Anyone tell me how to put this end cap on my hub? (pic)
Replacing front wheel bearings on a Sapphire Cosworth 4x4.
Built the hub back up but it's the end cap that goes into the hub that I can't seem to push back in. Tried a punch but the metal is so fragile that it just marks and I have no bearing press. Any ideas? Thanks
Use a flat piece of metal resting, laid on, on edge of seal and tap all around lightly but continuously for a few years, takes about two mins that's all but just tap hard enough to move it about 1mm at a time.
It works perfect everytime just a little slow.
Had the same problem a little while ago,ended up turning a piece of steel the right diameter and tapped in easily.BTW the dust shields are a twat to get back in too!!! Shame you don't live 350 miles nearer you could have borrowed my tool
I've ruined one cap already lol. I can't remember the cap being as tight as it is on this sierra, my last one literally fell out, should it be this much of a pain the arse to put back in?
It's maybe cause they've never been in done in 16 years lol
Can you tell me if this looks right lads?
Managed to get it in using the 2 old races on top of each other but I hope I put it in the right way round, the rubber seal sits proud of where the hole for the ABS sensor is, is that okay? Cheers
In your first picture the seal is the WRONG WAY UP, just imagine that you need the flat edge to tap onto, I lay a flat piece of bar on so bar of metal is HORIZONTAL, if you like so it could lay across seal, just rest on edge and tap.
Seal flat must face outwards.
Car is nearly back together now, so hopefully I've done it right! Thanks for all your help on this thread people
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
track.focus'd
Aug 12, 2015 05:53 PM
