4x4 front diff removal
Old 01-05-2016, 06:38 PM
Birty7810
Birty7810's Avatar
Default 4x4 front diff removal
I have developed a bad leak on my front diff to the point you carnt keep any oil in it, how big of a job is it to remove looks tight to get out,
Any advise on how to go about the job?
Car will be on a lift aswell so easy access
Old 01-05-2016, 07:16 PM
Jay,
Sponsor
Jay,'s Avatar
Down pip;e off ,
bottom diff plate off remove cir-clip of from inside the casing to drivers side drive shaft
Remove drivers side bottom ball joint
pull drive shaft out of the casing taking care to not pull the inner joint apart
undo all the mounting bolts and bracket that support the diff
Then swivel around and get a levy bar just to prize the diff off the intermediate shaft and hey presto
Its a awkward job but not hard did mine with a couple of cups of tea in about 2 hours complete
Best regards Jay
Old 01-05-2016, 07:20 PM
Caddyshack
Caddyshack's Avatar
The leak is probably only the bottom plate, I would remove that, drain the fluid and have a look. If rebsealing that doesn't do it then unbolt the steering rack and pull it forward. With the drive shafts out you can remove the circlip said inside the diff and pull the cups / drive flanges out. The diff can then be dropped out.
I would try re-sealing the bottom plate first. I used a squirty gasket from halfords and slowly tightened all the bolts.
Caddyshack
Caddyshack's Avatar
Jay beat me to it, not a hard job
Old 01-05-2016, 07:47 PM
Birty7810
Birty7810's Avatar
Thatl do then, I have had the bottom plate of and re sealed it but it didn't make any difference, I never noticed a circlip holding the drive shaft in when I was looking in there tho
Or do some people not replace these?
Old 01-05-2016, 07:48 PM
Caddyshack
Caddyshack's Avatar
Yes, I have seen a lot not use them
Old 01-05-2016, 07:52 PM
Birty7810
Birty7810's Avatar
Will try and remove the diff and replace the seals, I'm guessing the sump is separate and isn't going to empty all over the place when the diff is pulled out?
Old 01-05-2016, 07:55 PM
Caddyshack
Caddyshack's Avatar
You might lose some when you remove bits on the passenger side but that is easy to top up.
Bosch
03-06-2016 12:27 PM
Dr. Ickxs
02-05-2016 08:05 PM
cos elle
02-05-2016 04:08 PM
Turbomike89
30-04-2016 11:52 AM
James Porter
29-04-2016 01:27 PM
Quick Reply: 4x4 front diff removal
