snow foam
Old Oct 8, 2008 | 02:33 PM
Trist's Avatar
Trist
Default snow foam
any one used it?
http://www.elitecarcare.co.uk/produc...roducts_id=283
thinking of giving it a go. do you just wash it on with sponge and leave and rinse?
how long would 5 litre last?
is it any good??
Old Oct 8, 2008 | 03:56 PM
EliteDetailer's Avatar
EliteDetailer
Originally Posted by Trist
any one used it?
is it any good??
It's alright on your initial wash but it does strip wax faster than a decent shampoo.
Your better off using a quality shampoo through your foam gun, it will most likely come out slightly less foamy but the final results will be better.
Regards
Old Oct 8, 2008 | 09:51 PM
Trist's Avatar
Trist
Dont mean to sound stupid but what is a foam gun?
is thats what is needed to use these products, I have only ever done sponge bucket and polishes?
Old Oct 8, 2008 | 10:01 PM
EliteDetailer
Wowsers!
You dont want to be doing that. Use the sponge on crappy jobs.
Read this:
http://www.elitedetailer.com/content/CARCAREGUIDES.htm
With reference to the foam gun:
You need a foam lance which fits onto your pressure washer. I.e Karcher, Kew, Alto etc. http://www.elitedetailer.com/cgi-bin...mrid=1&cmpid=2
You can get ones that fit your hose pipe too but you need strong pressure from your hose tap as well as it does not foam as well.
Regards
Old Oct 9, 2008 | 09:44 AM
rst s2's Avatar
rst s2
SSS shouldn't strip wax. it's designed not to. Traffic film removers that give a similar foamy appearance when put through a foam gun will however.
Old Oct 9, 2008 | 11:33 AM
EliteDetailer
Hi rst2,
We have ran many many tests with the sss on various cars. Ranging from daily drivers, track day cars as well as garage queens. There is no doubt that the sss strips wax/sealants faster than a car that is foamed with a decent shampoo.
trust me, if sss was that good, we would be using it as it would work out a lot cheaper for us.
Regards
Old Oct 9, 2008 | 11:50 AM
rst s2's Avatar
rst s2
So how did you run the tests? just using sss and noting the amount of beading after each wash? just curious.
i only ever use sss on the pre wash through the foam gun and then follow up with something like pb super slick n suds or dodo btbm in the wash bucket. i don't find the sss slick enough in the wash bucket. other option for me through the foam gun is the megs hyper wash. but as you say is a fair bit more expensive than the sss.
Old Oct 10, 2008 | 03:09 PM
MENIS's Avatar
MENIS
snow foam is brilliant when used through the right foaming nozzle on your power washer.would seriously recommend this product
Old Oct 10, 2008 | 06:14 PM
Trist's Avatar
Trist
got some on its way and have a petrol power washer at work with different nozzles for spay patterns and pressure.
Old Oct 10, 2008 | 11:19 PM
EliteDetailer
Hi,
This is Gurcharn here, sorry I was not able to reply any sooner.
I have only just returned from working on this:
Beading is just part of the experiment. There are various high grade LSP's on the market which stop beading well after a month or so but are still providing adequate protection and gloss. All shampoo's cut into the LSP to a degree, even PH neutral ones. However the SSS is quite abit harsher.
The Hyper wash is better like you said. It doesn't work out that expensive with HW.
The PB shampoo mentioned above is nice, I used to use it a few years ago. Zaino Z7 is the king of shampoos though. You should give it a go, you will love it.
Regards
Old Oct 14, 2008 | 03:46 PM
Gav Diamond's Avatar
Gav Diamond
I also find that snowfoam strips all tire and trim dressing in one go, so if you have loads of plastics only foam if you plan on re-treating everything
Took me a while to figure that out, quite annoying considering all the plastics on my car, here is a pic of it in action
Old Oct 14, 2008 | 05:15 PM
rst s2's Avatar
rst s2
nice and foamy. not had any trouble with it stripping the protection from plastics before. which snow foam were you using?
Old Oct 14, 2008 | 06:41 PM
Gav Diamond
I have been using Autoglym bumper care for all the plastics, not the best but not going to replace till its run out.
I use Clean Your Car snow foam, i normally add in some Chemical guys Maxi sudsII but i have tried with and without and it still strips the Bumper care off the plastics
Old Oct 15, 2008 | 11:41 AM
rst s2's Avatar
rst s2
i've had trouble in the past with the ag bumper care running even when it gets rained on. i don;t find it particularly durable. however it does give a nice finish until then. on product you may like to try is swissvax pneu. it's a bit more expensive than the ag but gives a cracking finish and if applied properly will last well.
Old Oct 15, 2008 | 01:06 PM
EliteDetailer
You can apply the AG bumper care without streaking. You need to put multiple thin coats and it needs to dry out in between coats. Admittedly the snow foam isn't helping you.
If you still want to change then go with this, it's the best: http://www.elitedetailer.com/cgi-bin...mrid=1&cmpid=2 Again, thin coats are key and build them up..
On the subject of foam, below are a couple of cars thats been foamed with Zaino Z7.
Not overly foamy but easily good enough, more importantly not as harsh either.
