got a problem with the pc
Old Mar 2, 2006 | 09:38 PM
cossiecrew's Avatar
cossiecrew
Default got a problem with the pc
when i watch vids or try and play online games i keep getting a blue screen with white writing saying a load of rubbish and says something about dumping data and it crashes any ideas or shall i take a hammer to it does it have a bad virus? or is there a bust component my bird was doing 10 hours of uni work offline yesterday and not a problem but it seems to keep happening to me even when i look on ebay
Old Mar 3, 2006 | 06:13 PM
Thrush's Avatar
Thrush
Irritating c........
You are getting the "Blue Screen Of Death" - or BSOD in shorthand....
It will say something like this;
The important bit is to see if it says "DRIVER_IRQL_NOT_LESS_THAN_EQUAL"
If it does then the problem will most likely lie in the graffix card drivers, seeing as it only does this for video's and games, both of which show on the screen directly from the gfx card, rather than through the OS (which is why you can't do a screen print of a video )
You need to either re-install the original driver (if the gfx card is a stock item that came in the machine when you got it, you should have autilities disc for this, or if it is an aftermarket componant, then you should have a driver installation disc) or "roll back" the driver to try and find an alternative that doesn't cause you problems.
Try this link for explantions to rolling back drivers;
http://support.microsoft.com/default...283657&sd=tech
I had this problem lots and lots and lots when I installed a bluetooth usb device and used the driver that came with it. 5 mins after turning on I would get this BSOD, but if I unplugged the bluetooth USB stick and rebooted it was fine. Plug the bluetooth usb device back in, 5 mins later I would get a crash with this screen. It was because the device driver conflicted with Windows XP OS and they kept having a little fall out
I did a SYSTEM RESTORE back to the day BEFORE I installed the driver and it has been fine ever since (I am not using that bluetooth device anymore I might add)
That is the other thing you can do - if you remember when this started happening, you can use the System Restore feature to go back to the day before. This will only work if the problem isn't associated with a new graffix card you have fitted tho....
See this link for using the System Restore correctly;
http://support.microsoft.com/default...;en-us;Q306084
Old Mar 3, 2006 | 06:16 PM
Thrush's Avatar
Thrush
Now this is the only time you wanna see that message!!!
Old Mar 3, 2006 | 10:20 PM
cossiecrew's Avatar
cossiecrew
cheers mate i will try it out if not the bats coming out and its a gonna
Old Mar 3, 2006 | 11:01 PM
cossiecrew's Avatar
cossiecrew
ive reinstalled all my drivers and its not done it since but theres still time
Old Mar 4, 2006 | 06:27 PM
Thrush's Avatar
Thrush
Driver problem then mate Sounds like you got it licked
Old Mar 5, 2006 | 01:00 PM
DanRSturbo's Avatar
DanRSturbo
If not, wipe it clean and start again, microsoft claim that Windows XP should not generate a blue screen of death
Old Mar 5, 2006 | 07:10 PM
Thrush's Avatar
Thrush
Bollox I think they are lying - cos I had a chronic spell of it a couple months ago lol....
Old Mar 5, 2006 | 07:50 PM
cossiecrew's Avatar
cossiecrew
right since i installed the drivers its only done it once that was when i tryed to play a game but before it was doing on ebay and allsort now its just on games so can i safely say the graphics cards fuct ?
Old Mar 5, 2006 | 09:30 PM
Thrush's Avatar
Thrush
I reckon you can
What card is it?
Old Mar 6, 2006 | 08:18 AM
cossiecrew's Avatar
cossiecrew
cant remember it was about 3 year ago new cards not alot anyway ill keep you posted
Old Mar 6, 2006 | 08:33 AM
DanRSturbo's Avatar
DanRSturbo
Could possibly be a heat issue, try it with the side of the case off
Old Mar 6, 2006 | 11:21 AM
cossiecrew's Avatar
cossiecrew
ok mate will do that
Old Mar 8, 2006 | 09:55 PM
cossiecrew's Avatar
cossiecrew
your the man mate it kept happening to me tonight so ive stripped both sides off the tower and its mint even letting me play games so what doo i need a better fan ?
Old Mar 9, 2006 | 10:48 AM
L33 BYT's Avatar
L33 BYT
May be worth checking your DirectX version to.
Go to run type DXDIAG and at the bottom will be the version. You could upgrade that to.
Old Mar 9, 2006 | 04:55 PM
DanRSturbo's Avatar
DanRSturbo
You could probably do with blowing the system out, getting rid of the dust and crap in there if you can
Old Mar 9, 2006 | 05:33 PM
cossiecrew's Avatar
cossiecrew
yep done that with my hoover its mint without the sides on lol not fucked up once
Old Mar 9, 2006 | 08:22 PM
DanRSturbo's Avatar
DanRSturbo
Old Mar 9, 2006 | 08:57 PM
cossiecrew's Avatar
cossiecrew
lol whats wrong mate
Old Mar 9, 2006 | 11:08 PM
Thrush's Avatar
Thrush
Dan's about to tell you about all the tiny bits n bobs you may well have lost by hoovering out your PC
Like these for example;
Little jumper blocks that will be all over your mobo, which dictate settings
Plus little rsistors etc that easily come off with a good bit of suction
Dan don't like hoovers in PC's. When I found this on ebay and posted it up (cos I thought it was a bit daft) he told me off
http://cgi.ebay.co.uk/NEW-USB-VACUUM...QQcmdZViewItem
Old Mar 10, 2006 | 06:26 PM
cossiecrew's Avatar
cossiecrew
pmsl my dysons a right sucker aswell
Old Mar 10, 2006 | 06:36 PM
BM08's Avatar
BM08
ours is too, it screams at us in a very high pitch sound
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
