timing marks on s2
Old Jan 15, 2006 | 10:15 AM
kay79's Avatar
kay79
Default timing marks on s2
can anyone tell me were the timing marks are on a s2 i havenot got the timing belt cover
Old Jan 15, 2006 | 10:26 AM
Doug's Avatar
Doug
With no cover
Top pully has a "V" in the centre part of the pully taht lines up with a centre punch mark in the head approxamatly situated at 6 0clock
Bottom pully take the alternator belt pully off and there will be a dimple on the cam belt pully that alignes with a "V" on the engine (water pump housing) approxamatly situated at 12 oclock
Old Jan 15, 2006 | 10:46 AM
kay79's Avatar
kay79
thanks hun i will give that a go and let you know how i got on
Old Jan 16, 2006 | 03:08 PM
fiestasimon's Avatar
fiestasimon
is this the same for a frst?
Old Jan 16, 2006 | 03:15 PM
SafeChav's Avatar
SafeChav
Originally Posted by Doug
With no cover
Easy!!!! Both timing marks are at 12 o-clock. The cam pulley as said has a little arrow/V, and a hole punched in the head at 12 o'clock, the bottom pulley has a tiny nick in it (really hard to see when they get dirty, get a white touch up stick and dab the nick so its easier to see), and the bottom section of the timing belt cover (which u should have fitted, your crazy if you don't), has the marks 0,2,4,6,8 on it, 0 being at 12 o'clock. The bottom pulley should line up with 0 when the cam marks line up.
This puts the engine to cylinder number 1 ATDC (At Top Dead Centre)
This is the same for ANY CVH engine, so yes your fiesta aswell.
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
MK Motorsport Matt
75
Nov 15, 2015 11:22 PM
StephenC
Oct 9, 2015 09:33 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
