stroking
Old Oct 17, 2007 | 01:09 PM
boost mad's Avatar
boost mad
Default stroking
another question envolving the bottom end..
what would you say the pros and cons are to having a long stroke crank?
just toying with some ideas for the new engine !
Old Oct 17, 2007 | 02:16 PM
SafeChav's Avatar
SafeChav
You want advice on stroking?
LOL AFPMSL
From here on you will refered to as "stroker"
Old Oct 17, 2007 | 03:32 PM
boost mad's Avatar
boost mad
LOL AFPMSL
dont you start !
the saph is off the road now so i can start saving for some bits and pieces..... long stroking is just an idea i had
Old Oct 17, 2007 | 04:47 PM
Mark Shead's Avatar
Mark Shead
There are many benafits to it and I cant see any down sides if done correctly, But with all the best bits ie Pistons/Rods/Crank allow nearly £3300+vat, If you shopped around you could get it cheaper but debate'able if it would be as strong,
but it may be strong enough it could be enough for what you are looking for.
Mark
Old Oct 17, 2007 | 06:18 PM
AustenW's Avatar
AustenW
The downside is a reduced rod ratio, reduction in amout of revs engine can make safely etc.
The upside might be more BHP and torque but with spikey torque it just breaks gearboxes and looses traction etc
It will also move the power band further down the rev range and make the turbo spool up quicker
From a personal point of view I have chosen to de-stroke my engine from a 2.1 to a 1.8 as I'd rather have the power band further up the rev range and less torque to make the car more drivable
You cant beat cc's for power though
IMHO
Old Oct 18, 2007 | 01:48 PM
SafeChav's Avatar
SafeChav
LOL AFPMSL
dont you start !
Sorry i forgot you're getting on in your life now, you sound married off already
Old Oct 18, 2007 | 02:48 PM
boost mad's Avatar
boost mad
thats right, ive got a job
not married yet tho
Old Oct 18, 2007 | 05:24 PM
scoooby slayer's Avatar
scoooby slayer
that firm in norway are de stroking a cossie lump to 1700 and hoping for 1000 bhp
Old Oct 18, 2007 | 06:50 PM
boost mad's Avatar
boost mad
Old Nov 11, 2007 | 01:01 AM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Mark
What sort of power have you achived from these conversions mark?
I remember seeing a 2.4L stroker engine Years ago in a Ford mag, any reason why these never took off?
scoooby slayer i assume you ment 2700cc, any more info on that?
this has the potential to be a good topic on bigger cc stroker engines
Old Nov 11, 2007 | 01:06 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Rods was making 700+ on the dyno before it had a failure, on a stroked motor.
Higher piston speeds around TDC allow more ignition timing to be dialled in is another pro that ive not seen mentioned in this thread yet.
Old Nov 11, 2007 | 01:53 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
what are the power limits for a non-linered 200 block?
Old Nov 11, 2007 | 08:35 AM
Chip's Avatar
Chip
No one knows a definitive answer to that AFAIK, especially as there are different ways to make power that strain the block in different ways.
Old Nov 11, 2007 | 02:40 PM
Gatecrasher
Not welcome...
From what i have seen tuners say that anything over 600hp you should have liners for somthing like rods 700+ engine it must have custom liners
to have a Block long studded, with custom liners would be about £2000 and to Quote mark
so for all the bits mentioned is about £3900
Doesnt sound a lot when you look at it like that
Old Nov 11, 2007 | 02:53 PM
RWD_cossie_wil
Thing is, at those power levels, is it really worth pushing a 2.0 engine that hard, when you can pick up a crate LS1 V8 for about 4k with a gearbox? ..... IMHO once you start spending stupid money on a block like that, the drivabillity and life of the engine is a serious offset against the expendature......
Old Nov 11, 2007 | 03:14 PM
Gatecrasher
Not welcome...
you say that Wil but any decent tuner will ask you 10K for a 500HP engine so for under £6000 for a 700hp bottom end its very tempting dont you think?
Its like you said anyone can go and buy a V8 for 4K ready to rock but wheres the fun in that
and as far as reliablity, its not like your running round on full boost all the time, if the Gatebill mob are doing it
Old Nov 11, 2007 | 04:11 PM
RWD_cossie_wil
but you get to the point where its just not nice to drive anymore, even a T4 car isn't very nice to use all the time is it?
Old Nov 11, 2007 | 09:00 PM
Gatecrasher
Not welcome...
yeah i male you right, but then saying that i went in MikeR car last week and that has a T4 and was well responcive was just pull off but once crusing the lag was allmost nonexistent, but saying that we wasnt hanging about
Getting back to the stroker engine more cc's will make the car more responive low down thi wont it?
Old Nov 12, 2007 | 10:12 AM
Chip's Avatar
Chip
More CC makes the engine generate more torque when off boost, and also bring it on boost sooner.
IainRS1700T
Sep 25, 2015 06:44 AM
Bailes1992
Sep 3, 2015 02:17 PM
JamesH
Sep 2, 2015 10:02 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
vroooom ptssssh
12
Apr 27, 2006 01:36 PM
