached securely, not having one cannot be a fail, according to vosa, but as you may know what they are like it could be different next month.
Old Nov 30, 2008 | 09:51 AM
Matt Baxter
Back in black!
cheeRS stu
Iirc only if they are fitted from the factory and dont need the above for the mot
Old Nov 30, 2008 | 10:03 AM
Matt Baxter
Back in black!
yeah they were the cheaper type kits
Matt Baxter,
cant rember word for word but if a vehicle is known to be fitted as standard it must be fitted at time of test
the reason i remember was when I went for a refresher one on the other blokes asked about removing the antiroll bar as he was well into his off roading
but how can the tester know as things like the clio some have one some dont so cant really be enforced
Old Nov 30, 2008 | 05:00 PM
cossie604's Avatar
cossie604
Matt I think I'd just pass and advise....end of the day they spend most of the refresher courses telling us 'if unsure, pass and advise, and always cover your arse' Think i'm due refresher course number two early next year....it's a day off work at least
Old Nov 30, 2008 | 05:56 PM
STUCOS's Avatar
STUCOS
Suspension parts,ie arb if removed must have all sigh=ns of mounting points removed also,also fitting hid lights to a vehicle,if not a retro fit by a dealer means vehicle is no longer type aproved,
tabs i know what your saying,mot law and construction and use law are 2 diffrent things,ie whats mot able might still be illigal on the road ie no number plates
cheeRS stu
Old Nov 30, 2008 | 06:07 PM
cossie604's Avatar
cossie604
Not sure on the type approval bit as we only check the lenses, right?
ARB missing shouldnt be a fail if its a delibriate modification iirc.
Old Nov 30, 2008 | 06:08 PM
cossie604's Avatar
cossie604
Its a bit like the dodgy windscreen thingy...fail fo rmore than 10mm in the A zone but pass if you kick the screen out
Old Nov 30, 2008 | 06:51 PM
Matt Baxter
Back in black!
oh yeah pass and advise and remember there are no grey areas
I told a bloke that a few years back with an old polo.
The next thing i knew he was out there kicking the fuck out of the screen
i was pissinng me self but had to give him the vt20
very handy (its an online mot manual) http://www.motuk.co.uk/
missing antiroll bar is 2.4 g
and nothing about hid at all so as long as they give the right pattern cant see a reason to fail the MOT
Old Nov 30, 2008 | 07:48 PM
STUCOS's Avatar
STUCOS
Do you check all lenses are e marked ? as i have seen some gsh lighs on cars which arnt e marked
cheeRS stu
Old Nov 30, 2008 | 08:47 PM
cossie604's Avatar
cossie604
I'll be honest I very rarely bother to look...if its got a decent and correct pattern of the right colour and height, and is secure then through it goes
Just looked on that online manual...agree very handy, they should update it though....its nearly four years old!
Old Nov 30, 2008 | 08:49 PM
cossie604's Avatar
cossie604
Makes sense really as we aint allowed to remove anything during the test to prove/disprove it.
Old Nov 30, 2008 | 09:32 PM
iansoutham's Avatar
iansoutham
OCD Victim
Although there is an interesting bit in there under the brakes that states that a vehicle with either more than 1 axle engaged permanently or with an LSD should not be tested on rollers. I knew about the 4-wheel drive (mine does not get tested @ all in that respect) but was not aware of the LSD example.
Old Nov 30, 2008 | 10:03 PM
cossie604's Avatar
cossie604
tbh I thought every tester knew about that....it's the only excuse we've got for taking anything interesting (many funky motors have LSD's fitted) out for a test drive with the old deaccelerometer My new place is all tarty, its a automated test lane and the deaccelerometer (is that spelt right, im unsure?) is all digital.....miss my old tapperly
Old Dec 1, 2008 | 05:51 PM
iansoutham's Avatar
iansoutham
OCD Victim
I'm not a tester though
Old Dec 1, 2008 | 06:03 PM
xr4x4rs's Avatar
xr4x4rs
mine passed the mot no problem with them fitted
just plug and play kit so no wiring and you can always revert back to normallights if you wish, when i got rid of the sierra i put them on my mondeo st 24 lol
one of the best things ive bought and will be having them on the escos aswell
Old Dec 1, 2008 | 06:43 PM
WongRS's Avatar
WongRS
Which kits are good then?
Thanks for all the replies people!
Old Dec 1, 2008 | 06:53 PM
cossie604's Avatar
cossie604
Get out of this thread then you mear mortal
Old Dec 2, 2008 | 12:17 PM
iansoutham's Avatar
iansoutham
OCD Victim
Old Dec 2, 2008 | 11:06 PM
cosy trav's Avatar
cosy trav
I got a set off my mate who does them for my 4x4 saph , where the high/low beam ones aswell and makes it safer for when your blasting down dark country lanes , easy to fit too .
http://www.facebook.com/pages/Xenons...15757713?ref=s
He has supplied them for this beastie too .
Old Dec 3, 2008 | 07:24 AM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Nope, If its not there it cant be tested, therefore its an advisory. In the MOT testers mag the other week, there was an Astra with a front tie bar missing The tester phoned VOSA and asked where the failure would come under and they said pass it and issue an advisory I will try and copy the article and post it up. But that is VOSA's own magazine!
Old Dec 4, 2008 | 11:22 AM
Matt Baxter
Back in black!
sorry mate but it is a fail have a look in the testers manual 2.4 g2
Old Dec 4, 2008 | 06:35 PM
cossie604's Avatar
cossie604
Yep I'll back up Matt on this as I looked into it this week at work (I was REALLY bored lol).....very direct in its wording as well, and thats me checking via the F5 button.
Old Dec 4, 2008 | 06:54 PM
iansoutham's Avatar
iansoutham
OCD Victim
Is this about roll bars or lamps now?
Old Dec 4, 2008 | 07:53 PM
cossie604's Avatar
cossie604
Roll bar's.....you gone and passed the course yet and joined us testers? We have a funny handshake as well y'know
Old Dec 4, 2008 | 08:53 PM
iansoutham's Avatar
iansoutham
OCD Victim
I'm not allowed to do the course, I'm still too sane. Got told to come back when the Prozac kicks in
Old Dec 4, 2008 | 09:36 PM
155lee's Avatar
155lee
do you get some kind of kit to make morrete headlights brighter?i have them on my sapph and they are dire!
Old Dec 4, 2008 | 10:47 PM
xr4x4rs's Avatar
xr4x4rs
hid kit mate
mine were awsome with teh morrettes
and the question on rollbars, i never had a roll bar on my sierra had compression struts, does that mean it shouldnt of passed
Old Dec 5, 2008 | 06:47 AM
Matt Baxter
Back in black!
Can't see a problem with comp struts as they do the same sort of job as the front roll bar.
Old Dec 5, 2008 | 12:43 PM
cossie604's Avatar
cossie604
^^ Well they dont really do they, yes they keep the road wheel's position in the arch correct like the standard sierra front roll bar does but comp struts dont control body roll like a arb would. If you can fail any car for having no roll bar then you should be able in theory to fail a car with comp struts fitted in their place.
Old Dec 5, 2008 | 02:56 PM
dojj's Avatar
dojj
Resident Wrestling Legend
i got my hid kit from this fella charlie put me onto on another forum
i didn't notice a huge difference to be honest when i fitted them, but for the money they were brighter yes
but the other day when i was out in one of the works vans i really did notice the difference "normal" headlights made compared to the hid's
the ones i got were 2 pin versions though, so the sierra's have 3 pins sow ould need to have the flashier versions for the dip/dim thing yes?