997 Turbo
Murcielago LP640
Old Oct 15, 2008 | 01:24 PM
rst s2's Avatar
rst s2
i've never used the 303 aerospace on exterior trim before. always reserved it for dressing engine bays. what the durability like on the exterior?
foam from the z7 looks plenty. is that it topped up in the foam gun with warm water or just cold?
Old Oct 15, 2008 | 01:47 PM
boXXer's Avatar
boXXer
GASH!
i like this foaming shit
Might have a go myself
Old Oct 15, 2008 | 04:33 PM
EliteDetailer
Try the 303 on trim. I get the best results from it. I used to use Pneu back in 05, its pretty good too.
Z7 topped with cold water and thats it.
You should just use Hyper Wash through it and throw your snow foam away.
Old Oct 15, 2008 | 04:45 PM
rst s2's Avatar
rst s2
that's pretty good then with the cold water. what ratio do you use it in?
have to get some more 303 and hyper as it goes. onto the last dregs in the bottom of both. as only detailing part time and with nothing booked in at the moment, i've got a while to get it in .
will keep the snow foam for the inlaws car. i spent 3 days on it when they got it (1.6 focus in panther black metalic) making sure it was spot on. then because they didn't want me to see it dirty they put it through a car wash . needless to say i'm not correcting the paint again. it can be foamed, 2 bucket wash, dry and a quick layer of poorboys qw+.
Old Oct 15, 2008 | 06:29 PM
Gav Diamond
EliteDetailer
I will have to give the 303 a go as i normally only use it on engine bays like rst2
I have never had streaking with the AG bumper care just find the snowfoam gets rid of it.
Will have to just use up the snowfoam with APC mixed in for LSP removal on cars to be machined etc as i don't like to just bin anything if it can serve a different purpose
Few more i have done, not super cars like yours though, lol
Old Oct 15, 2008 | 07:39 PM
EliteDetailer
Gav,
I too have a mk2 golf. Yours looks nicer than mine though.
Any mods?
Old Oct 15, 2008 | 08:45 PM
fezzajsy's Avatar
fezzajsy
would u use 303 on samcos
Old Oct 15, 2008 | 11:07 PM
EliteDetailer
No problem on Samco's.
Old Oct 15, 2008 | 11:15 PM
bbspolo's Avatar
bbspolo
so what do u charge for say a simple detail up 2 a extreen detail???
Just wondering as my car has been in storage for a few years so would be nice 2 get her back up 2 spec??
Old Oct 15, 2008 | 11:23 PM
bbspolo's Avatar
bbspolo
dont worry just found your prices on your web site will be intouch shortly!
Old Oct 15, 2008 | 11:38 PM
fezzajsy's Avatar
fezzajsy
cheeRS man.very nice that u joined PF EliteDetailer.nice one
Old Oct 16, 2008 | 12:50 PM
boXXer's Avatar
boXXer
GASH!
so do PF'ers get a discount, hehe.
My 3dr could do with a good going over
could ya pm me with somre prices etc?
Old Oct 16, 2008 | 06:59 PM
Gav Diamond
Gav,
Any mods?
Not mine, belongs to a friend
Did a big spec list but this crappy site keeps packing up and i lost it when i clicked submit post and cant be bothered to type it all again
Here is the link to a thread i did on it, not the best detail in the world but the paint seemed thin and i didn't want to push my luck
http://www.cleanyourcar.co.uk/forum/...pic.php?t=4506
Old Oct 16, 2008 | 08:37 PM
EliteDetailer
Looking good Gav, nicely done.
Regards
Elite Detailer
Old Oct 17, 2008 | 11:48 AM
rst s2's Avatar
rst s2
Nice work Gav. that paint was a tad thin in places! i've only come across those sorts of figures on the door shuts so far. must have done well over 100 cars to date too.
Old Oct 17, 2008 | 04:23 PM
Gav Diamond
Cheers guys
Still learning and testing products, well over £1k in less than a year but enjoying it and the responce from the owners makes it all worth while.
Old Oct 17, 2008 | 04:57 PM
rst s2's Avatar
rst s2
Cheers guys
that's the tip of the iceberg on product testing. but in the end when you find what you're happy with it'll get easier / cheaper.
I've been detailing part time for the last couple of years. I'm still learning huge amounts. product developement and evolution is pretty big and can be costly to keep up with. one thing i find is if i buy a product and test it and don't get on with it after 1 or 2 applications you can sell them on. i know that this is a tad mad but you can regain some costs this way. also if you are looking to move into detailing full time one thing i'd say is when you find products you like, try to become and approved reseller. this way you can get the products in at trade price rather than having to shell out full price for them
Old Oct 17, 2008 | 06:46 PM
Gav Diamond
Like i say, i've been into it for about a year.
I don't like to give up on products so keep trying them on different things
For example Megs #80 and #83 first time i used i thought what a load of rubbish but it was on a Audi with super hard paint but when used on Modern Ford paint i think it works very well.
Only things im thinking of selling is some of my waxes as got a few but want to try some higher priced stuff
On the other hand, i think the EZ detail brush is the best cleaning brush i have ever bought, lol
Done with the Megs #83 then #80
Old Oct 17, 2008 | 07:21 PM
Kam B's Avatar
Kam B
snow foam RULES
Johnny Knoxville
Sep 30, 2015 07:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
