Stage 3 chips....
Old Jun 18, 2008 | 11:26 AM
Rolls's Avatar
Rolls
Default Stage 3 chips....
AS title, what do you guys have?
Was thinking MSD, and then take the car along to powers again for a set-up!
Old Jun 18, 2008 | 11:36 AM
R5FORD's Avatar
R5FORD
msd mate.. if i were you id make the journey upto stus and have it live mapped
Old Jun 18, 2008 | 11:41 AM
Stu @ M Developments's Avatar
PassionFords Creator
Good plan IMO, i will do the software and then Matt can get her up and running nicely with 29psi spike and 23 held.
Old Jun 18, 2008 | 11:47 AM
AlexD's Avatar
AlexD
Post Miester !
Talking
I have Stu's Closed Loop Stage 3 Chip on my Escos.. Its the business !!
Mine peaks at 27psi holds 24psi..... I reckon without the ported head i would still see 340+ BHP.
I fitted and setup up mine myself, set the boost, a couple of runs
up and down the ring road, job done !
Took it for a rr run, perfect...!
Old Jun 18, 2008 | 12:33 PM
MSD would not work in my car, neither would EA.
Old Jun 18, 2008 | 12:35 PM
GUZZLER's Avatar
GUZZLER
what do you mean by they would not work?
Old Jun 18, 2008 | 12:58 PM
Eh?
Old Jun 18, 2008 | 01:11 PM
Rolls's Avatar
Rolls
lol - Stu - how much am I looking for a chip? - Boggo spec engine, but with a 500 style intercooler..
Cheers!
Edit to add, its got an uprated fuel pump (well, will have when i get around to fitting the bloody thing) - obviously need to get the 3 bar, and greens too...
Old Jun 18, 2008 | 01:18 PM
Porkie's Avatar
Porkie
MSD
Old Jun 18, 2008 | 01:21 PM
Cheers!
Ł140 for the chip pal. Cant help with other items at the moment though sadly. Simon @ Woodford probably can though.
Old Jun 18, 2008 | 01:29 PM
Rolls's Avatar
Rolls
Ok - will give you a bell at some point before the weekend then! Cheers
Old Jun 18, 2008 | 01:50 PM
GUZZLER's Avatar
GUZZLER
Originally Posted by Porkie
MSD
who?
Old Jun 19, 2008 | 06:23 AM
The supplied chip and it's replacement had a collosal hole about 1800-2500rpm, which was so bad you physically could not drive through it in 4th or 5th gear.
I contacted MSD, and they gave a refund, including postage without complaint or delay, once it had been seen to be the chip/s.
Everything was set up as per instructions to the letter, merely swapping with another chip eliminated 100% the problem.
I would point out I had faultless service from MSD, and lots of advice help to try to get this problem sorted, but unfortunately to no avail.
For service alone I still use MSD for parts when needed, but have now decided to go aftermarket ecu, as Emerald rolling road is 500 metres away, so makes a lot of sense for me.
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
