2.0 Zetec turbo or hi reving 2.0 on throttle bodies
Need to decide between the two as I want a new engine for my track combo van. 1.6 RS turbo at the min.
Now I don't want a big boost hungry car that will be fast in a straight line as I want usable power to race with. And I would think 200-250 bhp will be plenty
Easier to get that power with a turbo I would think.
Budget is a big factor.
Have a read of this, might point you in a direction.
https://passionford.com/forum/ford-e...onversion.html
Budget is no problem, car will get whatever it wants, just don't want to build a engine with power that won't be usable or 100% reliable after some very hard use.
200-250 will be expensive if you want to keep it N/A
High ish compression (8.5:1 ?), small turbo (T3) set would be a better option
There has been a few conversions like this running below 300 with great throttle response
Yes 250 ish on a N/A would be in the region if six grand with dry sump etc, but I bet by the time You turbo a Zetec with management and steel bottom end for reliability I would of thought it would be just as much
Ben
Go Duratec, 250bhp will cost a fair chunk less than getting a Zetec to that level, Zetecs need a LOT of work.
Ben
i have a 2.1 zebec on jenveys as a drop in package for sale spec should be 220/230 bhp
2.1 zetec
arrow rods
high comp forged pistons
cylinder head developments head and kent cams
ashley manifold
jenvey 45mm throttle bodies
motorsport loom
omex 600
2.1 zetec
arrow rods
ashley manifold
motorsport loom
omex 600
Thanks all for the comments, just looking for different ideas. I don't buy secondhand engines as I build them my self and a friend does all the machine work. Thanks
Balls Deep!
No mate not even close! You will need management and forged pistons and rods either way, but for a ZT you need no head work, cam or custom manifolds to achieve your target BHP of 250..... get a black top, build your forged bottom end, use ST valve springs (or devil developments, etc) and FRS 1.8mm gasket, FRS exhaust manifold and turbo.... done.
