New Engine what can a safely expect to push BHP wise?
Old Jun 23, 2008 | 02:55 PM
JamesS2RS's Avatar
JamesS2RS
Default New Engine what can a safely expect to push BHP wise?
Engine Spec
1.6 CVH
81mm Wossner Forge Pistons
Steel H section Rods
7.5.1 Compression Ratio
Stage 3 Head with large valves
CVH35 kent Cam
ARP Studed Block
ARP Main Studs
MLS Cometic head gasket
T34 Ahmed spec Turbo
Cosworth P8 Management
Everything is brand new and rebuilt
Im hoping around 240-250bhp
Jim
Old Jun 23, 2008 | 03:11 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
you will get that 240 without to much issue and higher is you want to run the boost,
its pretty similar spec to mine, are you running the P8 or dizzy or coil pack ?
what you running intercooler wise.
mines runs :
steel cvh, ported head, cam, anti pump lifters, 4x4 turbo, P8, coil pack, air-injectors, aquamist, anti-lag, NOS
grs twin pass, etc
Old Jun 23, 2008 | 03:14 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
No reason why you shouldn't get over 300 with a spec like that
Old Jun 23, 2008 | 03:20 PM
Turbocabbie
Top Cab !!
Hello Tony.. did you ever decide what you were going to do with your RST ? was it broken, I can recall you being disheartened but im not sure if you still have it ? ??
JamesS2RS's Avatar
JamesS2RS
mines runs :
grs twin pass, etc
I will be running dizzy to start off with then changing it to coil pack.
I dont just run an intercooler i have made a custom charge cooler & intercooler setup
Jim
Old Jun 23, 2008 | 03:22 PM
stuart collins's Avatar
stuart collins
should be over 300bhp
Old Jun 23, 2008 | 03:23 PM
Turbocabbie
Top Cab !!
got any pictures of the custom set up ?
what made you run this instead of a normal inter cooler ?
what you running inlet wise ?
Old Jun 23, 2008 | 03:33 PM
JamesS2RS's Avatar
JamesS2RS
Bit hard to see and this was on my old engine.
But its a S1 Pace charge cooler with a S2 Radtec Cooler!
The only reason i done it was to be diffrent the highest inlet temps my collins monitor has shown was about 32c flat out on a hot day so it works very well. The engine at the time was Pushing 298bhp and 360ftlb
As for inlet im not sure what to run yet.
Jim
Tony Turbo's Avatar
Tony Turbo
Hiya,
Yeah I still have most of it. Sitting in a garage somewhere gathering dust. Poxy thing lol
Old Jun 23, 2008 | 03:36 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
^^^Pile of shit^^^
Old Jun 23, 2008 | 03:39 PM
JamesS2RS's Avatar
JamesS2RS
Originally Posted by Tony Turbo
Hiya,
Want to sell me your inlet manifold lol
Turbocabbie
Top Cab !!
Hiya,
get it out again, its been long enough, have a mid life crises and have some fun
looved your car, it was what started me of
If im doomed to a life with a bloody escort im taking you with me
Old Jun 23, 2008 | 03:48 PM
Tony Turbo's Avatar
Tony Turbo
Sorry, but chance are I would sell the engine and ECU complete so someone can just drop the lot into their car without any fuss. I'll bear you in mind though
Thanks for the kind words. I might do something with it one day, it's just such a waste of money
I saw it a few weeks ago though and I did miss it..... a bit.
Old Jun 23, 2008 | 06:13 PM
babscossie's Avatar
babscossie
Engine Spec
1.6 CVH
CVH35 kent Cam
ARP Studed Block
ARP Main Studs
Jim
20 BHP if your lucky batman!!!!!!
Old Jun 23, 2008 | 07:01 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
As long as the head flows the air, it should definately be knocking on for 270-280bhp (assuming large enough fuel injectors/fuel flow and reasonable air charge temps)...
SmudgerByName
52
Jul 28, 2016 06:14 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
knight19770
Aug 4, 2015 12:36 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
