Any renault techs in? Megane 1.6 petrol wont start
Old 14-10-2013, 08:57 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Default Any renault techs in? Megane 1.6 petrol wont start
Evening chap, a mate of mine has a 51 or 52 plate megane, its been off the road roughly 2 years and earlier this year they decided to sell it. It went for mot but failed on rear wheel bearing and front brake efficiency, so i stuck a new set of discs, pads and a rear bearing on for him and its remained sat outside his house for sale.
Now it didnt sell and he has decided to use it for work as his usual lift is no more, he charged the battery, used the car to take his lad to football sunday, about a mile and then drove home.
Went to take the car out for a good run yesterday afternoon ans the thing wouldnt start lol.
It turn over but wont fire, he had taken the plugs out tonight and im not sure if it was wd40 he sprayed everywhere or petrol on the plugs, they were quite wet so assuming petrol, but there was no spark.
I know these suffer from immobiliser issues, so is there a way around testing/ bypassing the immobiliser??
Cheers!
Old 15-10-2013, 04:16 AM
B19 JUB
B19 JUB's Avatar
if the red light goes out when ignition is put on then immobiliser is ok and its prob resistance in the crank sensor.if you touch the plug or body of sensor it should start up as your grounding it and taking away the resistance.will require a new sensor but will get it going.see it all the time out on the road (rac patrol)
Old 15-10-2013, 06:28 AM
gingerturbo
The annoying ginger guy
gingerturbo's Avatar
Very common the crank sensor problems on these, has this yr got the key or card
Old 15-10-2013, 06:44 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
cheers boys, its pre-facelift/fat arse.
it has a key, the red light on the dash goes out when cranking, so could be the CPS.
where are they on these cars?
i did trace some wires to around the middle of the block on the gearbox end, but couldnt really get to it nor see it as it was a bit dark last night lol.
are the cps expensive/easy to change?
its just weird how he used it twice, then it wouldnt work!
thanks again
Old 15-10-2013, 07:18 AM
stevos
stevos's Avatar
Its on the top of the gear box there is a cut out any you can see the flywheel
Think its just two bolts if I remember cheap and very easy to change.
My sister had bother with hers.
Old 15-10-2013, 10:02 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
ok mate cheers, ill pick one up later and give it a shot
Old 15-10-2013, 11:34 AM
Gazzonator
Gary Krishna
Gazzonator's Avatar
Take the old one with you to make sure they give you the same one as there seems to be quite a variation on the connectors.
I've given up trying to do them at the roadside as I can never seem to get the correct type.
I think Renault revised them a couple of times and sell a plug to go with the sensor when you buy it from them. They did when I bought one a few years ago anyway.
Old 15-10-2013, 12:34 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Ah bugger, wont have access to the car till tonight, so was gonna take a punt on the more expensive one lol.
the local euro car parts only has 2 possible sensors in stock, the other 3 are out of stock...
Old 15-10-2013, 12:40 PM
Gazzonator
Gary Krishna
Gazzonator's Avatar
The one that's on the car is bound to be one of the 3 that's not in stock!! Sods law!!!
Old 15-10-2013, 01:18 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
True, might have 30 mins to get it off, his mrs should be there but gotta pick the littleun up at 3:30.... time is ticking lol
cheers mate
Old 15-10-2013, 02:04 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
K'nell!
Took litterally 5 mins to open bonnet, get tools and a whip it out!
So had time to come hom and make a brew before getting my daughter lol
I bet it wont be so easy putting it back on in the dark lol
Old 15-10-2013, 02:35 PM
B19 JUB
B19 JUB's Avatar
sure it will be fine going back in.just don't drop the bolts in the gearbox lol
Old 15-10-2013, 06:34 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Well, went and got one, they part matched it but didnt have any genuine ones so i took what they had.
Littleun fell asleep on the way home so i popped round gav's and nailed it on.
He got home just as i was about to shut the bonnet so went and got the keys....
It fired up straght away!
Thanks very much chaps, gav is quite pleased. Wile there i dipped the oil, its like fooking treacle lol, so i told him thats next weekends job lol
Old 15-10-2013, 07:01 PM
stevos
stevos's Avatar
Glad you got a result mate for not a lot of cash.
Old 15-10-2013, 07:26 PM
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
BRIGSPORT's Avatar
Good lord! An easy fix on a renault?????????? Well i'll be damned!!!!!
Old 15-10-2013, 08:03 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Thats what i was saying last night, fucking french shit was said a few times lol
Old 15-10-2013, 08:17 PM
BRIGSPORT
BRIGSPORT's Avatar
I say it many times, daily!!!!!!!!!!!
Old 15-10-2013, 08:22 PM
Nick 172 Sport
Nick 172 Sport's Avatar
so did i till i got rid a month ago lol
Old 15-10-2013, 11:24 PM
vaughant
vaughant's Avatar
On the older megane they seem to suffer with dodgy relays/connections to the relay in the fusebox under the bonnet so quite often turning it over while giving them a good tap on top of the relays gets them going. No doubt the same dismal quality on the newer ones so another fault to put in the memory bank fudgemeister!!!
Old 16-10-2013, 12:53 AM
Gazzonator
Gary Krishna
Gazzonator's Avatar
Glad it was an easy fix!
9 times out of 10 it's the crank sensors at fault when I get called out to them!
Old 16-10-2013, 08:19 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
thanks again boys, got him out the shit anyhow. had a text to say it fired up straight away this morning and got him to work!
on another note while thinking about it, a guy round the corner has a 51 plate megane scenic.. that thing doesnt start easily, they often have to lock/unlock it a few times before it starts.
so that one does sound like the immobiliser??
ill pass on the crank sensor info to him just incase
Old 16-10-2013, 09:43 AM
B19 JUB
B19 JUB's Avatar
Cheap fix done. Glad we could all help. Friends one sounds like maybe immobiliser module isn't unlocking or about to permanently fail
Old 16-10-2013, 09:50 AM
Gazzonator
Gary Krishna
Gazzonator's Avatar
If it's got a single button remote, try pressing the button firmly as you turn the key in the ignition to start it. If it starts, it's probably the key at fault as they suffer with cracks in the circuit board which are difficult to see.
Old 16-10-2013, 10:22 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
cool cheers mate, its been doing it years - they have just learnt to live with it!
ill pass on the info suggested
cheers again!!
Old 16-10-2013, 09:45 PM
vaughant
vaughant's Avatar
See my post above re: the 51 plate mate.
Old 18-07-2017, 07:06 PM
Claire Ashton
Claire Ashton's Avatar
I know this is a really old post but you guys have just saved my bacon with this!!! Cheers fellas x
Old 18-07-2017, 07:45 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Glad to of helped. Fyi he never did change the oil and it died a few months later...
Some people wont be told
Old 02-09-2017, 10:56 AM
danhamon8
danhamon8's Avatar
hi
i think i may have the same problem as this??? trouble!!
basically -
car wouldn't start a few months ago and a guy changed the battery and worked fine for a while.
now i went to get in the car last week - turns over fine but won't kick in at all. came completely out the blue. literally will not start but turns over fine
it is a 1.4 megane dynamique petrol
key card ignition
any help would be appreciated????
Thanks
Old 03-09-2017, 12:45 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Change the CPS, its £20odd and a piece of piss to change, then go from there if its not that.
JoeyBoyden
04-01-2024 02:36 PM
Bailes1992
03-09-2015 02:17 PM
Bailes1992
16-08-2015 07:14 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
Quick Reply: Any renault techs in? Megane 1.6 petrol wont start
