Chkdsk
Old Jun 14, 2006 | 07:26 PM
Redkop's Avatar
Redkop
Default Chkdsk
Can anyone explain how using Chkdsk to repair errors can completely wipe a drive clean?
I have used Chkdsk loads of times. I went through the normal way of doing it.... C Drive > Properties > Tools > Error Checking, then said yes to run on next boot up. Rebooted and Chkdsk ran through the 5 stages ok and then went to DOS screen saying.... start in normal Windows or Safemode..... whichever one I clicked, it just looped back to the DOS window.
I took the PC into repairers and they rang me today and said the reason why Windows wouldn't load was because C Drive had been wiped clean!!!
How the fuck has that happened?
Old Jun 14, 2006 | 07:33 PM
Growler's Avatar
Growler
thats bollox mate
chkdsk will not wipe a drive unless it was so fucked up it had to fix everything
how long did the chkdsk run for?
more likely you got zapped by a virus that screwed yur disk when yu rebooted
Old Jun 14, 2006 | 08:16 PM
Redkop's Avatar
Redkop
Chkdsk ran normal time for the first 4 stages and as usual a little longer on stage 5.
I can almost say with 99% certainty that I didn't have a virus, I run regular AV scans and anti-spyware programmes. I don't open any emails that I don't recognise the name of and also my ISP scans for viruses first. I also don't click on any links that are given in threads.
I can't see that C drive was fucked either with errors, as it was a fresh install and a new HD in March. Luckily I had everything backed up until March, but have lost all emails and pics since then to date.
I spose there's a first time for everything and I was the 'chosen one'
Old Jun 15, 2006 | 09:12 AM
DanRSturbo's Avatar
DanRSturbo
Unless the scanning caused the drive to overheat, and fuck the head's, there's no way it will wipe it.
However,
What you should of done is boot of the windows xp cd, go thorugh the process of installing windows, but instead of doing an install, repair the current installation and, with a bit of luck, it would be fine.
The mere fact alone it gave you the windows xp startup menu proves there is an operating system on there.
I thought you was quite clue'd up on puters
Old Jun 15, 2006 | 04:03 PM
BM08's Avatar
BM08
It wiped everything!? thats shit mate
I used it for the first time about a month ago, think it took a good 20mins or so to scan all of HDD, and i still have windows running, bonus!
Old Jun 16, 2006 | 10:19 AM
Redkop's Avatar
Redkop
However,
Not clued up on that part of it Dan, the fact that it kept looping was the strange bit and my mind just went blank.... so off it went to the 'poorly PC Shop'.
I am going to be extremely wary of running Chkdsk at anytime now on my other PC and laptop.
Old Jun 16, 2006 | 11:06 AM
Growler's Avatar
Growler
have to admit i run chkdsk quite often, i am like that, and have never known this to happen havent even heard of it happening
cannot find any instance of it on the web either
only simlar report i can see at teh moment is here
http://www.frontpagewebmaster.com/m-.../tm.htm#328530
Old Jun 16, 2006 | 12:39 PM
DanRSturbo's Avatar
DanRSturbo
I run chkdsk once a month on all 5 drives
Old Jun 16, 2006 | 01:38 PM
Redkop's Avatar
Redkop
only simlar report i can see at the moment is here
Hmmm they say could be drivers on that link.
I've just been to pick up my PC now and I am still bemused.
I asked about the start-up screen showing Windows and apparently that was because it was picking up Windows on my other drive.
The guy took the hard-drive out of my machine and put it in another and this showed it had been totally wiped clean. So he put it back into my machine and it wouldn't install XP at all, kept saying drive wasn't formatted and there was an error. He put it on other machine again and it was ok (can't remember if he said he'd done something or not at that stage), so he refitted it again to mine and this time XP installed perfectly and all the updates installed OK too.
I think I am going to use the slave drive for storing/saving all My Docs and pics to now.
Now I just have to set everything up again and download everything from scratch....... great!!!!
At the moment, I don't know what I hate most..... computers or cossies
Old Jun 16, 2006 | 01:53 PM
EssexBoyRacer's Avatar
EssexBoyRacer
I bet the indexing got screwed up. The data is still there somewhere but the indexing wont be linking up to it properly - so the drive appears blank.
If you check for disc space how much does it say is left?
Fixing it on the other hand could be a nitemare, you'd have to do some hunting around on the net to find a tool better than chkdsk.
Old Jun 16, 2006 | 02:04 PM
BM08's Avatar
BM08
if i was you id buy a new HDD just to be on the safe side
Old Jun 16, 2006 | 02:52 PM
Redkop's Avatar
Redkop
The hard-drive is just over 16 months old and has only been in use for last 4 months... I didn't use the PC for 12 months as it had a problem and as I had my laptop, I didn't bother too much about getting it repaired. When it went wrong last year I had 2 new HDs put in but still had the damn thing kept freezing.
I finally took it into repair shop last Feb/March and had a new machine built, using both HDs. Everything was fine until I ran ChkDsk.
Luckily I have the laptop to copy most of the settings I had - but it's still a proverbial pain in the arse to get everything re-installed and set up.
I have got internet connection and OE set up so far and the PC shop must have installed Avast on it..... Not too sure about Avast, last time I had it it, I wasn't keen on it for some reason, which I can't remember, so uninstalled it and went back to AVG. Having AV was my first priority
My mind has gone totally blank though on how to network it to my other PC and my laptop....
Old Jun 16, 2006 | 03:03 PM
Redkop's Avatar
Redkop
Now after loading a few things it says Used Space 4.34gb and Free Space 110gb
Old Jun 16, 2006 | 03:24 PM
BM08's Avatar
BM08
yeah i didnt like avast's interface, it was totally shit compared to AVG, with AVG its just like straight to the point no nonsense, you can see exactly what button does what and where to find things, avast on the other hand
Old Jun 16, 2006 | 03:42 PM
Redkop's Avatar
Redkop
I need to get the network up and running, so I can transfer Favourites and My Docs over instead of loading them all up by the back-ups I have on CDs.
I hate doing this sort of thing
So far
Internet connected - check
AV installed - check
OE up and running - check
MSN up and running - check
XP to how I like it [silver and classic menu] - check
Old Jun 16, 2006 | 09:40 PM
Dan B's Avatar
Dan B
I prefer the following...
XP to how I like it [not installed] - check
Old Jun 17, 2006 | 08:10 AM
BM08's Avatar
BM08
So far
Firewall, do it NOW!
Old Jun 18, 2006 | 10:12 AM
tonyk's Avatar
tonyk
Lynne, if you put this drive in as a slave and install windows on another drive you may be able to run a file recovery program and retrieve some files from the drive.
If you have everything backed up then no real problems, although personally if storing my photos on the same drive as a windows install I would use Ghost and keep a clone of the whole drive for quickness.
Old Jun 19, 2006 | 09:11 AM
Redkop's Avatar
Redkop
Too late for that Tony... I think I have a copy of Ghost somewhere, never used it though. It's on a floppy and I don't have a floppy drive on my PC but I do on my laptop - so I could copy it onto a CD on that
GTi_iTG
That was done along with AV
Thrush
Computers, Consoles and I.T.
Mar 1, 2009 10:06 PM
Thrush
Apr 9, 2008 09:30 PM
Nath
Feb 19, 2006 05:21 PM
cossies4eva
Mar 27, 2005 01:06 AM
