converting carb head to efi
Old Jul 24, 2006 | 07:30 PM
steven botes's Avatar
steven botes
Default converting carb head to efi
spent the weekend modifying a std carb head(cross pattern on hexaust side)to fit efi manifold from xr3i
browsed one of the restoration/rebuild pages of an adaptor plate which is used to fit the efi manifold to the standard mfi/carb head
on my previous motor , i match ported the inlet manifold for my dellorto dhla(f)40's and was only left with 2mm around the port on the head.i was woried that it would blow but i used some good quality thick gasket material with some high temp silicone and experienced no problems , even at 1.5 bar plus
after seeing this plate , i am now worried that i have not got enough meat left on the head for a decent seal. after grinding away material to fit the injectors , i only have on some places 2.5mm left at the top.
will i have problems here?
Old Jul 25, 2006 | 04:49 PM
RST Ski's Avatar
RST Ski
i reckon its a case of trying it, ive seen ppl drill out snapped manifold studs to fix a heli coil in instead of the stud and the holes were practicly on the line of the head
Old Jul 25, 2006 | 07:40 PM
steven botes
keep you all posted
has anyone been to the gotech site - check it out
Old Jul 26, 2006 | 08:44 AM
SafeChav's Avatar
SafeChav
So, are you saying you've modified the inlet ports to accept injectors, yet you are you using a conversion plate?
Old Jul 26, 2006 | 05:24 PM
steven botes
no plate mate , cut outs cut into the top of the ports
Old Jul 26, 2006 | 06:48 PM
SafeChav's Avatar
SafeChav
Should be ok i saw a similar thing done before.
Old Aug 10, 2006 | 01:02 AM
turbodoctor's Avatar
turbodoctor
wot about crank sensor?
Old Aug 10, 2006 | 03:14 PM
SafeChav's Avatar
SafeChav
Indeed what about crank sensors?
this thread is about the head
Old Aug 10, 2006 | 05:31 PM
steven botes
ill be using gotech - no crank angle sensor required!
Old Aug 11, 2006 | 08:29 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Great so u have no sequential injection. Very crude.
Old Aug 12, 2006 | 04:36 PM
steven botes
no mate - crude is blowing 2 bar through 40mm dellortos with 2mm main jets and getting 3 - 4 km / liter!
Old Aug 12, 2006 | 07:36 PM
Versus_Creations
Ask me a question!
jessie_rs
62
Aug 6, 2019 09:27 PM
DAZZER
Sep 30, 2015 08:43 PM
sridgett
13
Sep 27, 2015 06:03 PM
dms04
Sep 11, 2015 01:57 PM
hopper350
Sep 4, 2015 12:53 AM
