ka rattle
Old May 6, 2007 | 07:20 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
Default ka rattle
my girlfriends ford ka has a rattle coming from the front left wheel! it only does it when she drives it up a hill or if you pull away from the lights a bit quick.so its doing it when the weight comes off the front! iv changed the drop-link bar on that side but its still doing it.
any idears please?
Old May 7, 2007 | 12:38 PM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
id almost guarentee that the anti-rattle clip is missing from the pads mate, take wheel off and check that. If it is, they are a few quid from Ford. Cheers
Old May 8, 2007 | 06:31 AM
rs graham's Avatar
rs graham
thanks for the help buts it not this?
Old May 8, 2007 | 09:26 AM
RodgeRS_Turbo
my girlfriend has a Ka, was doing the exact same thing up hills in a low gear or pulling away to quick. It was down to the Anti-rattle clip missing. sorry cant help further.
Old May 8, 2007 | 01:35 PM
D4nny8oy's Avatar
D4nny8oy
Fixing the bloody car...
When you say "rattle", do you mean more of a "knock"? Because it sounds like maybe a bottom ball-joint knocking due to wear.
I've had two cases, one Fiat Panda, one Ulysses, and both had a knock from the front drivers-side when over rough ground and turning right (due to the weight lifting off the suspension). Both cars were only 2 years old, and both sounded like worn drop-links until we checked the bottom ball-joint on the wishbone.
Hope this helps.
Old May 9, 2007 | 09:23 AM
rs graham's Avatar
rs graham
yeah this is a rattle or even a creeking sound?not a knock! but its doing it when the weight is lifting like you say,so im willing to try anything...
Old May 9, 2007 | 07:17 PM
lukes1's Avatar
lukes1
common knocks are front centre anti-roll- bar bushes and front lower arm rear bushes. take off your wheel and look at the lower suspension arm. there are 2 bushes in the sub frame, look to see if they are perished or split. as for the anti roll bar bushes visually check to see if the inner part of the bus looks a rusty colour, or get under and give the roll bar a good tug to check for movement.
if these items havent been replaced before, they deffinately will soon! SO COMMON!!!
Old May 9, 2007 | 09:23 PM
rs graham's Avatar
rs graham
cheers mate.its done 45k and lives on the isle of wight were the roads are crap so checking this out tomorrow.
Fudgey
Sep 17, 2015 01:06 PM
Bailes1992
Sep 3, 2015 02:17 PM
Roosie
Aug 13, 2015 07:40 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
oriont
Mar 2, 2005 06:32 PM
