Cossie cold running problems
Old Jul 16, 2004 | 09:56 AM
2wd's Avatar
2wd
Default Cossie cold running problems
Hi, a friend off mine have a problem with his stage 4, 93' Escort Cosworth, it starts fine from cold, but it "dies" after a few seconds, unless he use the throttle. when warm it is ok(except it seems to be a bit lean under 2500 rpm). Map, cts, ats, tps, iscv tested and found ok..... Mainly it's under warmup the problem is pressent.....help needed
Old Jul 16, 2004 | 01:58 PM
Dave Henshall's Avatar
Dave Henshall
can you hear the ISCV clicking when you go to position 2 on the ignition when the fuel pump primes up? thats assuming its abig turbo one.
Old Jul 16, 2004 | 06:42 PM
2wd's Avatar
2wd
Yes, there is "clicking" from iscv in pos 2.....and yes this is a big turbo model.
Old Jul 17, 2004 | 08:44 AM
Dave Henshall
could be the ECT (engine coolant temp) sensor tellin gthe ecu that its warm when its not , about 15-20 quid from woodford garage and the likes.
a quick check... its resistance when cold (20 dgc) should be 3.75Kohm, droppin gto 0.38Kohm when at 80deg(normal runing temp)
the ect is the small blue sensor underneath the inlet manifold at the back of the engine - bit of a tw@t to get to and it scres into the head with a copper washer sealing it to the head .
Old Jul 18, 2004 | 05:57 AM
2wd's Avatar
2wd
He tried to change both, the blue water temp sensor and the brown air temp sensor....no change
Also the map, tps, iscv tested and found ok....
Old Aug 17, 2004 | 08:40 AM
2wd's Avatar
2wd
Hmmmm...???
Old Sep 9, 2004 | 10:48 PM
blaazer2's Avatar
blaazer2
has he aquired this problem since fitting a chip or injectors or map sensor?
Old Sep 10, 2004 | 01:40 PM
2wd's Avatar
2wd
I dont know, but I'll ask him. Any idea what it could be ??
Tom
Karl 3dr
102
Oct 14, 2016 08:17 PM
kosienutter
31
Aug 22, 2015 09:55 AM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
Zoggon
Aug 10, 2015 10:39 AM
