what would a 650 hp 2wd saph be worth ?
Originally Posted by Tiff
it doesnt just depend on the engine....it is everything else aswell.
You won't get what you spent on it back anyhow. Look for some rich kid and bring him for a spin in it! friend of mine here got 12k Euro(about 8k stg) for his 400bhp saff recently. He even fitted new glass, doors, lights, lenses just before he sold it. reckon it was standing him close to 30k all in.
i would pull the pin long before i got to 30k how long did he own it ?
Just ask Yum, he still cant find a box that doesn't break everytime he gives it death !
Originally Posted by col cos1
im no been funny but my car has cost me close to 30k now inc buying car all parts and labour,private plate etc and its no where near 650bhp
i cant see why it would take to much to achieve 600 hp anyway proper head like euans but big valve job, and a gt35 or similar, modded eec iv inlet maybe 4 - 5 k or am i way of. although i suppose gearbox and diff will be leaving the building
Headwork alone for 600BHP must be redicilous amounts of money
EDIT: Spelling
Would say you would be looking at around 20k for a 600 bhp build, depending if you went for uprated liners, crank...
I know the head on my new engine was built to flow 600 and would be close to 3k.
Last i heard all custom bits were done just wiring to refit then fire it up and mibi tweak the map thats parlty done for running in. Hope alan should have it done for me getting home in 3 weeks. Will be a year on 3rd of jan its been off the road
Was actualy talking to Alan the other day about fitting the same T4 as Euan has before it gets fully mapped but need to sort out a gearbox before then as could be looking at around 500bhp.
I dont know about 2wd Saphs but in the escos world you might aswell not bother if you think 30K will get you a usable 650Hp Car
10K for a cheap escos
you could blow 10K on transmition that probebly wouldnt even cope under heavey abuse
5K on Brakes
5K on Turbo, inlet manifold, exhaust manifold and ECU
then the engine
5K on Brakes
then the engine
just found the link check this out for a cheap head. i cant see why standard crank and rods wouldnt be ok with 8k rev limiter, gt35 1500 quid, inlet manifold from mike Ł400 and map it on l8 Ł500. i reckon 5k would do it just. heres link anyway
http://www.cncheads.co.uk/ford_cosworth_bv.html
http://www.cncheads.co.uk/ford_cosworth_sv.html
this is even cheaper and should be good for 600 so they say
Originally Posted by glancy2081
1250 + vat not really cheap
alot less than most have said it would be though. and thats for 800 hp potential head, 600 hp potential head is 1095 and i can get the vat back
r and b inlet 700 hp capability Ł380
i think martin at reyland does a 600 hp turbo for Ł1000 on ebay then Ł500 for external wastegate.
would a standard crank and rods cope with it at no higher than 8k revs ?
i think martin at reyland does a 600 hp turbo for Ł1000 on ebay then Ł500 for external wastegate.would a standard crank and rods cope with it at no higher than 8k revs ?
then you have cams 16 new valves valve springs etc
engines only done 2k miles and of them 800 running in.
The first one is my spec head the second is the same as Euans i think both done by CNC , but as Glancy said the time you buy uprated cams,valves, springs.. it all adds up but as you say still a good price for the porting work.
Both standard rods and crank should be good for 600 bhp with a sensible rev limit if in good condition. Kev Sharp was running over 600 with a hit of gas without problems.
ive got bd14s bronze guides, uprated springs, i think all i need is porting. and my t4 is only 2.5 k old got receipt from universal turbos Ł1300 so that gotta be worth Ł700 to Ł800 id of thought. im just pondering on the maths to see if id be tempted to do it. btw engine is new block, pistons crank on first grind, new high pressure pump, injectors will do the job.
any knowledgable advice much appreciated
I was meaning if you go for the big valve head , would think you would need to go up from 14's to get the best from it.
Depending on how far you want to go it might be worth looking at getting your T4 modded like the one AVA have just developed on Euans car seems to make good power early and hold it to 8k.
I think to build a 650hp engine and have it reliable you will need nikasel liners aswell
Ł1600+
head and cams that is ready to go for 650hp Ł2000
Inlet manifold and Injectors Sweedish style Ł1000
Turbo, wastegate, exhaust manifold Ł2500
Custom made Exhaust System to flow 650hp Ł1100
where do you stop
to be honest if you was to use your current engine with a bigger ported head and just strap a GT35 on it and have it mapped on L8 i dont think you will see 650HP and it will probebly Surge its tits off ohh and push a rod through the side of the block
if you want a 650hp engine you have to have a 650hp engine built in the first place look at some of the most powerfull engines about! Yum, Ade, Martin reyland, AndrewG Focus, All hand built for the job not just boltd together
tell you somthing if you can do it i will be right behind you
Ł1600+head and cams that is ready to go for 650hp Ł2000
where do you stop
scoooby slayer
not slating you mate but i think you need to look into it properly.you cant just slap a 650 bhp engine together and expect it a.to pull the power and b. be anywhere near reliable for more than a thousand miles
its big bucks for that sort of power and the chassis and "extras"to cope
What Ben said about all the things you forgot about
. Also, I see you soon realised that 650bhp was going to cost shit-loads more than you anticipated, so you lowered your sites to 600
Originally Posted by Bullett
scoooby slayer
