s2 Gearbox
Old Jan 6, 2007 | 12:54 PM
xr3icabby's Avatar
xr3icabby
Default s2 Gearbox
Hi guys. I have series 2 gearbox to put into my XR3i. I have a few questions tho. what do i need to do to remove the abs from it and will it affect anything also the 3i has a trip computer do i need to do anything about that with swapping boxes over?
Other than that is it fairly straight forward?
Old Jan 6, 2007 | 01:09 PM
antony215's Avatar
antony215
Escort Rs Turbo
Taking the ABS off will not affect the gearbox i take it your xr3i has no ABS so it's a stright swop as for the fuel computer thats just a stight swop over from your old box
Old Jan 6, 2007 | 01:49 PM
SafeChav's Avatar
SafeChav
As Antony says if your car doesn't have ABS just unbolt the modulators and thats it! Would probably be worth putting in a couple of driveshaft oil seals before putting the box in for what they cost aswell
And as for your fuel computer, theres a speed sensor on the speedo cable drive, just swap that over
Old Jan 7, 2007 | 12:28 PM
xr3icabby's Avatar
xr3icabby
hi guys cheers for the input mine does have abs on it already but the new box has had it removed i think. i want to bin it anyway. what do i need to do with the pipes that go to the modulator?
Old Jan 7, 2007 | 12:57 PM
antony215's Avatar
antony215
Escort Rs Turbo
You need to get the pipes and brake reservoir ect.. form a non ABS car. If i was you id connect the ABS up to the new box as its alot less hassle than removing it all.
Old Jan 7, 2007 | 03:59 PM
Craigb's Avatar
Craigb
Im busy removing my ABS, I'll re-pipe the whole car. Looking at some threads/sites some people just by pass the modulator and keep the ABS master cylinder. Basically at the moment it goes from the master cylinder through a abs pump then to the 3 way connector on the front inner wing. Some people just fit a new pipe from the master cylinder to the 3 way connector on the wing. Not sure how effective it is though, but its hell of alot easier.
Old Jan 8, 2007 | 03:17 PM
SafeChav's Avatar
SafeChav
All you need to do is get some piping and connections and its very easy. I would always recommend removing mechanical ABS myself
Old Jan 8, 2007 | 03:21 PM
Craigb's Avatar
Craigb
How would you do it Safe chav?
Would you use a type 23 master cylinder and pipe each wheel up?
or
Use the abs master cylinder and bypass the modulators and keep the 3 way connector and use a non abs resevoir?
Old Jan 8, 2007 | 03:33 PM
SafeChav's Avatar
SafeChav
I'd use a 25mm if you can find one. If not your standard one will be fine, all you need to do is run a pipe from each outlet of the master cylinder to the 2 t pieces on the chassis rails, throw the modulators in the bin/on eBay job done
As said you will need a non ABS reservoir aswell (no return lines if theres no ABS) and obviously to bleed it before someone starts picking holes lol
Old Jan 8, 2007 | 03:48 PM
Craigb's Avatar
Craigb
I think I get what you mean. The standard ABS master cylinder has 2 outlets which normally go to a pump each. Remove the pump and repipe each of the outlets to the 3 way connector.
So in theory the 3 way connector still feeds (left or right) the front and rear brake on each side.
Where as a non abs car the master cylinder has 4 outlets, 1 for each brake.
Is there a advantage of piping each wheel seperatly using a non abs master cylinder or each side from the 2 way connector using the standard master cylinder and a non abs resevoir.
Old Jan 8, 2007 | 03:57 PM
SafeChav's Avatar
SafeChav
You've got it spot on
The only reason the ABS cylinder has 2 outlets is because theres 2 pumps, and then its split after the pumps.
Makes absolutely no difference in terms of functionality.
Old Jan 8, 2007 | 04:00 PM
Craigb's Avatar
Craigb
Thankyou.
Old Jan 8, 2007 | 04:16 PM
SafeChav's Avatar
SafeChav
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
