engine builders help required
Old Jul 10, 2007 | 07:24 PM
juffer's Avatar
juffer
Default engine builders help required
I had bettom end knocking so i removed the crank and sure enough the bearings and crank no good. I had the crank reground and they said at the engerneers it is a 1.8 cvh crank,They supplied the bearings to fit my crank but don't fit the rods. Thats where the problems started. I can't get bearings to fit my crank and rods.
I believe to have a 1.9 bored out 1.6 cvh rst block
1.8 cvh crank
mahle pistons
I cant identify the rods with a name such as ford ect.The rods have studs fixed in with a nut that holds the cap on not like standard with a bolt. They are covered in numbers but some are ground out. They are:
22269z2jgsbmlp (on one side)
88218122 w2168???????? (ground out on other side)
The pisons also have these numbers on them if this helps: r101 b2/61
I need to identify these as i cant get parts. Any help would be great as i have a potental scrap engine. any engine buildes on here got any ideas.
Old Jul 10, 2007 | 07:28 PM
dave green's Avatar
dave green
When the grank is reground they supply the bearings to suit surely.
Dave
Old Jul 10, 2007 | 07:34 PM
juffer's Avatar
juffer
they sent the bearings for a 1.8 but the securing key thats on the bearing is on the wrong side for the rods and also a different thickiness. they sent the bearings to acomodate the regrind but are thinner than the ones i took out.
Old Jul 10, 2007 | 08:32 PM
craigos's Avatar
craigos
you must have the \1.9 tall block?speak to speailized engines they will sort you out
Old Jul 10, 2007 | 08:33 PM
craigos's Avatar
craigos
or even specialized engines sorry im thick
Old Jul 10, 2007 | 08:43 PM
juffer's Avatar
juffer
hi mate its not the tall block as its got 1.6 on it also the oil dipstick is in the correct place
Old Jul 10, 2007 | 08:49 PM
craigos's Avatar
craigos
thats one hell of a bore out?would the tall block 1s not do maybe worth a call,they arnt 1.6 rods are they
Old Jul 10, 2007 | 09:00 PM
juffer's Avatar
juffer
i spoke to the builders today and they said the 1.6 big end is 2.5mm smaller than the 1.8 so there is no way it can be have you ever heard of COUNTY i think its the bearing company that made the old bearings but cant find anything on the net.
Old Jul 10, 2007 | 09:51 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Power engineering do the 1.6 overbore and stroked crank conversion and it takes it out to just over 1.8 but they call it a 1.9 and branded it as system2 for some reason.
Vulcan engineering on the Uxbridge road in Hanwell also do these conversions and were infact supplying PE for while
185 Uxbridge Road, London, W7 3TH.
Tel: 0208 579 3202 / Fax: 0208 579 7390
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
borboyous
Aug 22, 2015 11:17 AM
mrice0107
Aug 21, 2015 07:55 PM
yawiejon
15
Aug 9, 2015 06:36 PM
