what would a 650 hp 2wd saph be worth ?
#41
What Ben said about all the things you forgot about . Also, I see you soon realised that 650bhp was going to cost shit-loads more than you anticipated, so you lowered your sites to 600 .
600 more realistic i guess and liners are a no no i defo wouldnt touch the bottom end and its got 7 litre big wing already
#42
Originally Posted by Gatecrasher
I think to build a 650hp engine and have it reliable you will need nikasel liners aswell £1600+
head and cams that is ready to go for 650hp £2000
Inlet manifold and Injectors Sweedish style £1000
Turbo, wastegate, exhaust manifold £2500
Custom made Exhaust System to flow 650hp £1100
where do you stop
to be honest if you was to use your current engine with a bigger ported head and just strap a GT35 on it and have it mapped on L8 i dont think you will see 650HP and it will probebly Surge its tits off ohh and push a rod through the side of the block if you want a 650hp engine you have to have a 650hp engine built in the first place look at some of the most powerfull engines about! Yum, Ade, Martin reyland, AndrewG Focus, All hand built for the job not just boltd together
tell you somthing if you can do it i will be right behind you
where do you stop
and surge can be mapped out so i aint bothered bout that itl still make the power where i want it
anyone know what bd14s are good up to ?
#43
if youve got a sound bottom end then that will take 600 hp but if youve had a grind on crank thats a no no.you will need a good std std crank atleast and have it checked and rebalanced.youl need a bd16 inlet cam and youll have to check your valve springs are strong enough for the job and the platforms are right and porting wise 26mm inlet and 25mm exhaust.get a pj elbow for the external wastegate a gt35/40 turbo swedish plenum 1000cc injectors easy 600hp and even if you have to sort a new crnk you could do al this for 5k easy that includes getting it mapped
#44
Caraholic
IMO 26mm is not big enough for 600bhp, I run bigger than that for 500bhp .
Agree that you would need a very good quality valve train for the boost levels / revs .
Also, the 2wd manifold is about on it's absolute limit at 600bhp, and a standard 3" exhaust would be strangling the car.
#45
Did anyone mention the 9" diff your going to need another 3k !
Oh and a gearbox
TBH a genuine 550hp will piss just about anything if you get the car setup well enough.
No point having all that power if it just leaves black lines when you open it up doing 70mph
Best of luck with it Carl
Oh and a gearbox
#46
iv done a few engines at that spec and the lowest weve achieved is 572 and the most is 608 so you can do it but yeah in an ideal world you would do everything better my race car engine is only 583bhp but its well responsive and its got 562 lb/ft and that cost me 20k but its got the best of the best.cheers danny@abcmotorsport
#48
Caraholic
#50
Caraholic
mike the last one wich to be fair was the lower hp one at 572 was done last friday and the others were done on tommys as joes werent ready .danny@abcmotorsport
#51
Originally Posted by jhw
Just have 400bhp and a sorted suspension.
However You don't need liners or uprated rods or crank for 600-650 just good standard ones.
James
James
#54
Caraholic
James
James
#55
i dont think id be loosing much either tbh as long as i dont pop it as a 600 hp cossie must be worth 12k - 13k surely even if it is a saph.
brakes are done, suspension is pukker. if drivetrain will stike it aint really that much to do not in £ terms anyway.
#56
and my engine was done at tommys and then finished on joes cos of leaking wastegate but the spec is cgi block mountune liners wrc pistons and rods lightwieght new crank cnc cosworth bigvavle head from new cast solid lifters mountune cams proper inconel manifold gt35/42 turbo rs200 wastegate mountune roller barrel inlet f1 injectors f88 ecu and special loom dry sump and so on etc but im like you mike i want response and lots of tourque where you need it other wise i could lose the roller barrels and put a swedish 8 injector large throttle body and have 650 bhp no probs but on the track my spec will bequicker so it depends what you want and how long you want it to last. danny@abcmotorsport
#57
Was certainly not a silly HP top speed machine with the usual parking dents and stone chips on it, not many people want these...
#58
James
James
#59
#60
well yes mike of course the figures will be realistic as just said i know when harvey helped joe calibrate and i havny used joes dyno until then iv used tommys wich actually reads higher than joes.so whats your point?
#61
http://cgi.ebay.co.uk/Garrett-GT3582...QQcmdZViewItem
just found this on ebay and can use identical rear housing to my t4 so 5 bolt wastegate housing and internal wastegate will fit straight on for £900.
can anyone tell me from the flow charts on the listings if this turbo would genuinely flow 600 hp and at what boost it would need to be at to do it ?
thanks for info so far people
#62
Cake lover!
James
James
I am not being funny but everyone who has built a car to this spec have all said the same thing. You cannot cut any corners with anything as it will show up straight away. If you want a genuine 600bhp thats also reliable then its going to cost money and lots of it!
