gaskets
Old Nov 29, 2006 | 09:48 PM
Gucci Boy's Avatar
Gucci Boy
Default gaskets
should there be a gasket between turbo and manafold
Old Nov 29, 2006 | 09:51 PM
Rick's Avatar
Rick
no. make sure both surfaces are perfectly smooth
Old Nov 29, 2006 | 10:17 PM
Gucci Boy's Avatar
Gucci Boy
exzost is blowin from there could i get away with jus tighternin up the nuts
thanks for your comment
Old Nov 29, 2006 | 11:41 PM
smitsturbo's Avatar
smitsturbo
if you want to snap them
cos that can be a right bastard some times
Old Nov 30, 2006 | 09:00 AM
Chris69's Avatar
Chris69
mine did this, apperantly its common and tightening the nuts is risky as u may daage the studs
they didn't come with a gasket but u can get one from burton power.
my advice is either take the manifold and turbo off and have the faces machined flat or as a quick fix fit a gasket
Old Nov 30, 2006 | 10:05 AM
Rick's Avatar
Rick
gasket wont last.
Old Dec 2, 2006 | 03:47 PM
steven botes's Avatar
steven botes
i use a metal gasket from garret which is about 1mm and shaped to squash into place with some exhaust high temp sealer each side
lasts a few months at a time on 1.5bar plus
i also use some ss m12 bolts in place of the std jobs with hi tensile nuts - do not use ss blts and nuts together , they will pick up and you have to use a grinder to get them off!!!
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 23, 2015 06:28 AM
pie-face
Sep 15, 2015 10:43 AM
