T5 Gearbox
Old Aug 2, 2008 | 08:43 PM
Dearo's Avatar
Dearo
Default T5 Gearbox
The guy who installed my gearbox says he forgot to mention that a considerable amount of oil spilled out when he installed it. (Lucky I haven't driven the car yet).
Could this be the reason the gearbox chatters on idle (disappears when clutch is pressed in).
How many litres of gearbox oil does the box hold ???
Dearo
Old Aug 3, 2008 | 01:12 AM
LHD220Turbo's Avatar
LHD220Turbo
t5 holds 2.5 or 2.6l (cant remember which) of atf dexron 3 or some use 75/90 gear oil
as for the chattering as you describe, that wouldnt be caused by low oil IMO
it could be the input shaft bearing, easy to change but box out i'm afraid
Old Aug 3, 2008 | 07:30 AM
cossie604's Avatar
cossie604
Why didnt said guy top up your oil for you??
Old Aug 3, 2008 | 08:14 AM
Dearo's Avatar
Dearo
No Idea mate, Muppet comes to mind !!
Old Aug 3, 2008 | 08:21 AM
Dearo's Avatar
Dearo
Yeah we've discussed that it could be the input shaft bearing before eh mate !! Was just hoping it could be something stupid like the low oil level before having to rip it all apart.
I've now got a replacement box, so I may have a go at fixing it myself (God help me).
Old Aug 3, 2008 | 10:49 AM
mechanic28's Avatar
mechanic28
2wd gearbox are a peice of piss fella!!!
Old Aug 3, 2008 | 11:48 AM
Dearo's Avatar
Dearo
The gearbox manual states you need a special tool to fit the replacement bearing, is this correct or just a load of Ford Bo##ocks ??
Old Aug 3, 2008 | 06:39 PM
mechanic28's Avatar
mechanic28
i think its just a puller!?or am i thinking of 5th gear??i cant remember fella!sure someone will know maybe post up in gd
Old Oct 13, 2008 | 02:07 PM
Dearo's Avatar
Dearo
Just a quick update...
I finally got the chance to jack the car up and sort the gearbox out today. Work and family commitments has meant that I've never really had the chance to plod on with the project.
The reason the gearbox was chattering it's nuts off was purely down to the lack of oil !!! Thank god it was nothing mechanical.
Oh well, on to the next stage and fit a replacement ABS pump.
Old Oct 13, 2008 | 03:05 PM
The 5th gear can be so tight on the shaft that it breaks trying to remove it, sometimes even with heat and a puller.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
