PSI to Bar
PSI to Bar
A quickie for you boys and girls
my rouse is running at 12 psi at the moment
My question is how many psi to 1 bar of pressure
cheers
steve
cheers
steve
Depends what type of pressure you are converting or summat... IIRC Tiff IS correct when refering to boost...
been loads of techy discussions on it...
Originally Posted by Damo V
14.5-14.7
Doug .
Tiff was correct with his first reply....
1 Bar=14.7 Psi at sea level,which incidentally is atmospheric pressure..
This also equates to 1 Kilogram per square centimetre....And technically 1 Ton per square foot...
This is where the equation gets a little mixed up,because we are already at a constant 1 bar of atmo pressure there is conversion factors that come into play.......And the Yanks always have their own idea of things anyway(Hence the conversion tables in the above site... )
So you are all nearly there,...14.5-14.7..................Or thereabouts...
Davva your wrong mate
1 atmosphere (1atm) is 14.7 Psi
but 1 bar is 14.5 psi
This is bercause atmospheric pressure is an average as its different all over the world hence weather fronts and the like.
Alex
Alex
Originally Posted by Oranoco
Was going to say 14.5 as 14.7 is 1 atm (atmosphere) but somebody beat me to it. I could have looked clever there for a minute as well
i was told this wrong when at college
but there is 14.5 psi per bar
the reason most people say 14.7 (which is 1.013 bar) is that this is the standard atmopheric pressure at sea level! so when you see high pressure on the weather forcast it means that its about 1.013 bar,,, and low pressure is below 1.013 bar
155lee
24-10-2015 11:11 AM
Tony W
09-09-2015 12:08 PM
