How to check the timing with verniers fitted????
now there's the two arrows on the 'inner' portions of the verniers....
do I take it that these are the same as the 'standard' alignment arrows???
Also on the dizzy shaft (I have no rotor arm!! - coilpack!!) is the cutout portion at the back i.e. 180 deg away from the timing mark on the dizzy??
Help!! I think the inlet cam may be a tooth out!!
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
