Gotech Ignition amp
Old Aug 3, 2008 | 05:56 PM
johnenright150rst's Avatar
johnenright150rst
Default Gotech Ignition amp
i have a erst runnin gotech management, which i have to say jamie at jamsport did a brillant job fitting. but now i have realised the ignition amp must have been getting hot which is a bosch 6 pin amp, i orderd 1 up and they sent a 7 pin when i put it on the car it ran shit on idle, then i orderd a propper bosch 1 and again that caused it to run shit on idle even tho bosch say they are the same!? when i put the old 1 bach on it runs fine, but i would like to replace it as i has some meltin marks on it. i did realise that when it was put on the paste wasnt used, so i asume thats why it got hot! does any 1 have any ideas why this might be happening? your views are much appreciated.
Old Aug 3, 2008 | 06:44 PM
haz87's Avatar
haz87
So have you actually got hold of a new 6 pin amp? or are both the new ones 7 pin?
Old Aug 3, 2008 | 08:14 PM
johnenright150rst
Both are 7 pin and bosch say that the 7 pin superseeds the 6 pin!
Old Aug 3, 2008 | 08:26 PM
JesseT's Avatar
JesseT
What's the type (number) of the amplifier? Don't know much of the 6-pin ones, but there is at least 20 different versions of the 7-pin amplifier that can not be mixed. Some control dwell, some are multichannel, some read reluctance sensors, etc...
Old Aug 6, 2008 | 09:31 PM
johnenright150rst
i gave the numer 2 a local motor factor and they mached it. thinkin they might have got it wrong i gave the number to bosch and the one they sent me has a matching number across the middle but with the addition of 1 extra pin!? mabey i need to move some pins?
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
