scratch/swirl removal
Old Aug 28, 2011 | 08:38 PM
gjh's Avatar
gjh
Default scratch/swirl removal
Anybody know what the best way to get rid of swirls scratches is? I gave my car a wash/polish today and when I was working on the roof I noticed that I have hundreds of light scratches on the roof, they aren't deep, but there's loads of them, and I'm a bit puzzled at how they got there, could claying without enough lube have done it? What would work to remoce them (and annoying swirl marks)? Poorboys blackhole? I do the 2 bucket method, wash mitt, autoglym shapoo and ultra deep shine, didn'r clay it today though, and I don't use a machine polish. Cheers for any help people.
Old Aug 28, 2011 | 08:41 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
is it not poorboys blacklight? lol
meguiars ultimate compound is all you need, what are you using as a lube for the clay bar?
Old Aug 28, 2011 | 08:48 PM
gjh's Avatar
gjh
autoglym rapid detailer. There's a blacklight but there's also blackhole (google it).
Old Aug 28, 2011 | 08:53 PM
NoRubNoDub's Avatar
NoRubNoDub
your best working with a wet surface as well as the detailer, the same goes for compounding, although you will need to use a DA.
Old Aug 28, 2011 | 09:09 PM
phil robson's Avatar
phil robson
the other halfs mondog had swirl marks all over it when we got it, i used meguires 3stage and has got rid of them, too many people making a balls up of machine polishing imo
Old Aug 28, 2011 | 09:33 PM
Rs Craig's Avatar
Rs Craig
land of the rising sun
From: sheffield,home of james toseland world superbike champion
Originally Posted by gjh
yes a bit, plus loads of little light scratches, I'm beginning to think I didn't use enough lube and thats why I have scratches, and swirls are just a build up of incorrect maintanance, so machine polish is my way foward is it?
from my own experiance if you use the 3 stage megs you will get light marks off the paint, if you havent used enough lube when claying then you may well have created some of the marks also known as marring.Swirls are ushually caused by incorrect washing and polishing in circles.
IMO the way to get rid of them properly to leave the finish on the site i gave you is to machine polish, that was only a one stage polish with a finishing polish then wax to get rid of them swirls and light scratches
hope this helps
Old Aug 28, 2011 | 09:49 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Dont matter how good your wash technique is you will always inflict swirls,you can reduce them with a safe wash techniqiue,if you want it perfect you need to use a rotary or da and remove a micron or two, but they will come back in time
Old Aug 28, 2011 | 10:06 PM
gjh's Avatar
gjh
Thanks people, a real help.
Old Aug 29, 2011 | 06:55 PM
jaiscossie's Avatar
jaiscossie
Poorboys blackhole just contains alot of fillers for dark cars and works similar to ag srp. Your better off getting a good machine polish to remove them rather than covering them up
My cossie had light swirls all over when i got it but the paint had been really well looked after, it needed a light cutting compound and then a couple of coats of decent wax and i removed probably 95% of them .
Old Aug 29, 2011 | 07:10 PM
RichieST's Avatar
RichieST
As above, poorboys black hole is good as filling in swirl marks but to get rid of them then the only way is with a machine polish.
Old Sep 6, 2011 | 08:21 PM
minder's Avatar
minder
the only real way of getting rid of them mate is with a megs G220 polisher
and using megs 80# and 83# with a mixture of 6" buff/polish pads. you aint
got much hope/chance by hand and as said black hole is just a polish also use poorboys S S R 1 or for really bad swirls/scratches S S R 3
Old Sep 7, 2011 | 07:00 PM
JamboRS's Avatar
JamboRS
focus rs 1672
its a glaze,has no abrasives at all
PB BH is good for quick enhancement detail in between machine polishing,you cant keep machine polishing everytime
Old Sep 7, 2011 | 07:05 PM
blue oval 24v's Avatar
blue oval 24v
not all compounds are to be usrd with water
Old Sep 10, 2011 | 04:04 PM
mjonathan24's Avatar
mjonathan24
Meguires ultimate compound and a DA work wonders. Clas Ohlsson (if thats how you spell it) do a good DA for £40 if you dont have one.
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
