what would a 650 hp 2wd saph be worth ?
#121
yes mate weve run loads at around this power on just a good std crank and rods just checked and balanced with f1 conrod bolts or arp.i know you dont want to split your engine but i wouldnt peronaly use your ground crank id use one thats still std but thats no big deal to change anyhow.the head work and turbo is the biggest expense
#122
Originally Posted by jhw
It would be alot easier to buy an engine already tuned by a professional, sell your old engine and it would probably cost you less.
Buttttt
If I was you, i would spend it on a proper kick ass chassis like wrc rear end 8 pots etc, and get a real buzz by going round corners, FAST!
James
Buttttt
James
car is fast enough in the bends for me just want more power captain
an already built engine would cost what 15k i seriously cant see it would be cheaper
that looks as though it was a bargain had standard crank, rods and block though
#123
thanks for your advice mate its reasuring to hear someone has done it so it can work.
have u used a 3 inch scorpion or mongoose exhaust at this power level ?
are solid lifters only needed if you rev above 8k or have i got that wrong ?
#124
i had a 3 door that had 2 group a fuel pumps on but that was done when i bought it. is it just case of plumbing second one in next to original pump and both t pieced in to original line ? all i know is both pumps were sat together under the 3 door. just thinking would be cheaper that way maybe
#125
I'll say it again, if all you want is 190 @ Brunters then fit some nitrous.
You could easily give it another 150hp of nitrous or more which judging on how well Euans goes without any would see you at 190mph if not very close too.
#127
just found this on the net i think its a t4 capable of 600 hp flow rate of 75lb/min
http://www.turboelements.com/index.p...d&productId=41
#128
Caraholic
#129
It has to be said, is it REALLY worth pushing a 2.0 16v engine that hard? .... don't get me wrong, as a long time cossie lover nothing else feels like 500YB horses, but you reach the point of diminishing returns.....
#130
http://www.turboelements.com/index.p...d&productId=29
got my maths wrong on calculating air flow to hp.
this one seems the same as whats for sale on ebay except not ball bearing or water cooled and should be good for around 650 hp.
#132
Even that has almost 700bhp capability - just times the airflow by 10 and add 30bhp .
#134
has anyone ever run 600 hp on standard rods, crank and 200 block ?
all input is much appreciated
#136
Why dont you buy the same turbo as mine?
pretty sure it could run a genuine 600 bhp is wrung out
do you know roughly how much it would cost to convert my current rs500 t4 to 600 hp spec ?
i understand the spec will be secret but does he change any housings or is it just internal work with porting and different comp wheel ?
#137
ive been advised standard crank is really needed at that power level
although my last saph was around 340 hp and that was on .75 grind and did 14k of proper hard caining without any bottom end issues.
so would possibly be ok if i dare to try
#138
My turbo is 1400 plus VAT but not sure how much or if your can be converted?
you could give Vince at CR turbos a call and he will sort you out
#139
if i go ahead il have to give him a call and see what he could do. makes sense i suppose as it will bolt straight on are you still running internal gate ?
#140
The turbo is running 2.2 bar.
Boost could be incresed to 2.5/2.6 bar and would see closer to 600 bhp.
Yeah its still an internal wastegate.
Just tell him you want a turbo like Euans and he will know what you mean
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
dojj
28
11-09-2015 10:00 PM
