pinto engine problem?
Old Oct 23, 2008 | 09:17 AM
xr_triplow_turbo's Avatar
xr_triplow_turbo
Smile pinto engine problem?
i have just bought a mk1 sierra that was going to be scrapped, so that i can take some bits off for my xr4i, and to use as a recreational drift car, to proove that old fords go sideways best, sad i know! but factual.
It is a 1.6 pinto, and was hoping to use that engine until i can drift properly, then upgrade the engine to poss v6 or something, but the engine lacks power, and when left to idle will cut out. On occasions when driving the car if u dont keep the revs up, she cuts out and then is very difficult to start, but after a few goes she will run.
i have changed leads, plugs, dizzy cap, rotor arm, and have checked carbs diagphram, and cleaned it with carb cleaner.
Any ideas, will be much appreciated.
cheeRS
Old Oct 23, 2008 | 09:23 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
cheeRS
fuel shut of valve on the side of the carb my xr2 had dat problem its got one wire going to it and should be live when the car is running
Old Oct 23, 2008 | 09:34 AM
xr_triplow_turbo
hey i remembered to put it on never checked it, thanks ill try that.
Old Oct 23, 2008 | 11:53 AM
Kverna's Avatar
Kverna
Virgin-popper
Try adjusting the valves. My mate had the exact same prob, only he couldn't go uphill without a whole lot of effort.
Old Oct 23, 2008 | 12:00 PM
Dave Henshall's Avatar
Dave Henshall
vac leak, if you can get some one to hold the revs really steady... spray carb cleaner around the intake manifold, (not down the carb) and it will rev faster if there is a leak and it draws it in....
Old Oct 23, 2008 | 12:34 PM
Check your ignition timing and the co level, if a VV carb pull back the carb slide and see if it goes back slowly or snaps back, if it snaps back the diaphragm is split, cheap but very common problem.
Old Oct 24, 2008 | 04:08 PM
xr_triplow_turbo
ok i have tried diaphragm and thats fine, the fuel shut off valve in carb, will check for vac leak, i think head gasket is gone though so will do compression test tomoz, thanks for your help will update.
big_Rad
Sep 15, 2017 09:36 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