#64
Uprated engine mounts
T4 turbo with mar-am 247 shaft
AH fabrications intercooler
Radtec alloy rad
Air injector
Wasted spark conversion
Closed loop fueling
Brand new engine loom
Touring car spec head,
BD16/14 cams,
Blue verniers,
isky double valve springs,
WRC 4 layer head gasket
New 200 block,
ST escos inlet manifold
6 wrc long studs 4 std head bolts,
7:2-1 compression
Mahle pistons
ARP rod bolts
Fully balanced and lightened bottom end (not too light)
4 paddle clutch
Big wing sump
Siemens 1000cc injectors
L8 ecu with ANTI-LAG and LAUNCH CONTROL
Oil cooler
Usual chrome tanks under the bonnet
Aeromotive ae1000 fuel pump with -8 to fuel rail and -6 return
Aeromotive fuel regulator
Aeromotive high flow fuel filter
Glebe straight cut T5 gearbox with non std ratios (yes its noisy) it does what its supposed to. 70MPH 1ST GEAR 100MPH 2ND GEAR 175MPH IN 5TH
Quaife atb rear diff
R and B rear shims
AP 6 pot 330mm front brakes
Large rear brakes
Fully polybushed
AVO coilover suspension
Compomotive mo's 17" 5 spokes in anthracite
3 ford racing gauges
Elliot 8k tacho (fitted where std one was)
Roughly this was the spec of my 3 door, It was around 530 bhp, the t4 was flat out. All this needed was a bigger turbo for more power, Then i think it would make around 600 ish bhp, I dont think it would of made anymore though.
So how siimilar is your spec and see what else you need, may give you an idea.
(ive just took this from the sale add so some things wont matter obviously )
Radtec alloy rad
Air injector
Closed loop fueling
BD16/14 cams,
Blue verniers,
New 200 block,
7:2-1 compression
Mahle pistons
ARP rod bolts
4 paddle clutch
Big wing sump
Oil cooler
R and B rear shims
Large rear brakes
Fully polybushed
#65
all id need from that list is fuel pump, 16 inlet cam, head porting, inlet manifold ive got 865 cc injectors but stu said when he mapped there good for around 600 hp.
#66
TBH I can't see the point in having 600hp when you know the gearbox or diff is going to shit itself IF you launch it.
If your not willing to spend out on a good gearbox and diff then stick to 500 MAX as thats more than enough for standard ish running gear.
Its doing things like this that cause people to get fucked off with their cars and break them up, it will let you down at the most awkward time.
Obviously doing it right is going to cost a fortune but IMO either do it that way or don't bother.
Personally if its just 190mph you want then add some nitrous, a proper setup isn't cheap but its a LOT cheaper than a 650hp engine, its not on constant so the car won't fall apart too quickly.
Just look at Rod Tarrys car for a example of what nitrous can give you
#67
Pump, £300
Reg £140
Filter £
Lines £150
Plus all the areoquip you can put nearly 1k on for all that and poss the mod to your fuel rail or a new one.
Its always the little things that all add up and supprise you, Aswell as doing the big things right
#68
Caraholic
#69
Add another 120bhp and it won't feel good in the bends.
Gearbox might stick it for a while.
Diff will die.
What do you see in doing 190 at brunters may I ask? I very much doubt you will though if you just throw on a gt35, etc.
See what your tuners views are on this.
And soon, 190 probably won't be with the big boys anymore anyway
Diff will die.
#70
Happily retired
Ive been offered lots more for my engine than 12k chum, a genuine 770bhp costs mega bucks, there are over 43k parts alone in my old girl. My Block is costing more than the guy thinks it costs to get 650bhp. .
#71
Diff will die.
Diff will die.
and who mentions just throwing on a gt35 with correct cams, headporting, inlet, fuel and turbo what else is there ? i would dare chance the bottom end im running 2.2 bar boost now without any issues so id dare run 2.2 bar with a bigger turbo.
#72
Originally Posted by col cos1
im no been funny but my car has cost me close to 30k now inc buying car all parts and labour,private plate etc and its no where near 650bhp
i cant see why it would take to much to achieve 600 hp anyway proper head like euans but big valve job, and a gt35 or similar, modded eec iv inlet maybe 4 - 5 k or am i way of. although i suppose gearbox and diff will be leaving the building
Headwork alone for 600BHP must be redicilous amounts of money
EDIT: Spelling
Mark
#73
Mark
#74
Super Moderator
#75
Super Moderator
EDIT: Spelling
Mark
#76
EDIT: Spelling
Mark
Mark
#78
ok mark but that isn't what you said makes sense now
obviously a 600 bhp head can also make 400 bhp but it wouldn't be the best power band for 400 bhp.
10 out of 10 for digging yourself back out of that hole
Mark
#79
Not welcome...
Diff will die.
Diff will die.
#80
Diff will die.
Diff will die.
