Red cars
Old Aug 10, 2011 | 05:14 AM
bennrst's Avatar
bennrst
Default Red cars
Help please what's best to keep a car red instead of the faded pink I usually use meguires tech wax am I right in using that or is there better stuff to use
Thanks Ben
Old Aug 10, 2011 | 05:47 AM
**caz**'s Avatar
**caz**
I find and always recommend...Auto Glym Super Resin Polish followed by Auto Glym Extra Gloss Protection! Always works well on my car....
Old Aug 10, 2011 | 04:33 PM
neil73's Avatar
neil73
Try using a light cutting polish before your meguiars tech wax
Old Aug 10, 2011 | 04:35 PM
D16PJM's Avatar
D16PJM
super resin has a light cut
Old Aug 10, 2011 | 08:35 PM
bennrst's Avatar
bennrst
Is tech wax a super resin then lol sorry im a retard when comes to cleaning it
Old Aug 10, 2011 | 08:49 PM
**caz**'s Avatar
**caz**
No, Super Resin Polish is made by Auto Glym and looks like this.....
Old Aug 10, 2011 | 08:52 PM
RS Grant's Avatar
RS Grant
Made in Scotland
I didnt realise that SRP had any cut in it... learn something new every day.
Cheers,
Grant
Old Aug 10, 2011 | 09:26 PM
Bailes1992's Avatar
Bailes1992
Very very fine cut and has to be worked in well to make any decent progress with it.
It's a great polish, I use it by DA polisher with a drop or two of parrifin on the pad to help lubcricate it and it makes a great 'quick once over' polish.
The fine cut removed hologramming, the fillers help hide swirls and leaves a perfect base for practually any sealent or wax!
Old Aug 11, 2011 | 05:53 AM
bennrst's Avatar
bennrst
So I should super resin polish then tech wax to seal it
Thanks ben
Old Aug 11, 2011 | 06:05 AM
STeve's Avatar
Super Moderator
It drove me mad paint fade when I had a red ford ,since I sold it happy days ,always found The auto glym products worked well on it
Old Aug 11, 2011 | 08:20 AM
Bailes1992's Avatar
Bailes1992
Thanks ben
Get a better wax
Meguiars #16 is an awesome wax! Only costs about Ł10 and can last 3-4 months in winter and 6+ in the summer.
What I would do it every 2-4 weeks over the next clouple of months is just give the car a good polish with SRP. Work it in well in thin coats and leave it 10 mins to set before buffing it. As SRP leaves a very fine layer of sealent down anyway you will be protecting the paint but only if you do it regularly.
Keep doing it every few weeks until you get the paint upto the condition you want it. You will be removing the fine oxidised layer bit by bit in very fine layers until you get the perfect glossy red you want.
When you got that perfect red then give it a coat of a good wax.
Then once every 3 months give it a good polish with SRP again and another coat of wax and your set for another 3 months
Old Aug 11, 2011 | 08:27 AM
D16PJM's Avatar
D16PJM
i used to find the autoglym and meguiars don't work that well together, meguiars seems to go greasey over autoglym.
Old Aug 11, 2011 | 09:23 AM
Bailes1992's Avatar
Bailes1992
Also bare in mind Megs tech wax in an all in one product that will remove all the fillers and sealents that SRP leaves behind.
Megs will go greasy over Autoglym if it's damp or humid. Same as any other combination of products.
Old Aug 11, 2011 | 09:54 AM
bennrst's Avatar
bennrst
thanks for the help im just gunna srp it a good few times then get a good layer of wax over it thats helped alot
thanks ben
Old Aug 11, 2011 | 10:00 AM
Mike C's Avatar
Mike C
The Special One
SRP is a decent enough product if you're doing it by hand, but once the paintwork is looking as good as you want it to, seal it then wax it.
Seal it with Carlack 68 sealant, then wax it with Collinite 476s. A real heavy duty wax.
Couple of coats of each of those and you shouldn't have to touch it again for 12 months, just top it up with a half decent QD.
Bailes1992's Avatar
Bailes1992
Get a microfiber applicator pad. SRP will clean the paint no end so you need a microfiber pad just tomake sure you don't do any damage. Also make sure you work it in well! Not much pressure but needs to be worked in will.
Old Aug 11, 2011 | 10:39 AM
bennrst's Avatar
bennrst
I've just got autoglym SRP as pictured and a megs applicator from halfrauds are they microfibre ?
I only ever used to wash it (chamois) it then megs tech wax looking like il be at it all weekend lol thank you so much for all your help
Thanks Ben
Old Aug 11, 2011 | 10:41 AM
Bailes1992's Avatar
Bailes1992
Thanks Ben
You can get sponge and microfiber ones. White are microfiber and Yellow are sponge
Also you went a few microfiber cloths for buffing up
Old Aug 11, 2011 | 10:46 AM
**caz**'s Avatar
**caz**
I use the Meguairs yellow sponge applicators to apply srp and wax etc!
You will know if you have used too much SRP as you will get white dusty residue, if thats the case use less! SRP goes a long way, and a litre bottle will last a long time!
I always finish off as said above with Auto Glym Extra Gloss Protection. This is like a watery substance. You dont rub this into the paint tho, you lay it on in a thin coat in straight lines, leave it on for 30-45 mins depending on outside temperature and direct sunlight...it can be a bugger to get off if left too long in heat, so try to use it in the shade!
You will love the results when these 2 are used together!
