S2 ERST Oil Stem Seals??????
Old Jul 10, 2006 | 06:25 PM
marky_g's Avatar
marky_g
Fleet Manager
Default S2 ERST Oil Stem Seals??????
rights its a S2 ERST, got a little bit of smoke from cold start, hope its stem seals its 90k standard engine,
how difficult are they to change, cant find it in haynes manual.
oh and where can i buy the seals i have the tool already
hope its not piston rings
Old Jul 11, 2006 | 12:19 AM
NEWTON's Avatar
NEWTON
stem seals from ford,there the modded ones with the collar dead easy to fit make sure no 1 piston is at top ,1 and 3 first 2 and 4 after dont let valves drop throgh
Old Jul 11, 2006 | 07:39 AM
velocity's Avatar
velocity
Draper sell a tool specifically for that job on cvh engines for removing and installing the valve springs without cylinder head removal. its a tidy piece of kit and simple to use.
will try and post the part number later
Old Jul 11, 2006 | 10:50 AM
SafeChav's Avatar
SafeChav
Think you mean 1 & 4 then 2 & 3........
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
