RST Escort Sumps....
Old Dec 13, 2005 | 05:44 PM
MichaelG's Avatar
MichaelG
Default RST Escort Sumps....
Hi
Can someone please tell me if the sump pan is the same on a Series 1 as on a Series 2 ?
I would like to replace mine on my Series 1 for a new one while doing the underneath freshen up, and can get a Series 2 one relatively easy.
Failing that does anyone know the part number for one from Ford and if they are still available ? Gasket too please
Thanks folks
Michael.
Old Dec 13, 2005 | 05:48 PM
HORNETS7's Avatar
HORNETS7
yes they should be the same if not better as the internals might have been baffled to stop oil floating when cornering!
one on ebay at the moment powdercoated blue
i'll find u the link
Old Dec 13, 2005 | 05:49 PM
HORNETS7's Avatar
HORNETS7
here ya go !!!!!!!!!!!
http://cgi.ebay.co.uk/Rs-Turbo-sump_...QQcmdZViewItem
Old Dec 13, 2005 | 05:52 PM
MichaelG's Avatar
MichaelG
Cheers m8 !
Just need someone to confirm they are DEFO the same though. I was under the impression that the oil pickup was different on an S1 but maybe thinking of something else..............
Old Dec 13, 2005 | 06:22 PM
edding's Avatar
edding
what material is made rst sump?????
Old Dec 13, 2005 | 06:43 PM
davidreader5's Avatar
davidreader5
HI,
They are different, on the s2 the oil return fitting leading into the
sump is different , you can mod it to fit, just compare the two and make
room for the pipe if fitting a s1 to a s2.
Dave R.
Old Dec 13, 2005 | 08:15 PM
MichaelG's Avatar
MichaelG
Originally Posted by davidreader5
HI,
Dave R.
Thanks mate thats along the lines of what i was thinking. Is it a straightforward mod to do or more hassle than its worth ? It will be a Sump designed for a S2 that i would like to mod to fit to an S1......
Old Dec 13, 2005 | 08:26 PM
davidreader5
MICHAEL,
The s2 sump should go straight on as the s2 engine has a pipe after the
oil return on the block, if you see a s2 engine with the sump off, you
will see the return from the block then follow it and you can see the approx 10 to 11 mm, pipe im talking about it helps the oil return to the sump better, if you fit a s1 or std cvh sump it hits on the pipe and you
have to make room for the sump to seat against the pipe, i did mine
but you should be able to just fit the s2 sump to a s1, without any problems, compare the two and you will see,
DAVE R.
Old Dec 13, 2005 | 08:49 PM
MichaelG's Avatar
MichaelG
MICHAEL,
DAVE R.
So a normal CVH Sump will mate to an S1 block fine yeah ? Its just if fitting an S1 sump to an S2 the mod is needed ?
Old Dec 13, 2005 | 09:01 PM
davidreader5
HI,
with mine noticed it by chance doing a restoration, S2, so the sump
i assume was off either a s1, or possible a std cvh, not compared
that but if the oil capacity is the same i would say the std sump is as a s1,
but may be baffled differently, put it this way a xr3i of the s1 era is the
same sump.
DAVE R.
Old Dec 13, 2005 | 10:14 PM
MichaelG's Avatar
MichaelG
HI,
same sump.
DAVE R.
Now am even more confusled !! lol
This sump below is apparently for an S2 (i asked the seller) so i assume this will fit an S1 yeah ?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Old Dec 14, 2005 | 05:10 AM
Nick500's Avatar
Nick500
Just try and get a S1 sump!! lol!!
Old Dec 14, 2005 | 09:27 AM
JesseT's Avatar
JesseT
Either there is a hole under the oil return pipe or there isn't. If it's missing, then it's a 1 minute job to make one. There are no other differences between the different 1.6 cvh sumps.
Old Dec 14, 2005 | 06:17 PM
MichaelG's Avatar
MichaelG
Shut it you
Thats another job for you when you get home.............sump drillin !!
Old Dec 14, 2005 | 06:21 PM
opposite lock's Avatar
opposite lock
Default Re: RST Escort Sumps....
Originally Posted by MichaelG
Hi
Thanks folks
Michael.
you can get 1 off a guy on ebay brand new . I bought one fits pukka for around 50 quid. all in fresh black. But its not a ford item if your into perfection
Old Dec 14, 2005 | 06:23 PM
MichaelG's Avatar
MichaelG
Is it the one i posted in the link above mate ? Thats the one i am going to go for, he says they are for Series 2, so i assume no modification needed for an S1 ?
Old Dec 15, 2005 | 08:42 AM
MJC's Avatar
MJC
Mike, why dont you just get your original one cleaned up and repainted? that would be the best option I would have thought!
Old Dec 15, 2005 | 09:53 AM
opposite lock
yes thats it , fits perfect
Old Dec 15, 2005 | 02:48 PM
MichaelG's Avatar
MichaelG
Hello there mate
Well i am lazy, and for £40 its not bad
I think mine is a bit porous as its oily all over, so might be as well just getting a new one !?what u think mate ?
Old Dec 16, 2005 | 08:33 AM
MJC's Avatar
MJC
I'd personally get the original all cleaned up n fit a new sump gasket. Porblem solved
Old Dec 16, 2005 | 09:44 AM
MichaelG's Avatar
MichaelG
If its gone porous though, am gonna need a new one Dont know if its porous or just leaking from top down. will have to investigate,
JK12
33
Apr 26, 2021 12:09 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Billy_RS
Sep 13, 2015 04:17 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
