Wireless Network Help!
Old May 10, 2011 | 12:00 AM
danneth's Avatar
danneth
TORQUE!
Talking Wireless Network Help!
I am posting this on behalf of my Bro, any help would be much appreciated!
Hi Guys,
I am all out of ideas so was hoping some of you guys can help me out as I am having major problems with my wireless network.
I moved house a couple of months ago and signed up with BeThere, had stonking reviews and met my needs exactly.
The internet was fine for 10 weeks, no problems at all, wireless worked, wired worked, no slow down no nothing.
A couple of weeks ago I started to have some problems, my wireless internet would just at random times, intermittently drop for no reason what so ever. The laptop I was using would disconnect from the router and the network would disapper from the list of available networks on my laptop only to reappear about 30 seconds later (sometimes longer than 30 seconds but generally around this time)
I tried everything, such as changing channels, setting manual IPs for the network adapter and so forth and still the same thing happened over and over.
I then decided that the Router had died a death and needed a new one so went out and bought an Edimax router as they had outstanding reviews.
After finally getting it setup......... The exact same thing happened. I am at a loss, Never had an ADSL connection before, always had cable so im appealing to you guys!
When connected via Ethernet, the connection is flawless. No problems and no disconnections at all. nothing has changed in my house, no new gadgets or anything that could interfere with the connection or anything
Troubleshooting so far:
1/. Change wireless channels - Tried 4 different channels
2/. Change SSID / WEP Key
3/. Update firmware of modem router
4/. Set manual IPs for the wireless adapter on the laptop
5/. Tried on 4 different laptops, all experience the same problem
6/. Turning off my cordless phones (someone told me this could interfere with the connection - Didnt fix it)
I am at an absolute loss what to do but it is so frustrating as I work from home so have to sit uncomfy next to the router and I really want my wireless back
The model of the Router is a Edimax AR7266-WnA
The ISP is http://www.bethere.co.uk
Any ideas / help would be much appreciated!
Thanks Guys!
Old May 10, 2011 | 07:16 PM
St3V3_C's Avatar
St3V3_C
Does sound like interference. Next door could have something that is screwing it up.
Also look for:
Wireless Doorbell
Wireless video sender
Ask if neighbours have any issues too.
Old May 10, 2011 | 09:26 PM
DanRSturbo's Avatar
DanRSturbo
Is this just the laptop having issues ? It could be the adapter in the laptop weather it be an internal one or an external one. I'm really not sure what else to suggest other then viewing the log files on the router to see what ip addresses have accessed it. It's possible that someone has cracked your password and is raping your internet, but I've not known it to cause signal loss. See if someone you trust can pop round with a lappy, or a smart phone with wireless on it.
Old May 10, 2011 | 10:05 PM
martysmartie's Avatar
martysmartie
Do you have any other nodes you could test (To eliminate the laptop?), if ok then I suspect some kind of interferance. What do the logs suggest on the laptop?
Martin
Old May 10, 2011 | 10:33 PM
danneth's Avatar
danneth
TORQUE!
Thanks guys for the input
I have tried it on a few different laptops aswell as my samsung galaxy s with the same results.
How would I find the log files which show the connection dropping etc ?
Thanks
Old May 10, 2011 | 10:44 PM
LewisT's Avatar
LewisT
go in to the power management for the wireless card on the lappy turn off the power saving features
Old May 10, 2011 | 11:16 PM
danneth's Avatar
danneth
TORQUE!
Not the laptop, happens on more than one unit aswell as smartphones etc.
The power saving is off anyways as it happens, thanks for the suggestion though!
Old May 11, 2011 | 09:27 AM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
When you are using wireless do you sit in another room? If so what is between you and that room, you must consider all electrical devices.
Do you have a cordless phone? What other devices do you have?
May seem extreme but try turning all other electrical devices off to see if you continue to get the same problem.
All part of the ball ache process that is troubleshooting.
Don't just turn them off and expect an immediate solution, turn all off, reboot laptop/router and try sitting right next to the router, then move to other rooms/areas of the house.
Old May 11, 2011 | 12:31 PM
Dr. Blofeld's Avatar
Dr. Blofeld
Menace to society
You have got the little filters connected to any other phone points in the house haven't you?
Keep the router away from the telly (particularly if it's a plasma).
If you have an upstairs socket, plug the router in up there.
Old May 11, 2011 | 01:17 PM
martysmartie
The micro filters won't cause the wireless connection to drop, it would only cause problems with the actual net connection itself if they were not installed, there job to put it simply is to split the line into voice and data.
Martin
Old May 11, 2011 | 01:37 PM
marc_gti's Avatar
marc_gti
i had the same issue with bethere when i was with them, funnily enough when i moved to a different ISP everything worked as it should.
Old May 11, 2011 | 02:01 PM
r06ert's Avatar
r06ert
i had the same issue with Virgin and they finally admitted it was overload in the area, after getting me to change router and checking the computer and xbox every night for a week
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
TrickyDicky
Jul 25, 2004 08:22 PM
AlexF
Jul 7, 2004 09:38 AM
