coil pack
coil pack
with gotech management what do I need to get rid of the old distributer and convert to using a coil pack?
is there a car I can get all the bits from??
any help appreciated
so I would need some type of trigger wheel like used in an efi conversion? I just thought it would be best o do coil pack because its more reliable and you get a stronger spark.
Yes and Yes
You have to check what kind of input the Gotech will take. Either Hall effect, optical, or Variable Reluctance. The Hall and Optical give a similar output, but the VR needs conditioning circuitry. The ECU will probably have provison for all these built in, but it's best to check.
The Fiesta and Sierra 1800 use VR sensors.
You can actually use the std dizzy for the pickup, and not use it as a Distributor - ie the coilpacks/edis module provides the spark. You'd have to mount the coilpacks elsewhere, but that's no prob.
the gotech pro uses coilpacks but you need the 36:1 pickup from the fly wheel like on the xr3i efi eec4?. The gotechpro requires a crank angle reference point
coil packs make approximately 50% stronger spark which is useful at higher boost levels
07-10-2015 12:56 PM
