cvh head
Old Oct 16, 2008 | 08:32 PM
orion88's Avatar
orion88
Default cvh head
right all being offered an xr2 head to replace my tired rs turbo head.can i swop these or doi need another rs head or are all cvhsthe same?need to know asap cheers all
Old Oct 17, 2008 | 11:59 AM
Smartdj.'s Avatar
Smartdj.
i think i red on here there the same but cant be sure..maybe depends on mfi efi
Old Oct 17, 2008 | 12:07 PM
orion88's Avatar
orion88
been looking onto it they are different but i wanna know if the loss of compression will allow the car to run and well?
mines mfi and im after the lean burn head with hopes of it running the rs very well.just wanna know if it bolts on and all will run well
Old Oct 17, 2008 | 12:24 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
duz work mate.i used a xrs head on my s2 and it made 186bhp.u cant use efi tho
Old Oct 17, 2008 | 12:45 PM
orion88's Avatar
orion88
lovely so the lean burn head will work on the rstseries2 engine with no problems at all?
Old Oct 17, 2008 | 12:55 PM
rickbartlett
G911 TTA
yep did on mine mate
Old Oct 17, 2008 | 01:08 PM
orion88's Avatar
orion88
sound mate cheers for that
Old Oct 17, 2008 | 05:04 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
NO NO NO, the lean burn head will raise the compression, so not good for an RS turbo.
Old Oct 17, 2008 | 07:33 PM
rickbartlett
G911 TTA
most s2 heads have bin skimmed to death anyway mate.mine worked perfect at 15psi
Old Oct 18, 2008 | 06:28 PM
Karl's Avatar
Karl
Norris Motorsport
You CANNOT use the lean burn 1.6cvh head on a std RS turbo bottom end. This is because the std RS turbo has a 2mm piston protrusion at TDC above the deck height. The head gasket is only 1.5mm thick, and hence if you fit the lean burn head to a std RS turbo bottom end, the pistons will make heavy contact with the combustion chamber "beak" resulting in horrendous noise and bent con-rods!!
A second issue is the high compression ratio this results in, but that is insignificant in comparison to the 1st problem!!!!!
Old Oct 18, 2008 | 06:40 PM
boothy's Avatar
boothy
listen to karl he knows his stuff
Old Oct 20, 2008 | 03:24 PM
orion88's Avatar
orion88
cheers carl exactly what i was lookin for cheers
Old Oct 22, 2008 | 05:01 PM
JesseT's Avatar
JesseT
The XR has a head identical to the RS turbo and not the lean burn variant as fitted to carburettor models from -86.
Old Mar 24, 2016 | 04:55 PM
Rsturbo519's Avatar
Rsturbo519
Hi Karl looking for a little help here. Going to double check everything but getting 1.5 mm taken off me pistons crowns to give me a CR off 8.6:1. My head has been skimmed a lot and turned out at 48.5cc. Do you think I will have enough squish clearance? I have enough piston to valve clearance I think ( around 2mm ) just worried about my head hitting pistons. Valves are only about 1mm deeper than the face off the head as been skimmed that much.
Old Mar 24, 2016 | 07:16 PM
haz87's Avatar
haz87
This is an 8yr old thread and Karl is fairly inactive on here now.
Better to start a new topic in the RST room - plenty of knowledgable folk about to answer.
Old Mar 24, 2016 | 07:42 PM
Rsturbo519's Avatar
Rsturbo519
Ok thanks haz
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
