zetec turbo?
Old Jan 27, 2006 | 11:07 PM
Zanderford's Avatar
Zanderford
Default zetec turbo?
hi peeps first time ive posted in this room so here goes
im considerig putting a turbo onto a 2ltr zetec engine what would i have to change in order to acheive this can i get away with not changing the internals what inlet would i have to use etc cheers 4 reading any help will be gratefully recieved
alex
Old Jan 28, 2006 | 06:34 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
simple cheap build
arp bolts on con rods.
2.5mm de comp plate.
std metal inlet found in fiesta/escort e.t.c.
std erst manifold can fit many other turbo s with t3 flange (drill+tap to head or buy conversion plate.
200 sx injectors fit right into rail.
modded sump-fitting welded in for turbo return.
most inportant decent remapable ecu.
hope this helps
Old Jan 29, 2006 | 11:46 AM
Zanderford's Avatar
Zanderford
cheers 4 the reply any chance you could give me an average price 4 these parts and where i can get em
Old Jan 31, 2006 | 09:55 PM
Zanderford's Avatar
Zanderford
anyone?
Old Feb 1, 2006 | 10:47 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
[quote="xr3iturbo"]simple cheap build
arp bolts on con rods. £100 grahame goode racing/mad ford it
2.5mm de comp plate.£150 ferriday engeneering
std metal inlet found in fiesta/escort e.t.c. £25 scrappy
std erst manifold can fit many other turbo s with t3 flange (drill+tap to head or buy conversion plate. odd kid creations do the conversion plate,or you can drill and tap your self??
200 sx injectors fit right into rail. £50 ebay
modded sump-fitting welded in for turbo return. £40-£50 ebay
i am using mega sqiurt ecu this is diy but works a treat
i can get them all built up and tested for £275 all you have to do is wire it up,simple wiring
hope this helps
any questions mate just send a pm instead
tommy
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
