Zetec building crank wont turn
Skint Passionford User
Did a dummy run of assembling the bottom end of my ZVH today, and the crank is really tight (ie need to swing on it with a long bar to get it to turn) with the main caps just nipped up, new std size bearings and all new bolts etc.
Is it more likely that the crank is bent or that the caps are from another block? The caps weren't bolted up when I picked the block up and the crank was wrapped up in a curtain
Ta if anyone can help
Checked all the clearances with plastiguage and they were all sound, so put it together with a load of graphogen and its perfect now! No tightness anywhere, no grinding noises and the end float is within tolerances so its all good
I must have left some grit or other shite under the shells or summat?
Roll on getting the head done and I might hear it running before crimbo
Cheers for the replies lads
JoeyBoyden
Jan 4, 2024 02:36 PM
James Porter
Oct 28, 2015 12:17 PM
The Underdog
29
Sep 7, 2015 09:49 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
