dump valve removal help please
Old Apr 13, 2006 | 04:47 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
Default dump valve removal help please
there is a breather pipe attatched to the valve that goes onto the inlet what is it for? where should i connect iit or should i block it? help need to get rid of this dump valve does my head in
Old Apr 13, 2006 | 04:49 PM
xr4x4rs's Avatar
xr4x4rs
sounds like a vacum pipe if it just goes into the top of the dumpvalve the just block the pipe off
Old Apr 13, 2006 | 04:53 PM
deleted's Avatar
deleted
ok cool thanks
Old Apr 13, 2006 | 05:13 PM
mark_24v_wiring's Avatar
mark_24v_wiring
Err hold on are you totaly removing a dump valve from the car?
Old Apr 13, 2006 | 05:23 PM
xr4x4rs's Avatar
xr4x4rs
i think i know where your coming from mate but i pressumed he was taking the complete dumpvalve out and just asking what he should do with the pipe that goes onto it
i could be wrong though
Old Apr 13, 2006 | 05:27 PM
mark_24v_wiring
Yeh you know exactly what im thinking the vac pipe is what operated the valve and even if he is fitting a re circ valve he will need the vac and if he is totaly removing the valve then he should be aware of turbo stall have no idea what boost this becomes a problem but you never know
Old Apr 13, 2006 | 05:31 PM
xr4x4rs's Avatar
xr4x4rs
well i never ran a dumpvalve on my last one and was holding 26psi happily
never had any probs or turbo stall
so he should be alright
shouldnt you be building anyhow lol
Old Apr 13, 2006 | 05:33 PM
mark_24v_wiring
Well im supposed to be this weekend but as me bro's cought light i gotta look at repairing his loom lol
so looks like ill have to wait a while longer
Old Apr 13, 2006 | 05:34 PM
xr4x4rs's Avatar
xr4x4rs
lol
im sure yu will sort it
as for the dumpvalve kick it down the road id say
Old Apr 13, 2006 | 05:35 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Not a problem with a T3 or T34 on a cossie
Old Apr 13, 2006 | 05:37 PM
mark_24v_wiring
Fair enough i have never owned a turbo so have limited knowledge always interested to learn tho
Old Apr 13, 2006 | 05:44 PM
frog's Avatar
frog
Mark, the dump valve on/off debate has been going on here for years and is still not resolved.
As said, T3 and T34 are ok and won't suffer in the long term.
However, T4 and GT series turbos deffo need them iirc.
A quick search on here will give you both sides of the argument, up to you to make up your mind
Old Apr 13, 2006 | 05:50 PM
mark_24v_wiring
Hmm i dont wanna get into the whole argument about them just thought it was a needed bit of kit to prolong the turbo's life but hey like i said never owned a turbocar so never really bothered to find out much about them
Old Apr 13, 2006 | 06:10 PM
frog's Avatar
frog
I wasn't suggesting you should get into the argument
The most likely reason recirculating valves are fitted to standard turbo cars is that your average joe blogs has no interest in the pschiiit noises, or chatter (turbo blades cutting through compressed air).
They keep the car quiet, but don't necessarily add anything to the reliability of the car overall
They become really necessary with bigger turbos or seriously big boost.
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
