cold start problems
Old Nov 1, 2008 | 07:52 PM
webby80's Avatar
webby80
Default cold start problems
any ideas guys my car is a right pig to start when cold she just spins over but wont fire have to pump the pedal to get it to catch , once warm she starts fine first turn of the key
Old Nov 1, 2008 | 09:33 PM
dangerousbrian's Avatar
dangerousbrian
ive had the same prob...i used to get sum1 to press the "flap" down on the metering head while i turned the key..when on my own i wedged it open with a bit fag box or summat till i could get it set up
Old Nov 2, 2008 | 10:24 AM
marky_g's Avatar
marky_g
Fleet Manager
cold start injector unplugged?
multy plugs on the wrong way round?
mine was always a pig to start cos it kept comin off
Old Nov 2, 2008 | 10:47 AM
anvini's Avatar
anvini
Check the following:
- Auxiliary air valve device, (rear from inlet manifold)
- Cold start injector and all injectors (maybe are faulty)
- Termo-time switch sensor (inlet manifold down cold start injector)
Also will be ok check and clean pluggs.
CheeRs
Old Nov 3, 2008 | 06:09 PM
webby80's Avatar
webby80
wonder if its the cold start valve it did the same with the old engine and when i changed engine i used my old inlet with all the injectors and sensors , still got the one from the new engine somewhere in the workshop so might try changing it
Old Nov 3, 2008 | 06:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If the above doesnt sort it then could be a simple as your idle mixture, if pushing the flap down makes it start like dangerousbrian's then it's either the idle mixture or cold start injector.
Old Nov 3, 2008 | 06:35 PM
kevnoize's Avatar
kevnoize
RsTurbo crewe ina corna.
will it make a difference with the blue cold start plug off?
as mine seems to run better with it off @ the mo......
Old Nov 3, 2008 | 06:40 PM
webby80's Avatar
webby80
not tried that
cant see its the mixture as the car was only set up on the rollers 2 weeks ago
Old Nov 3, 2008 | 07:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Probably cold start then mate.
Old Nov 4, 2008 | 04:08 PM
addiction's Avatar
addiction
just disconnect the cold start valve and see how it starts then!!!
Old Nov 4, 2008 | 11:32 PM
denbo's Avatar
denbo
My S2 has started to do the same i have tryed disconnecting the cold start valve but it makes it more harder to start
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
