Dump valve problem
Old Jan 25, 2007 | 08:07 AM
orion_rst's Avatar
orion_rst
Time to play The Game HHH
Default Dump valve problem
I've got a problem with my dump valve on my RS Turbo S2. At first the dump valve sounds perfect but then once the engine warms up no sound at all. All I hear is the light screamy noise of the actuator. I've got Forge 6-bolt twin-piston type dump valve.
I don't know what the problem could be. I checked the springs and they seem working fine. The dump valve opens and closes normally when I checked it. What I've installed recently and don't know but might affect it in someway is the stage 3 T3 turbo and a Blitz dual-solenoid boost controller. Anyone can help pls? Thanks
Old Jan 25, 2007 | 08:23 AM
zippyobrien's Avatar
zippyobrien
perhaps the heat is affecting the piston in some respec, or the booost is being cut back when the engine heats up, ????/
why not remove it and plug the whole, have chatter for a change,
Old Jan 25, 2007 | 12:08 PM
badboy rs's Avatar
badboy rs
dump valves can be headaches at times, i used to have a forge 1 and when the car got hot it did the same,i found out that it was lettin boost out, i changed it with a baily one and it got sorted
Old Jan 25, 2007 | 01:45 PM
orion_rst's Avatar
orion_rst
Thanks for the reply. That's what I was afraid of, having to buy a new dump valve! It's a pitty cause it used to sound pretty good
So what do you suggest? Bailey's dv26 or dv36?
Old Jan 25, 2007 | 02:40 PM
badboy rs's Avatar
badboy rs
i had bailys dv26, or if you gonna get a different make, make sure it's a twin piston type as only this type works properly on rsts.
Old Jan 26, 2007 | 07:07 PM
Moose's Avatar
Moose
chatter, it sounds ace...........do it
Old Jan 27, 2007 | 02:47 PM
lewis_lisa's Avatar
lewis_lisa
ive got bailey twin piston sounds pretty good but im taking it out as i fancy a bit of chatter
try it m8 dv plugs are lot cheaper than a new dv
Old Jan 31, 2007 | 08:16 AM
orion_rst's Avatar
orion_rst
I soted it out guys. I contacted Forge Motorsport and talked to a guy called Peter Miles. He said my dump valve is so old that it's almost a classic! Since their dump valves are guaranteed for life and there is no repair kit available that can guarantee to work for my dump valve, he's gonna send me a new twin-piston ram-type dump valve FREE OF CHARGE! Excellent service ain't it guys?!!
Thanks for the help
Old Jan 31, 2007 | 04:06 PM
badboy rs's Avatar
badboy rs
but i thought you can only get chatter on efi, not mfi??????????
Old Jan 31, 2007 | 04:46 PM
SafeChav's Avatar
SafeChav
Nice end result there then
badboy rs some MFI cars chatter, but its never as prominent as an EFI car.
15
Oct 7, 2015 03:43 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
