Fuel pressure regulator
Old Nov 11, 2007 | 02:56 PM
spudmurphy's Avatar
spudmurphy
Default Fuel pressure regulator
I could be in the running for thick question of the day award, but which side of the fuel rail does the fuel pressure regulator go on?
Inlet or outlet?
Ta much,
Spud
Old Nov 12, 2007 | 05:05 AM
stevecossy's Avatar
stevecossy
Ill go easy on ya bud lol, It goes on the return side or outlet.
Old Nov 12, 2007 | 09:38 AM
NUTS RuS's Avatar
NUTS RuS
As above, regulate the return feed to the tank, so everything before it is under full pressure
Old Nov 12, 2007 | 10:13 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The way the fuel pressure regulator works, is to restrict the flow after it, causing a buildup of pressure between it and the pump, so therefore the rail needs to be between it and the pump, so AFTER the rail, like mentioned above.
Old Nov 12, 2007 | 11:11 AM
spudmurphy's Avatar
spudmurphy
Nice one everyone
Was having a slow day yesterday Thanks for the responses, fuel lines are all plumbed in now.
Thanks again,
Spud
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