Post up some before and after pics
Old Aug 12, 2011 | 10:07 AM
bennrst's Avatar
bennrst
right here goes tell me how u think ive done i washed and dried it then it decided to rain
so before
and after
It was fairly easy to use aswell came of easily with no swirl marks good stuff will be using it again a few times then a good coat of wax thanks for all the help even treated her to some megs metal cleaner
Thanks ben
Old Aug 12, 2011 | 11:47 AM
**caz**'s Avatar
**caz**
Glad you like it! Its good stuff! A few layers of that and wax it will be looking great, tbh in the pics it doesn't look bad anyway! lol
Old Aug 12, 2011 | 12:56 PM
gjh's Avatar
gjh
Good results there, and a very nice car too.
Old Aug 12, 2011 | 01:17 PM
markc's Avatar
markc
mostly original 21year old paint work and not mopped in my ownership;
radient red looks fantastic when maintained
Old Aug 12, 2011 | 03:13 PM
bennrst's Avatar
bennrst
What's best to clean my White wheels while were at it lol thanks
Ben
Old Aug 12, 2011 | 03:18 PM
muz's Avatar
muz
Wye Valley Hardcore
Originally Posted by markc
radiant red looks fantastic when maintained
Yes, yes it does.
Old Aug 13, 2011 | 07:06 AM
bennrst's Avatar
bennrst
Thanks everyone for the comments I'm gunna do it again today what's the best thing to use on my wheels there starting to stain a bit
Muz that looks shiney shiney good effort
Thanks ben
Old Aug 13, 2011 | 12:17 PM
Bailes1992's Avatar
Bailes1992
Give them a wash in something strong, bit of fairy liquid should be fine. Then give them a polish with SRP, should remove the tar Abit of a bodge but it does work
Old Aug 13, 2011 | 01:26 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Thanks ben
What do the stains look like? is it yellowing or lots of black spots?
Old Aug 13, 2011 | 06:29 PM
bennrst's Avatar
bennrst
Yellowing and black stains right in the grooves I've only had em a year and there unkerbed so don't really wanna have to get them painted
Old Aug 13, 2011 | 08:18 PM
JamboRS's Avatar
JamboRS
focus rs 1672
firstly AG srp has very little cutting ability and youd need a machine to get the best from it so its pointless using it other than a filler.you wont restore faded red paint by using it.you need a dedicated polish,something like menzerna or 3m as your going to need to cut to get the shine back.i really cant tell the difference in the pics other than it looks a less dull red.it has no depth to the paint. you'll struggle to do it by hand and will need a machine polisher to restore.red is the hardest colour to get back to its best. SRP is useful on a car that just needs a quick enhancement detail on a car that has been looked after and wont restore faded paint.
secondly megs tech wax is as durable as suntan lotion.try something like dodo supernatural for summer and coli 476 for winter. supernatural will give you 2-4 months worth and coli will get you right through the winter as its very durable.
Old Aug 14, 2011 | 11:47 AM
**caz**'s Avatar
**caz**
This was mine when i picked her up
and this after using srp...
SRP does work by hand! You just have to be able to take the time to do it properly!
This has been shown on detailers world and this was the best by hand product for removing swirl marks!
Old Aug 14, 2011 | 11:53 AM
danneth's Avatar
danneth
TORQUE!
looks good dude, mines abit easier to keep red as its abit newer but love red when its clean
Old Aug 14, 2011 | 12:01 PM
**caz**'s Avatar
**caz**
I love it when mines all done! Ive been known to spend 4/5 hours on my car but when its done, i stand back and look and i love it! Its only mk6 escort but the looks it gets when its clean is unbelieveable!!
Down where my garages are, theres an old boy that always comments on it when im out there, couple of months back, the car wasn't exactly clean...and he told me i was letting the neighbour hood down
Old Aug 14, 2011 | 12:03 PM
muz's Avatar
muz
Wye Valley Hardcore
That's just after a wash, wasn't even polished
Old Aug 14, 2011 | 12:13 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
That Fez looks great
Old Aug 14, 2011 | 06:46 PM
JamboRS's Avatar
JamboRS
focus rs 1672
its not faded thats why it worked for you,you cant bring faded paint back by using a filler.you need to cut the top coat to get the gloss back.srp doesnt remove swirls,its fills them.the swirls are still there. ill explain it in lady terms,srp is like make up,it will hide the cracks and make a woman look better,but under the make up theres still bad skin.where as real polishes are like botox,they remove the cracks/lines.
srp gets it results by hand because its a filler,it if was a dedicated polish you could never get enough heat or work it enough to get the abrasives to remove anything more than water marks.its not got the cutting ability.id rather use blackhole than srp as its easier to work with.
Old Aug 15, 2011 | 07:54 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Won't it also depend if its a solid colour like the fiesta or a base coat and laquer like the S2's radiant red?? Solid paints fade as it has no laquer to protect whilst radiant red's always fine as it's got the laquer protection!?
Old Aug 15, 2011 | 08:14 AM
muz's Avatar
muz
Wye Valley Hardcore
If you mean my Series 2, as far as I'm aware it's just basecoat also. I don't think it's laquered and was painted in 2000. Just stored since.
Old Aug 15, 2011 | 09:19 AM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Red cars look the best when given a good coat of wax
Old Aug 15, 2011 | 10:05 AM
**caz**'s Avatar
**caz**
Unfortunately that was the only pic i have of the car before i got to work with it, but i can assure you it was faded! It was pink rather than red...that pic is not good enough quality to show that!
I know what your saying with SRP but in my opinion and from experience...SRP used along side EGP is the best combination for red cars!
