last cossie left overs to go, cheap and offers please mustgo
Prices edited, open to sensible offers
GGR Gp A dump valve £100 posted
4x803s and £100 posted SOLD
set of std blue injectors
3bar map sensor,SOLD
set of white sapphire electric mirrors good working order inc loom £??
set of boost hoses red £SOLD
set of blue boost hoses
L6ECU bracket £5 + P+p
2wd TCAs with poly bushes inside and out SOLD
set of TCA / ARB poly bushes £cheap
2wd and 4x4 braided oil hoses ££10 ea?
alloy steering wheel drop bracket £50posted
alloy header tank £60 small dent in L/H side
twin ignition amp bracket anodised black £35posted
ignition amp and mounting bracket SOLD
twin ignition amp loom? £50posted
2wd Throttle body and Pf01 TPS and ISCV £SOLD
7.5"rear beam with pair of arms £50
std 2wd cams and pulleys £30
std 3spoke steering wheel £20?? + post
XS power alloy rad brand new unused not fitted £160
rubber spring assisters for towing or?£10 a pair. fit std cossie springs (3x sets available)
set of4x 7x17" Toora alloys, high power chrome finish, kerbed rims on 2x £160
I need the space and cash to continue my project
please note blue boost hose turbo-cooler was cut to fit 4x4 cooler perfectly on my 2wd, I must make this clear
Also red hose was cut by previous owner to accept cone type filter in the end, still works great
These are £35 pounds a set ONLY, NOT £130.
I will get a size sbd16v but they are std cooler dia (hook shaped one) whatever that is- 63mm? and T34 so will get sizes for you.
RSCOSTALOT- I will PM you as soon as poss
borboyous
Aug 22, 2015 11:17 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
